catalog size, checkout/billing bursts, scheduled integrations and concurrent workers Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Anforderungen an Hardware für Lebensmittelbestellungen: RAM, CPU, Speicher & Bestellungen, Kataloge & Hintergrundaufgaben
Planen Sie RAM, CPU, dauerhaften Speicher und Service-Abhängigkeiten für die Essensbestellung – mit einer an die Workload angepassten ZimaOS-Konfiguration, Backups und praktischen Hardware-Empfehlungen.
Food Ordering hardware requirements at a glance
Host a branded food-ordering website; catalog, order records, images and integrations determine application resources. Customers, orders/catalogs and background workflows need consistent data and file recovery. Payment, notification and blockchain providers are separate. Measure realistic imports and busy transactions rather than predicting capacity from registered accounts.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist catalog/billing database, transaction state, configuration, uploads and job history. Keep matching application state and recoverable copies outside the primary failure domain.
- Required services
- Use the supported Food Ordering runtime and complete upstream deployment topology. Customers, orders/catalogs and background workflows need consistent data and file recovery. Payment, notification and blockchain providers are separate. Measure realistic imports and busy transactions rather than predicting capacity from registered accounts.
- Main sizing variable
- catalog size, checkout/billing bursts, scheduled integrations and concurrent workers
- Practical Zima starting point
- ZimaBoard 2 832 with SSD-backed active state is an editorial starting point for modest use. Include the OS and all companion services; it is not a measured capacity guarantee.
Plan the complete Food Ordering workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the supported Food Ordering runtime and complete upstream deployment topology. Customers, orders/catalogs and background workflows need consistent data and file recovery. Payment, notification and blockchain providers are separate. Measure realistic imports and busy transactions rather than predicting capacity from registered accounts.
Confirm your needs
Test a representative busy operation: catalog size, checkout/billing bursts, scheduled integrations and concurrent workers Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist catalog/billing database, transaction state, configuration, uploads and job history. Keep matching application state and recoverable copies outside the primary failure domain. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Host a branded food-ordering website; catalog, order records, images and integrations determine application resources. An application host is not a payment provider. Size external databases, queues and integrations separately; test representative orders or billing runs and preserve consistent transaction records. Customers, orders/catalogs and background workflows need consistent data and file recovery. Payment, notification and blockchain providers are separate. Measure realistic imports and busy transactions rather than predicting capacity from registered accounts.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 23, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Host a branded food-ordering website; catalog, order records, images and integrations determine application resources. An application host is not a payment provider. Size external databases, queues and integrations separately; test representative orders or billing runs and preserve consistent transaction records. Customers, orders/catalogs and background workflows need consistent data and file recovery. Payment, notification and blockchain providers are separate. Measure realistic imports and busy transactions rather than predicting capacity from registered accounts. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist catalog/billing database, transaction state, configuration, uploads and job history. Keep matching application state and recoverable copies outside the primary failure domain. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the supported Food Ordering runtime and complete upstream deployment topology. Customers, orders/catalogs and background workflows need consistent data and file recovery. Payment, notification and blockchain providers are separate. Measure realistic imports and busy transactions rather than predicting capacity from registered accounts. | Include every stateful companion service in the host budget. |
| Persistent state | Persist catalog/billing database, transaction state, configuration, uploads and job history. Keep matching application state and recoverable copies outside the primary failure domain. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Host a branded food-ordering website; catalog, order records, images and integrations determine application resources. An application host is not a payment provider. Size external databases, queues and integrations separately; test representative orders or billing runs and preserve consistent transaction records. Customers, orders/catalogs and background workflows need consistent data and file recovery. Payment, notification and blockchain providers are separate. Measure realistic imports and busy transactions rather than predicting capacity from registered accounts. | Check the linked project instructions for the selected edition and release. |
Use observed Food Ordering workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist catalog/billing database, transaction state, configuration, uploads and job history. Keep matching application state and recoverable copies outside the primary failure domain. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 832 or ZimaBoard 2 1664 according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
Host a branded food-ordering website; catalog, order records, images and integrations determine application resources. An application host is not a payment provider. Size external databases, queues and integrations separately; test representative orders or billing runs and preserve consistent transaction records. Customers, orders/catalogs and background workflows need consistent data and file recovery. Payment, notification and blockchain providers are separate. Measure realistic imports and busy transactions rather than predicting capacity from registered accounts. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official Food Ordering deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review Food Ordering official installation ↗Check workload-specific deployment details
Review Food Ordering deployment details ↗Which Zima hardware fits Food Ordering?
Which workload best matches your Food Ordering deployment?
- Workload optionZimaBoard 2 832
- Workload optionZimaBoard 2 1664
| ZimaBoard 2 832 | Modest Food Ordering workload | catalog size, checkout/billing bursts, scheduled integrations and concurrent workers |
This is an editorial host choice, not an official app minimum or a guaranteed user/device capacity. | Get Now |
| ZimaBoard 2 1664 | More processing or shared-service headroom | Use the supported Food Ordering runtime and complete upstream deployment topology. Customers, orders/catalogs and background workflows need consistent data and file recovery. Payment, notification and blockchain providers are separate. Measure realistic imports and busy transactions rather than predicting capacity from registered accounts. |
Size the combined stack and active working set; more RAM does not fix remote API limits or missing dependencies. | Get Now |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to Food Ordering RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Food Ordering?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: catalog size, checkout/billing bursts, scheduled integrations and concurrent workers
Persist catalog/billing database, transaction state, configuration, uploads and job history. Keep matching application state and recoverable copies outside the primary failure domain. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Host a branded food-ordering website; catalog, order records, images and integrations determine application resources. An application host is not a payment provider. Size external databases, queues and integrations separately; test representative orders or billing runs and preserve consistent transaction records. Customers, orders/catalogs and background workflows need consistent data and file recovery. Payment, notification and blockchain providers are separate. Measure realistic imports and busy transactions rather than predicting capacity from registered accounts. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Food Ordering hardware guide?
This guide was reviewed against the linked project deployment documentation on November 23, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
