Hardwareanforderungen für den Homelab-Monitor: RAM, CPU, Speicherplatz & Prüfungen, Agenten & Verlauf
Plane deinen Homelab-Monitoring-Stack: Überwache RAM, CPU, persistenten Speicher und Service-Abhängigkeiten. Stimme ZimaOS auf deine Workloads ab und plane Backups sowie eine praxisgerechte Hardwareauswahl.
Homelab Monitor hardware requirements at a glance
Host, Docker and device monitoring with separately configured access. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist check definitions, credentials, agent/host mappings and configured historical records.
Required services
Use the documented Homelab Monitor runtime and selected service topology. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. Upstream references include SQLite. Verify which apply to your selected mode; a mention is not a mandatory dependency.
Main sizing variable
check count, interval, timeouts, network discovery and retained history
Practical Zima starting point
Plan the complete Homelab Monitor workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the documented Homelab Monitor runtime and selected service topology. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. Upstream references include SQLite. Verify which apply to your selected mode; a mention is not a mandatory dependency.
    Test a representative busy operation: check count, interval, timeouts, network discovery and retained history Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist check definitions, credentials, agent/host mappings and configured historical records. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Host, Docker and device monitoring with separately configured access. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. SSH/host, Docker and systemd visibility must be configured separately. GPU telemetry does not imply the monitoring host supplies inference resources; optional benchmark jobs add real worker load.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 20, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Homelab Monitor official requirements
Host, Docker and device monitoring with separately configured access. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. SSH/host, Docker and systemd visibility must be configured separately. GPU telemetry does not imply the monitoring host supplies inference resources; optional benchmark jobs add real worker load. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist check definitions, credentials, agent/host mappings and configured historical records.Installation space is separate from retained content, working files and backups.
Service topologyUse the documented Homelab Monitor runtime and selected service topology. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. Upstream references include SQLite. Verify which apply to your selected mode; a mention is not a mandatory dependency.Include every stateful companion service in the host budget.
Persistent statePersist check definitions, credentials, agent/host mappings and configured historical records.An image rebuild or container replacement is not a backup.
Deployment boundaryHost, Docker and device monitoring with separately configured access. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. SSH/host, Docker and systemd visibility must be configured separately. GPU telemetry does not imply the monitoring host supplies inference resources; optional benchmark jobs add real worker load.Check the linked project instructions for the selected edition and release.
Use observed Homelab Monitor workload pressure to decide when an upgrade is warranted.
check count, interval, timeouts, network discovery and retained history Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist check definitions, credentials, agent/host mappings and configured historical records. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
Host, Docker and device monitoring with separately configured access. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. SSH/host, Docker and systemd visibility must be configured separately. GPU telemetry does not imply the monitoring host supplies inference resources; optional benchmark jobs add real worker load. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review Homelab Monitor deployment details ↗
Which Zima hardware fits Homelab Monitor?
Which workload best matches your Homelab Monitor deployment?
Modest Homelab Monitor deployment
ZimaBoard 2 832 Modest Homelab Monitor workload check count, interval, timeouts, network discovery and retained history
ZimaBoard 2 1664 More processing or shared-service headroom Use the documented Homelab Monitor runtime and selected service topology. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. Upstream references include SQLite. Verify which apply to your selected mode; a mention is not a mandatory dependency.
Answers to Homelab Monitor RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Homelab Monitor?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: check count, interval, timeouts, network discovery and retained history
Persist check definitions, credentials, agent/host mappings and configured historical records. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Host, Docker and device monitoring with separately configured access. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. SSH/host, Docker and systemd visibility must be configured separately. GPU telemetry does not imply the monitoring host supplies inference resources; optional benchmark jobs add real worker load. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Homelab Monitor hardware guide?
This guide was reviewed against the linked project deployment documentation on November 20, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Homelab Monitor official setup / requirements
  2. Homelab Monitor configuration / deployment
  3. Homelab Monitor official repository and releases
  4. ZimaBoard 2 specifications
  5. Homelab Monitor image source: public project material
