ZimaOS already places Index-tts above 12 GB memory. A 16 GB machine therefore has limited headroom once ZimaOS, Docker and other services are included. Persistent swapping or out-of-memory behavior is a clear signal to move beyond the minimum class.
For users running Index-TTS beside other AI, media or home-server containers.Hardwareanforderungen für Index-TTS: RAM, GPU, VRAM und Speicherplatz
Erfahren Sie mehr über die Hardwareanforderungen von Index-TTS an RAM, GPU, VRAM, CUDA und Speicher, die Voraussetzungen für Voice Cloning und die passende ZimaOS-Hardware.
Index-TTS hardware requirements at a glance
Index-TTS is heavier than a normal web app because the host runs an autoregressive speech model, acoustic model and vocoder locally. ZimaOS currently calls for more than 12 GB system memory, while upstream IndexTTS2 does not publish one universal RAM or VRAM minimum.
- CPU
- The upstream project does not publish a universal minimum CPU model or core count. CPU inference is possible but much slower than a well-configured accelerator path, so CPU choice mainly affects generation speed when no GPU is used.
- RAM
- ZimaOS's current Index-tts release guidance specifies memory greater than 12 GB. That makes a 16 GB Zima configuration the practical minimum class for this packaged app. Daiyl independently lists 16 GB RAM minimum for its local IndexTTS2 installer.
- GPU / VRAM
- Upstream IndexTTS2 does not publish one universal VRAM minimum. The Local Lab recommends a CUDA-compatible NVIDIA GPU with at least 8 GB VRAM for its Windows build, while Knowara also uses 8 GB as a real-time planning point. Treat these as third-party deployment guidance, not an upstream minimum.
- Storage
- The upstream project does not publish one universal disk minimum. Daiyl recommends 24 GB or more, while The Local Lab asks for at least 40 GB free for its one-click Windows package. On ZimaOS, use SSD capacity with headroom for model checkpoints, Docker layers, generated audio and caches.
- Acceleration
- The official repository supports optional FP16 inference to reduce VRAM use and improve speed, plus DeepSpeed and compiled CUDA acceleration depending on hardware. Linux/Windows CUDA setups should use CUDA Toolkit 12.8 or newer according to the current README.
- Best Zima starting point
- ZimaBoard 2 1664 is the smallest current Zima configuration that clears the ZimaOS >12 GB memory guidance, but add SSD storage. ZimaCube 2 Pro is the more balanced CPU/RAM/storage option. Creator Pack is for users who also want local NVIDIA acceleration, subject to verifying exact GPU VRAM.
Index-TTS sizing starts with the ZimaOS memory gate, then checks CPU versus GPU inference, accelerator compatibility, model storage and the amount of speech generated.
Official requirements
Start with system memory. ZimaOS currently describes Index-tts as needing more than 12 GB memory, so use a 16 GB or larger system rather than treating an 8 GB configuration as the normal supported target.
Confirm your needs
Choose the inference path. IndexTTS2 can run on CPU or hardware accelerators, but GPU acceleration is the practical route for faster local generation. For NVIDIA on Linux/Windows, the current upstream README calls for CUDA Toolkit 12.8 or newer when CUDA is used.
Leave room to grow
Leave storage headroom for the model repository, downloaded checkpoints, Python/uv environment, Docker data, generated WAV files and repeated voice-cloning jobs. Third-party installers range from about 24 GB recommended to 40 GB free.
Run it on ZimaOS
Generate representative clips and monitor peak system RAM, VRAM, real-time factor, CPU/GPU utilization and storage growth. Enable FP16 only after confirming that the small quality tradeoff is acceptable for your voice-cloning workload.
- IndexTTS2 model/version used by the installed package
- At least >12 GB system memory for the current ZimaOS App
- CPU-only versus GPU-accelerated inference
- Exact NVIDIA GPU and available VRAM if using CUDA
- CUDA Toolkit 12.8+ and PyTorch GPU visibility
- FP16, DeepSpeed or compiled-kernel acceleration
- SSD capacity for checkpoints, cache and generated audio
- Other ZimaOS AI, media and container workloads
The IndexTTS upstream repository publishes installation and acceleration requirements but no universal minimum CPU, RAM, VRAM or disk table. ZimaOS separately publishes a memory requirement for its packaged Index-tts app.
For a ZimaOS deployment, use more than 12 GB RAM as the current local package gate. Do not relabel third-party 8 GB VRAM or 24–40 GB storage figures as official upstream requirements; use them as planning references and validate the actual inference path.
| ZimaOS system memory | More than 12 GB | ZimaSpace's January 2026 App announcement explicitly describes Index-tts as a local text-to-speech tool requiring memory >12 GB. |
| Upstream RAM / VRAM minimum | No universal official number published | The official README focuses on installation, model download and optional acceleration rather than a fixed hardware table. |
| Installation method | uv is the supported upstream installation path | The current official repository warns that conda/pip-based non-standard installs are not supported for dependency correctness. |
| NVIDIA CUDA path | CUDA Toolkit 12.8 or newer on Linux/Windows when CUDA is used | This is the current upstream CUDA compatibility instruction, not a statement that NVIDIA hardware is mandatory for every inference path. |
| VRAM optimization | FP16 can reduce VRAM and improve speed | The official WebUI supports --fp16, and the maintainers note a small quality tradeoff. DeepSpeed and compiled kernels may also help depending on hardware. |
| Accelerator support | CPU and multiple accelerator backends are possible | Official project discussion confirms NVIDIA CUDA, AMD ROCm, Intel XPU, Apple MPS and CPU paths, though performance and setup quality vary by backend. |
Upgrade Index-TTS hardware when generation speed, memory pressure or concurrency becomes the measured bottleneck rather than relying on one generic VRAM number.
System memory stays close to the 16 GB ceiling
CPU generation is too slow for interactive voice work
GPU VRAM pressure limits FP32 or concurrent jobs
CPU inference works, but third-party testing and official issue reports show much slower generation than a properly configured accelerator. Move to a compatible GPU path when turnaround time matters for dubbing, cloning or repeated iteration.
For creators generating many clips, testing emotion settings or using Index-TTS interactively.The Local Lab recommends at least 8 GB VRAM for its Windows package, while community reports show that 12 GB can still be tight in some configurations. Use FP16 and measure peak VRAM before assuming a nominal card size guarantees smooth generation.
For NVIDIA users increasing clip length, parallel work or higher-performance local generation.Plan hardware growth with confidence
Index-TTS scales most cleanly when system memory, GPU acceleration and model/audio storage are treated as separate resources.
Put the model environment and checkpoints on SSD
IndexTTS2 downloads a large checkpoint set and also keeps Python packages, caches and generated audio locally. SSD storage improves startup and repeated model access while preventing a small system disk from becoming the first bottleneck.
Use SATA or NVMe SSD rather than relying only on 64 GB eMMC for long-term Index-TTS use.Use FP16 before assuming a larger GPU is mandatory
The official WebUI exposes FP16 specifically because it reduces VRAM use and improves speed with only a small quality tradeoff. It can change the practical fit of a consumer GPU.
Test FP16 on representative voices and emotion settings, then size the GPU from measured peak VRAM and quality requirements.Keep generated audio separate from model storage
Voice-cloning sessions can create many WAV outputs and reference files. These grow independently from the checkpoint and environment and should be backed up differently.
Use fast SSD for active model/cache data and larger NAS storage for source/reference audio and final generated libraries.Add a dedicated GPU only when speed justifies it
The ZimaOS App announcement defines a system-memory requirement, not a mandatory GPU requirement. A dedicated NVIDIA GPU is most valuable when interactive or repeated local generation needs lower latency.
Use ZimaCube 2 Creator Pack or a separately validated GPU expansion only after confirming the exact VRAM and software path.Can it run on ZimaOS?
Index-TTS is currently listed in the ZimaOS App Store. ZimaSpace's release announcement explicitly marks the local app as requiring more than 12 GB memory, making system RAM the first compatibility check.
Install Index-TTS from the ZimaOS App Store
ZimaOS currently lists Index-TTS as an AI app. The package is distinct from the separate DeepSeek OCR(Nvidia GPU) listing and should be sized from its own memory guidance.
Open Index-TTS in the ZimaOS App StoreUse more than 12 GB system memory
ZimaSpace's January 2026 App announcement explicitly describes Index-tts as a local text-to-speech tool requiring memory >12 GB. This rules out current 8 GB Zima configurations as the normal target.
Read the ZimaOS App announcementTreat GPU acceleration as a second-stage decision
Upstream IndexTTS2 supports multiple inference backends and optional FP16/CUDA acceleration. If you add a GPU, verify the exact device, available VRAM, driver, container exposure and inference speed instead of assuming any NVIDIA card is sufficient.
Read the IndexTTS official repositoryChoose Zima hardware for your Index-TTS workload
The current ZimaOS >12 GB memory requirement immediately makes 16 GB the minimum Zima class for a normal Index-TTS deployment. Storage and GPU acceleration then determine which 16 GB-or-larger system is the better fit.
Does the Zima system have more than 12 GB system memory and enough SSD capacity for the local model stack?
ZimaBoard 2 1664 is the smallest current Zima option that clears the memory gate, but pair it with SSD storage. ZimaCube 2 Pro is a more balanced choice for heavier CPU inference, larger audio/model storage and broader always-on workloads.
- Smallest current Zima memory fit; add SSDZimaBoard 2 1664
- More balanced CPU, storage and 16 GB system-memory platformZimaCube 2 Pro
ZimaBoard 2 832 and ZimaCube 2 Standard are below the current ZimaOS >12 GB memory guidance. Creator Pack is appropriate only when you also need dedicated NVIDIA acceleration and have verified its exact VRAM against the intended IndexTTS configuration.
- Below current ZimaOS memory guidanceZimaBoard 2 832
- Below current ZimaOS memory guidance despite larger storageZimaCube 2 Standard
- 64 GB RAM plus dedicated NVIDIA acceleration pathZimaCube 2 Creator Pack
This is a workload guide, not a guaranteed real-time-factor or VRAM benchmark. Performance depends on IndexTTS version, accelerator backend, FP16, DeepSpeed, CUDA/PyTorch versions, clip length, emotion mode, concurrency and other ZimaOS services.
| ZimaBoard 2 832 | Adjacent audio workflows, storage or remote Index-TTS access rather than the current ZimaOS local Index-TTS App. | Reference-audio storage, generated-audio management and lightweight helper services. |
8 GB RAM is below the ZimaOS >12 GB requirement. Do not recommend the 832 as the standard local Index-TTS host. | Get Now |
| ZimaBoard 2 1664 | The smallest current ZimaBoard 2 configuration that clears the ZimaOS memory requirement for local Index-TTS. | Personal voice cloning, TTS generation and light co-hosted services with CPU inference or a separately validated accelerator path. |
16 GB only modestly exceeds the >12 GB ZimaOS gate. Heavy concurrent apps or CPU-only generation can still be constrained, and 64 GB eMMC is not ideal as the long-term model/audio workspace. | Get Now |
| ZimaCube 2 Standard | Large voice/audio storage and remote Index-TTS workflows, but not the current standard local ZimaOS Index-TTS target. | Reference-audio archives, generated voice libraries, backups and remote inference workflows. |
8 GB RAM is below the current ZimaOS Index-tts memory requirement. Do not recommend Standard for the packaged local app solely because it has more storage. | Get Now |
| ZimaCube 2 Pro | The most balanced stock Zima configuration for local Index-TTS without making dedicated GPU acceleration mandatory. | Voice cloning, repeated TTS generation, larger reference/output libraries and other always-on ZimaOS services. |
16 GB still leaves limited memory headroom above the ZimaOS >12 GB guidance once other services run. For heavy multi-app AI use, 64 GB is safer. | Get Now |
| ZimaCube 2 Creator Pack | Index-TTS combined with dedicated local NVIDIA acceleration, large audio libraries and other AI/creator workloads. | Interactive voice cloning, repeated local generation, AI services and large multi-drive source/output storage. |
The current product page names RTX PRO 2000 but does not publish VRAM in its text specification. Do not promise the third-party 8 GB VRAM tier or a particular real-time factor until the installed GPU memory is verified. | Get Now |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
These answers separate the current ZimaOS App memory gate, upstream IndexTTS2 requirements and third-party Windows/local-install recommendations.
How much RAM does Index-TTS need?
Upstream IndexTTS2 does not publish one universal RAM minimum, but ZimaOS currently describes its Index-tts App as requiring more than 12 GB memory. Daiyl's local installer independently lists 16 GB RAM minimum, so 16 GB is the practical Zima starting class.
Is 8 GB RAM enough for Index-TTS on ZimaOS?
Not according to the current ZimaOS App guidance. ZimaSpace specifies memory >12 GB, so current 8 GB ZimaBoard 2 832 and ZimaCube 2 Standard configurations fall below the packaged app's stated requirement.
Does IndexTTS2 need a GPU?
A GPU is not universally mandatory. The project can run through CPU and several accelerator backends, but CPU inference is slower. NVIDIA CUDA is a common performance path, and the current README requires CUDA Toolkit 12.8+ for Linux/Windows CUDA setups.
How much VRAM does IndexTTS2 need?
The official repository does not publish one universal VRAM minimum. The Local Lab recommends at least 8 GB VRAM for its Windows installer, and Knowara also uses 8 GB as a real-time planning point. Those are third-party deployment recommendations, not an upstream minimum.
Can ZimaBoard 2 run Index-TTS?
ZimaBoard 2 1664 can clear the current ZimaOS >12 GB memory requirement with its 16 GB RAM. Add SSD storage because its 64 GB eMMC leaves limited room for the model environment, checkpoints and generated audio. The 832's 8 GB RAM is below the current ZimaOS requirement.
Can FP16 reduce IndexTTS2 VRAM usage?
Yes. The official IndexTTS2 WebUI exposes an --fp16 option, and the maintainers say half-precision is faster and uses less VRAM with a very small quality loss. Actual savings and speed still depend on the GPU and software stack.
How much storage should I plan for Index-TTS?
Upstream does not publish one universal disk minimum. Daiyl recommends 24 GB or more for its local install, while The Local Lab asks for at least 40 GB free for its bundled Windows setup. On ZimaOS, use SSD storage with extra room for Docker data, checkpoints, cache and output audio.
When should I choose ZimaCube 2 Creator Pack for Index-TTS?
Choose Creator Pack when you want dedicated NVIDIA acceleration plus 64 GB system memory and large local storage for voice or other AI workloads. Do not choose it merely to satisfy Index-TTS's system-memory requirement; ZimaCube 2 Pro already reaches 16 GB. Verify the Creator Pack GPU's exact VRAM before promising a specific performance tier.
What sources and further reading informed this Index-TTS hardware guide?
The Local Lab's December 2025 Windows packages recommend an RTX 4090/5090-class GPU for best performance, at least 8 GB VRAM and 40 GB free storage; these figures apply to its bundled Windows setup, not to upstream as a universal minimum. The DEV review correctly recommends CUDA acceleration but does not establish numeric RAM/VRAM minimums. Knowara's July 2026 hands-on review uses 8 GB VRAM as a real-time inference planning point and notes CPU inference is slower, but its 8-GB claim is third-party interpretation rather than a number currently published in the official README. Daiyl's LM Downloader guide specifies 16 GB RAM minimum and 24 GB+ storage for its Mac/Windows installer and recommends NVIDIA on Windows; these are installer-specific requirements. The canonical IndexTTS GitHub repository remains the primary source for supported installation and acceleration behavior.
