Garlic-Hub-Hardwareanforderungen: RAM, CPU, Speicher & Echtzeitmedien & Host-Geräte
Plane RAM, CPU, persistenten Speicher und Service-Abhängigkeiten für Garlic-Hub, mit einer auf die Workload abgestimmten Dimensionierung von ZimaOS, Backups und praxisnahen Hardware-Empfehlungen.
Garlic-Hub hardware requirements at a glance
Digital signage device and content management system with SMIL playlist support and scheduling. Size the complete deployment around resolution, frame rate, codec, concurrent streams and network latency/bandwidth. The hub manages signage content and clients; playback/decoding on signage players is separate. Budget media assets, distribution traffic and compatible player provisioning rather than treating hub RAM as display capability.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist streaming configuration, access state, optional recordings and media caches.
Required services
Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite, MariaDB / MySQL. These may include optional integrations or alternatives; install only the services required by the selected deployment.
Main sizing variable
Practical Zima starting point
Plan the complete Garlic-Hub workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite, MariaDB / MySQL. These may include optional integrations or alternatives; install only the services required by the selected deployment.
    Test a representative busy operation: resolution, frame rate, codec, concurrent streams and network latency/bandwidth Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist streaming configuration, access state, optional recordings and media caches. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    On ZimaOS, use a compatible amd64 container through Custom Install and reproduce all required services, volume mappings and device access. The hub manages signage content and clients; playback/decoding on signage players is separate. Budget media assets, distribution traffic and compatible player provisioning rather than treating hub RAM as display capability.
  • Realistic peak activity
Reviewed November 2, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Garlic-Hub official requirements
The hub manages signage content and clients; playback/decoding on signage players is separate. Budget media assets, distribution traffic and compatible player provisioning rather than treating hub RAM as display capability. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist streaming configuration, access state, optional recordings and media caches.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite, MariaDB / MySQL. These may include optional integrations or alternatives; install only the services required by the selected deployment.Include every stateful companion service in the host budget.
Persistent statePersist streaming configuration, access state, optional recordings and media caches.An image rebuild or container replacement is not a backup.
Deployment boundaryThe hub manages signage content and clients; playback/decoding on signage players is separate. Budget media assets, distribution traffic and compatible player provisioning rather than treating hub RAM as display capability.Check the linked project instructions for the selected edition and release.
Use observed Garlic-Hub workload pressure to decide when an upgrade is warranted.
resolution, frame rate, codec, concurrent streams and network latency/bandwidth Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist streaming configuration, access state, optional recordings and media caches. Track primary state and backup retention separately.
Use suitable active storage
ZimaBoard 2 832 or ZimaCube 2 Pro according to the measured constraint.
Fix the observed bottleneck
Custom install Garlic-Hub in ZimaOS
Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite, MariaDB / MySQL. These may include optional integrations or alternatives; install only the services required by the selected deployment. Persist: Persist streaming configuration, access state, optional recordings and media caches.
Custom install Garlic-Hub in the ZimaOS app ↗
Review Garlic-Hub deployment details ↗
Which Zima hardware fits Garlic-Hub?
Which workload best matches your Garlic-Hub deployment?
Modest Garlic-Hub deployment
ZimaBoard 2 832 Modest Garlic-Hub workload resolution, frame rate, codec, concurrent streams and network latency/bandwidth
ZimaCube 2 Pro More processing or shared-service headroom Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite, MariaDB / MySQL. These may include optional integrations or alternatives; install only the services required by the selected deployment.
16 GB
10GbE plus 2.5GbE
Answers to Garlic-Hub RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Garlic-Hub?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: resolution, frame rate, codec, concurrent streams and network latency/bandwidth
Persist streaming configuration, access state, optional recordings and media caches. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Accelerator needs depend on the selected inference, synthesis, browser or media backend. The hub manages signage content and clients; playback/decoding on signage players is separate. Budget media assets, distribution traffic and compatible player provisioning rather than treating hub RAM as display capability.
Can I deploy it on ZimaOS?
The hub manages signage content and clients; playback/decoding on signage players is separate. Budget media assets, distribution traffic and compatible player provisioning rather than treating hub RAM as display capability. Measure the same representative operation before and after a configuration or hardware change.
ZimaBoard 2 832 is the editorial starting point for this modest deployment. Choose ZimaCube 2 Pro for measured memory/processing pressure or broader shared services; retained data determines storage expansion.
What sources informed this Garlic-Hub hardware guide?
This guide was reviewed against the linked project deployment documentation on November 2, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Garlic-Hub official setup / requirements
  2. Garlic-Hub configuration / deployment
  3. Garlic-Hub official repository and releases
  4. ZimaBoard 2 specifications
  5. Garlic-Hub image source: public project material
