Hardwareanforderungen für Immich Power Tools: RAM, CPU, Speicher und Controller sowie verwaltete Workloads
Plane Immich Power Tools mit RAM, CPU, persistentem Speicher und Dienstabhängigkeiten – mit einer an der Arbeitslast orientierten Dimensionierung für ZimaOS, Backups und praktischen Hardware-Empfehlungen.
Immich Power Tools hardware requirements at a glance
Power tools for organizing Immich libraries These perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist declarative configuration, credentials, workflow history, controller state and recovery copies.
Required services
Use the supported upstream runtime and complete Immich Power Tools deployment for the selected release. These perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small.
Main sizing variable
managed objects/nodes, API activity, reconciliation frequency, concurrent jobs and worker resources
Practical Zima starting point
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. These perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small.
Plan the complete Immich Power Tools workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported upstream runtime and complete Immich Power Tools deployment for the selected release. These perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small.
    Test a representative busy operation: managed objects/nodes, API activity, reconciliation frequency, concurrent jobs and worker resources Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist declarative configuration, credentials, workflow history, controller state and recovery copies. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. These perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 11, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Immich Power Tools official requirements
These perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist declarative configuration, credentials, workflow history, controller state and recovery copies.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported upstream runtime and complete Immich Power Tools deployment for the selected release. These perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small.Include every stateful companion service in the host budget.
Persistent statePersist declarative configuration, credentials, workflow history, controller state and recovery copies.An image rebuild or container replacement is not a backup.
Deployment boundaryThese perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small.Check the linked project instructions for the selected edition and release.
Use observed Immich Power Tools workload pressure to decide when an upgrade is warranted.
managed objects/nodes, API activity, reconciliation frequency, concurrent jobs and worker resources Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist declarative configuration, credentials, workflow history, controller state and recovery copies. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
These perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review Immich Power Tools deployment details ↗
Which Zima hardware fits Immich Power Tools?
Which workload best matches your Immich Power Tools deployment?
Conditional lab or supporting storage use only
  • Supporting hardware onlyZimaBoard 2 832
ZimaBoard 2 832 Conditional lab or supporting-service role managed objects/nodes, API activity, reconciliation frequency, concurrent jobs and worker resources
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. These perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small. Get Now
ZimaBoard 2 1664 Conditional lab or supporting-service role Use the supported upstream runtime and complete Immich Power Tools deployment for the selected release. These perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small.
Answers to Immich Power Tools RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Immich Power Tools?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: managed objects/nodes, API activity, reconciliation frequency, concurrent jobs and worker resources
Persist declarative configuration, credentials, workflow history, controller state and recovery copies. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Accelerator needs depend on the selected inference, synthesis, browser or media backend. These perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small.
Can I deploy it on ZimaOS?
These perform management/batch work against separately deployed media/photo services. Bound concurrent operations, preserve credentials/state and verify deletion/cleanup settings; scanning or metadata changes can load the backend even when the management UI is small. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Immich Power Tools hardware guide?
This guide was reviewed against the linked project deployment documentation on November 11, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Immich Power Tools official setup / requirements
  2. Immich Power Tools configuration / deployment
  3. Immich Power Tools official repository and releases
  4. ZimaBoard 2 specifications
  5. Immich Power Tools image source: public project material
