Hardwareanforderungen der Hermes-Steuerungsschnittstelle: RAM, CPU, Speicher und Workspaces und Build-Jobs
Plane den RAM- und CPU-Bedarf, den persistenten Speicher und die Dienstabhängigkeiten für die Hermes Control Interface, mit einer auf die Workloads abgestimmten Dimensionierung von ZimaOS, Backups und praktischen Hardware-Empfehlungen.
Hermes Control Interface hardware requirements at a glance
Operate a browser interface for an existing Hermes deployment; agent sessions, terminals and underlying tools are separate from the dashboard. The interface is separate from agent harnesses, compilers, tests and browser tools. Measure parallel workspaces and build peaks; repositories, dependency caches, image layers and generated artifacts need persistent and temporary space.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist workspace files, repositories, extensions, configuration, build caches and artifacts. Preserve a matched set and keep independent recovery copies.
Required services
Use the supported Hermes Control Interface runtime and full upstream deployment topology. The interface is separate from agent harnesses, compilers, tests and browser tools. Measure parallel workspaces and build peaks; repositories, dependency caches, image layers and generated artifacts need persistent and temporary space. The reviewed repository references SQLite; include each only when required by the chosen mode, not simply because the name appears in the repository.
Main sizing variable
active workspaces, language servers, dependency installs, builds and test processes
Practical Zima starting point
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Operate a browser interface for an existing Hermes deployment; agent sessions, terminals and underlying tools are separate from the dashboard. An idle editor or control plane does not represent build consumption. Match each workspace image and runtime, and isolate heavy compilation or nested-container jobs when required. The interface is separate from agent harnesses, compilers, tests and browser tools. Measure parallel workspaces and build peaks; repositories, dependency caches, image layers and generated artifacts need persistent and temporary space.
Plan the complete Hermes Control Interface workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported Hermes Control Interface runtime and full upstream deployment topology. The interface is separate from agent harnesses, compilers, tests and browser tools. Measure parallel workspaces and build peaks; repositories, dependency caches, image layers and generated artifacts need persistent and temporary space. The reviewed repository references SQLite; include each only when required by the chosen mode, not simply because the name appears in the repository.
    Test a representative busy operation: active workspaces, language servers, dependency installs, builds and test processes Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist workspace files, repositories, extensions, configuration, build caches and artifacts. Preserve a matched set and keep independent recovery copies. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Operate a browser interface for an existing Hermes deployment; agent sessions, terminals and underlying tools are separate from the dashboard. An idle editor or control plane does not represent build consumption. Match each workspace image and runtime, and isolate heavy compilation or nested-container jobs when required. The interface is separate from agent harnesses, compilers, tests and browser tools. Measure parallel workspaces and build peaks; repositories, dependency caches, image layers and generated artifacts need persistent and temporary space.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 24, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Hermes Control Interface official requirements
Operate a browser interface for an existing Hermes deployment; agent sessions, terminals and underlying tools are separate from the dashboard. An idle editor or control plane does not represent build consumption. Match each workspace image and runtime, and isolate heavy compilation or nested-container jobs when required. The interface is separate from agent harnesses, compilers, tests and browser tools. Measure parallel workspaces and build peaks; repositories, dependency caches, image layers and generated artifacts need persistent and temporary space. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist workspace files, repositories, extensions, configuration, build caches and artifacts. Preserve a matched set and keep independent recovery copies.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported Hermes Control Interface runtime and full upstream deployment topology. The interface is separate from agent harnesses, compilers, tests and browser tools. Measure parallel workspaces and build peaks; repositories, dependency caches, image layers and generated artifacts need persistent and temporary space. The reviewed repository references SQLite; include each only when required by the chosen mode, not simply because the name appears in the repository.Include every stateful companion service in the host budget.
Persistent statePersist workspace files, repositories, extensions, configuration, build caches and artifacts. Preserve a matched set and keep independent recovery copies.An image rebuild or container replacement is not a backup.
Deployment boundaryOperate a browser interface for an existing Hermes deployment; agent sessions, terminals and underlying tools are separate from the dashboard. An idle editor or control plane does not represent build consumption. Match each workspace image and runtime, and isolate heavy compilation or nested-container jobs when required. The interface is separate from agent harnesses, compilers, tests and browser tools. Measure parallel workspaces and build peaks; repositories, dependency caches, image layers and generated artifacts need persistent and temporary space.Check the linked project instructions for the selected edition and release.
Use observed Hermes Control Interface workload pressure to decide when an upgrade is warranted.
active workspaces, language servers, dependency installs, builds and test processes Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist workspace files, repositories, extensions, configuration, build caches and artifacts. Preserve a matched set and keep independent recovery copies. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
Operate a browser interface for an existing Hermes deployment; agent sessions, terminals and underlying tools are separate from the dashboard. An idle editor or control plane does not represent build consumption. Match each workspace image and runtime, and isolate heavy compilation or nested-container jobs when required. The interface is separate from agent harnesses, compilers, tests and browser tools. Measure parallel workspaces and build peaks; repositories, dependency caches, image layers and generated artifacts need persistent and temporary space. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review Hermes Control Interface deployment details ↗
Which Zima hardware fits Hermes Control Interface?
Which workload best matches your Hermes Control Interface deployment?
Conditional lab or supporting storage use only
  • Supporting hardware onlyZimaBoard 2 1664
ZimaBoard 2 1664 Conditional lab or supporting-service role active workspaces, language servers, dependency installs, builds and test processes
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Operate a browser interface for an existing Hermes deployment; agent sessions, terminals and underlying tools are separate from the dashboard. An idle editor or control plane does not represent build consumption. Match each workspace image and runtime, and isolate heavy compilation or nested-container jobs when required. The interface is separate from agent harnesses, compilers, tests and browser tools. Measure parallel workspaces and build peaks; repositories, dependency caches, image layers and generated artifacts need persistent and temporary space. Get Now
ZimaCube 2 Pro Conditional lab or supporting-service role Use the supported Hermes Control Interface runtime and full upstream deployment topology. The interface is separate from agent harnesses, compilers, tests and browser tools. Measure parallel workspaces and build peaks; repositories, dependency caches, image layers and generated artifacts need persistent and temporary space. The reviewed repository references SQLite; include each only when required by the chosen mode, not simply because the name appears in the repository.
16 GB
10GbE plus 2.5GbE
Answers to Hermes Control Interface RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Hermes Control Interface?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: active workspaces, language servers, dependency installs, builds and test processes
Persist workspace files, repositories, extensions, configuration, build caches and artifacts. Preserve a matched set and keep independent recovery copies. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Operate a browser interface for an existing Hermes deployment; agent sessions, terminals and underlying tools are separate from the dashboard. An idle editor or control plane does not represent build consumption. Match each workspace image and runtime, and isolate heavy compilation or nested-container jobs when required. The interface is separate from agent harnesses, compilers, tests and browser tools. Measure parallel workspaces and build peaks; repositories, dependency caches, image layers and generated artifacts need persistent and temporary space. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Hermes Control Interface hardware guide?
This guide was reviewed against the linked project deployment documentation on November 24, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Hermes Control Interface official setup / requirements
  2. Hermes Control Interface configuration / deployment
  3. Hermes Control Interface official repository and releases
  4. ZimaBoard 2 specifications
  5. Hermes Control Interface image source: public project material
