EinVault-Hardwareanforderungen: RAM, CPU, Speicher und Datenbank, Importe und Hintergrundjobs
Planen Sie RAM, CPU, persistenten Speicher und Service-Abhängigkeiten für EinVault mit einer an den Workloads ausgerichteten Dimensionierung von ZimaOS, Backups und praxisgerechter Hardware-Auswahl.
EinVault hardware requirements at a glance
Track pet care and health records; attachments, reminders, sensor imports where supported and backups determine application resources. Retain actual records, relationships and attached evidence. Discovery, imports and optional polling have separate peaks, while managed cloud or physical resources remain independently provisioned.
The supplied service has a 256 MB container memory limit. It is an allocation, not a measured host minimum, and may need increasing for video processing.
The supplied service has a 0.5-core limit, with more advised for video transcoding. This does not size the whole host.
The supplied configuration uses a 64 MB temporary filesystem. Retained care records, media, database state and backups require separate persistent storage.
Required services
Use the supported EinVault runtime and full upstream deployment topology. Retain actual records, relationships and attached evidence. Discovery, imports and optional polling have separate peaks, while managed cloud or physical resources remain independently provisioned. The reviewed repository references SQLite, S3-compatible object storage; include each only when required by the chosen mode, not simply because the name appears in the repository.
Main sizing variable
bulk imports, API traffic, background jobs, custom plugins and database size
Practical Zima starting point
Plan the complete EinVault workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported EinVault runtime and full upstream deployment topology. Retain actual records, relationships and attached evidence. Discovery, imports and optional polling have separate peaks, while managed cloud or physical resources remain independently provisioned. The reviewed repository references SQLite, S3-compatible object storage; include each only when required by the chosen mode, not simply because the name appears in the repository.
    Test a representative busy operation: bulk imports, API traffic, background jobs, custom plugins and database size Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist infrastructure records, media/configuration, database, jobs and plugin state. Preserve a matched set and keep independent recovery copies. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Track pet care and health records; attachments, reminders, sensor imports where supported and backups determine application resources. The web service is only one part of the stack. Include the release-matched database, cache/queue and workers; plugins and automation jobs can change the resource profile substantially. Retain actual records, relationships and attached evidence. Discovery, imports and optional polling have separate peaks, while managed cloud or physical resources remain independently provisioned.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 24, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review EinVault official requirements
Track pet care and health records; attachments, reminders, sensor imports where supported and backups determine application resources. The web service is only one part of the stack. Include the release-matched database, cache/queue and workers; plugins and automation jobs can change the resource profile substantially. Retain actual records, relationships and attached evidence. Discovery, imports and optional polling have separate peaks, while managed cloud or physical resources remain independently provisioned. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceThe supplied service has a 256 MB container memory limit. It is an allocation, not a measured host minimum, and may need increasing for video processing.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceThe supplied service has a 0.5-core limit, with more advised for video transcoding. This does not size the whole host.Core counts do not predict a fixed user, device or document capacity.
Storage planningThe supplied configuration uses a 64 MB temporary filesystem. Retained care records, media, database state and backups require separate persistent storage.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported EinVault runtime and full upstream deployment topology. Retain actual records, relationships and attached evidence. Discovery, imports and optional polling have separate peaks, while managed cloud or physical resources remain independently provisioned. The reviewed repository references SQLite, S3-compatible object storage; include each only when required by the chosen mode, not simply because the name appears in the repository.Include every stateful companion service in the host budget.
Persistent statePersist infrastructure records, media/configuration, database, jobs and plugin state. Preserve a matched set and keep independent recovery copies.An image rebuild or container replacement is not a backup.
Deployment boundaryTrack pet care and health records; attachments, reminders, sensor imports where supported and backups determine application resources. The web service is only one part of the stack. Include the release-matched database, cache/queue and workers; plugins and automation jobs can change the resource profile substantially. Retain actual records, relationships and attached evidence. Discovery, imports and optional polling have separate peaks, while managed cloud or physical resources remain independently provisioned.Check the linked project instructions for the selected edition and release.
Use observed EinVault workload pressure to decide when an upgrade is warranted.
bulk imports, API traffic, background jobs, custom plugins and database size Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist infrastructure records, media/configuration, database, jobs and plugin state. Preserve a matched set and keep independent recovery copies. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
Track pet care and health records; attachments, reminders, sensor imports where supported and backups determine application resources. The web service is only one part of the stack. Include the release-matched database, cache/queue and workers; plugins and automation jobs can change the resource profile substantially. Retain actual records, relationships and attached evidence. Discovery, imports and optional polling have separate peaks, while managed cloud or physical resources remain independently provisioned. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review EinVault deployment details ↗
Which Zima hardware fits EinVault?
Which workload best matches your EinVault deployment?
Modest EinVault deployment
ZimaBoard 2 1664 Modest EinVault workload bulk imports, API traffic, background jobs, custom plugins and database size
ZimaCube 2 Pro More processing or shared-service headroom Use the supported EinVault runtime and full upstream deployment topology. Retain actual records, relationships and attached evidence. Discovery, imports and optional polling have separate peaks, while managed cloud or physical resources remain independently provisioned. The reviewed repository references SQLite, S3-compatible object storage; include each only when required by the chosen mode, not simply because the name appears in the repository.
16 GB
10GbE plus 2.5GbE
Answers to EinVault RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for EinVault?
The supplied service has a 256 MB container memory limit. It is an allocation, not a measured host minimum, and may need increasing for video processing. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
The supplied service has a 0.5-core limit, with more advised for video transcoding. This does not size the whole host. The workload to test is: bulk imports, API traffic, background jobs, custom plugins and database size
Persist infrastructure records, media/configuration, database, jobs and plugin state. Preserve a matched set and keep independent recovery copies. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Track pet care and health records; attachments, reminders, sensor imports where supported and backups determine application resources. The web service is only one part of the stack. Include the release-matched database, cache/queue and workers; plugins and automation jobs can change the resource profile substantially. Retain actual records, relationships and attached evidence. Discovery, imports and optional polling have separate peaks, while managed cloud or physical resources remain independently provisioned. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this EinVault hardware guide?
This guide was reviewed against the linked project deployment documentation on November 24, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. EinVault official setup / requirements
  2. EinVault configuration / deployment
  3. EinVault official repository and releases
  4. ZimaBoard 2 specifications
  5. EinVault image source: public project material
