Hardwareanforderungen für Geo Monitor: RAM, CPU, Speicher & Datenaufnahme, Abfragen & Aufbewahrung
Planen Sie mit Geo Monitor RAM, CPU, persistenten Speicher und Service-Abhängigkeiten – mit auf Workloads abgestimmter ZimaOS-Dimensionierung, Backups und praktischer Hardwareauswahl.
Geo Monitor hardware requirements at a glance
Analyze crawler activity from web-server logs; ingestion volume, retention and reports determine database growth. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity.
The collector default limit is 128 MiB. This is a per-collector allocation, not the full dashboard/database requirement.
The collector default limit is 0.25 CPU, not a full-stack minimum.
Budget retained logs, database state and independent backups; log volume and retention determine growth.
Required services
Use the supported Geo Monitor runtime and complete upstream deployment topology. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The reviewed repository references SQLite; include each only where required by the selected mode, rather than assuming every reference is mandatory.
Main sizing variable
event ingestion, data retention, query scans, refresh frequency and dashboard concurrency
Practical Zima starting point
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Analyze crawler activity from web-server logs; ingestion volume, retention and reports determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity.
Plan the complete Geo Monitor workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported Geo Monitor runtime and complete upstream deployment topology. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The reviewed repository references SQLite; include each only where required by the selected mode, rather than assuming every reference is mandatory.
    Test a representative busy operation: event ingestion, data retention, query scans, refresh frequency and dashboard concurrency Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist events, metadata, analytical database/indexes, imported data and retained reports. Keep matching application state and recoverable copies outside the primary failure domain. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Analyze crawler activity from web-server logs; ingestion volume, retention and reports determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 23, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Geo Monitor official requirements
Analyze crawler activity from web-server logs; ingestion volume, retention and reports determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceThe collector default limit is 128 MiB. This is a per-collector allocation, not the full dashboard/database requirement.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceThe collector default limit is 0.25 CPU, not a full-stack minimum.Core counts do not predict a fixed user, device or document capacity.
Storage planningBudget retained logs, database state and independent backups; log volume and retention determine growth.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported Geo Monitor runtime and complete upstream deployment topology. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The reviewed repository references SQLite; include each only where required by the selected mode, rather than assuming every reference is mandatory.Include every stateful companion service in the host budget.
Persistent statePersist events, metadata, analytical database/indexes, imported data and retained reports. Keep matching application state and recoverable copies outside the primary failure domain.An image rebuild or container replacement is not a backup.
Deployment boundaryAnalyze crawler activity from web-server logs; ingestion volume, retention and reports determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity.Check the linked project instructions for the selected edition and release.
Use observed Geo Monitor workload pressure to decide when an upgrade is warranted.
event ingestion, data retention, query scans, refresh frequency and dashboard concurrency Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist events, metadata, analytical database/indexes, imported data and retained reports. Keep matching application state and recoverable copies outside the primary failure domain. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
Analyze crawler activity from web-server logs; ingestion volume, retention and reports determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review Geo Monitor deployment details ↗
Which Zima hardware fits Geo Monitor?
Which workload best matches your Geo Monitor deployment?
Conditional lab or supporting storage use only
  • Supporting hardware onlyZimaBoard 2 1664
ZimaBoard 2 1664 Conditional lab or supporting-service role event ingestion, data retention, query scans, refresh frequency and dashboard concurrency
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Analyze crawler activity from web-server logs; ingestion volume, retention and reports determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. Get Now
ZimaCube 2 Pro Conditional lab or supporting-service role Use the supported Geo Monitor runtime and complete upstream deployment topology. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The reviewed repository references SQLite; include each only where required by the selected mode, rather than assuming every reference is mandatory.
16 GB
10GbE plus 2.5GbE
Answers to Geo Monitor RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Geo Monitor?
The collector default limit is 128 MiB. This is a per-collector allocation, not the full dashboard/database requirement. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
The collector default limit is 0.25 CPU, not a full-stack minimum. The workload to test is: event ingestion, data retention, query scans, refresh frequency and dashboard concurrency
Persist events, metadata, analytical database/indexes, imported data and retained reports. Keep matching application state and recoverable copies outside the primary failure domain. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Analyze crawler activity from web-server logs; ingestion volume, retention and reports determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Geo Monitor hardware guide?
This guide was reviewed against the linked project deployment documentation on November 23, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Geo Monitor official setup / requirements
  2. Geo Monitor configuration / deployment
  3. Geo Monitor official repository and releases
  4. ZimaBoard 2 specifications
  5. Geo Monitor image source: public project material
