Immich-Frame-Hardwareanforderungen: RAM, CPU, Speicher & Bibliotheksscans & Vorschaubilder
Plane RAM, CPU, persistenten Speicher und Dienstabhängigkeiten für Immich-Frame und dimensioniere ZimaOS anhand der Arbeitslast. Berücksichtige Backups und praktische Hardwareoptionen.
Immich-Frame hardware requirements at a glance
Awesome way to display photos as a digital photo frame The display/frame service uses an existing Immich library/API. Image retrieval/cache and slideshow delivery are separate from Immich database storage, machine learning and client display rendering; the frame does not replace the original photo archive.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist original media, metadata database, previews/thumbnails and processing cache.
Required services
Use the supported upstream runtime and complete Immich-Frame deployment for the selected release. The display/frame service uses an existing Immich library/API. Image retrieval/cache and slideshow delivery are separate from Immich database storage, machine learning and client display rendering; the frame does not replace the original photo archive.
Main sizing variable
initial library scan, photo/video formats, thumbnail jobs and simultaneous browsing
Practical Zima starting point
Plan the complete Immich-Frame workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported upstream runtime and complete Immich-Frame deployment for the selected release. The display/frame service uses an existing Immich library/API. Image retrieval/cache and slideshow delivery are separate from Immich database storage, machine learning and client display rendering; the frame does not replace the original photo archive.
    Test a representative busy operation: initial library scan, photo/video formats, thumbnail jobs and simultaneous browsing Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist original media, metadata database, previews/thumbnails and processing cache. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. The display/frame service uses an existing Immich library/API. Image retrieval/cache and slideshow delivery are separate from Immich database storage, machine learning and client display rendering; the frame does not replace the original photo archive.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 11, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Immich-Frame official requirements
The display/frame service uses an existing Immich library/API. Image retrieval/cache and slideshow delivery are separate from Immich database storage, machine learning and client display rendering; the frame does not replace the original photo archive. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist original media, metadata database, previews/thumbnails and processing cache.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported upstream runtime and complete Immich-Frame deployment for the selected release. The display/frame service uses an existing Immich library/API. Image retrieval/cache and slideshow delivery are separate from Immich database storage, machine learning and client display rendering; the frame does not replace the original photo archive.Include every stateful companion service in the host budget.
Persistent statePersist original media, metadata database, previews/thumbnails and processing cache.An image rebuild or container replacement is not a backup.
Deployment boundaryThe display/frame service uses an existing Immich library/API. Image retrieval/cache and slideshow delivery are separate from Immich database storage, machine learning and client display rendering; the frame does not replace the original photo archive.Check the linked project instructions for the selected edition and release.
Use observed Immich-Frame workload pressure to decide when an upgrade is warranted.
initial library scan, photo/video formats, thumbnail jobs and simultaneous browsing Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist original media, metadata database, previews/thumbnails and processing cache. Track primary state and backup retention separately.
Use suitable active storage
ZimaBoard 2 832 or ZimaCube 2 Pro according to the measured constraint.
Fix the observed bottleneck
Verify the supported upstream deployment
The display/frame service uses an existing Immich library/API. Image retrieval/cache and slideshow delivery are separate from Immich database storage, machine learning and client display rendering; the frame does not replace the original photo archive. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review Immich-Frame deployment details ↗
Which Zima hardware fits Immich-Frame?
Which workload best matches your Immich-Frame deployment?
Modest Immich-Frame deployment
ZimaBoard 2 832 Modest Immich-Frame workload initial library scan, photo/video formats, thumbnail jobs and simultaneous browsing
ZimaCube 2 Pro More processing or shared-service headroom Use the supported upstream runtime and complete Immich-Frame deployment for the selected release. The display/frame service uses an existing Immich library/API. Image retrieval/cache and slideshow delivery are separate from Immich database storage, machine learning and client display rendering; the frame does not replace the original photo archive.
16 GB
10GbE plus 2.5GbE
Answers to Immich-Frame RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Immich-Frame?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: initial library scan, photo/video formats, thumbnail jobs and simultaneous browsing
Persist original media, metadata database, previews/thumbnails and processing cache. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Accelerator needs depend on the selected inference, synthesis, browser or media backend. The display/frame service uses an existing Immich library/API. Image retrieval/cache and slideshow delivery are separate from Immich database storage, machine learning and client display rendering; the frame does not replace the original photo archive.
Can I deploy it on ZimaOS?
The display/frame service uses an existing Immich library/API. Image retrieval/cache and slideshow delivery are separate from Immich database storage, machine learning and client display rendering; the frame does not replace the original photo archive. Measure the same representative operation before and after a configuration or hardware change.
ZimaBoard 2 832 is the editorial starting point for this modest deployment. Choose ZimaCube 2 Pro for measured memory/processing pressure or broader shared services; retained data determines storage expansion.
What sources informed this Immich-Frame hardware guide?
This guide was reviewed against the linked project deployment documentation on November 11, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Immich-Frame official setup / requirements
  2. Immich-Frame configuration / deployment
  3. Immich-Frame official repository and releases
  4. ZimaBoard 2 specifications
  5. Immich-Frame image source: public project material
