message throughput, mailbox retention, spam/antivirus processing and simultaneous clients Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Cypht-Hardwareanforderungen: RAM, CPU, Speicherplatz & Aufbewahrung und Filterung von Postfächern
Planen Sie RAM, CPU, persistenten Speicher und Dienstabhängigkeiten für Cypht mit einer workloadbasierten ZimaOS-Dimensionierung, Backups und praktischen Hardwareempfehlungen.
Cypht hardware requirements at a glance
Feed reader for your email accounts. This is a webmail client/aggregator that connects to existing accounts, not a full SMTP/IMAP mailbox server. Size the PHP application, session/configuration state and configured caching separately from remote mail storage.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist mailboxes, queue, domains, credentials, keys, aliases and filtering state.
- Required services
- Use the supported upstream runtime and complete service topology for the selected release.
- Main sizing variable
- message throughput, mailbox retention, spam/antivirus processing and simultaneous clients
- Practical Zima starting point
- ZimaBoard 2 832 with SSD-backed active state is an editorial starting point for modest use. Include the OS and all companion services; it is not a measured capacity guarantee.
Plan the complete Cypht workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the supported upstream runtime and complete service topology for the selected release.
Confirm your needs
Test a representative busy operation: message throughput, mailbox retention, spam/antivirus processing and simultaneous clients Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist mailboxes, queue, domains, credentials, keys, aliases and filtering state. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. This is a webmail client/aggregator that connects to existing accounts, not a full SMTP/IMAP mailbox server. Size the PHP application, session/configuration state and configured caching separately from remote mail storage.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 2, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
This is a webmail client/aggregator that connects to existing accounts, not a full SMTP/IMAP mailbox server. Size the PHP application, session/configuration state and configured caching separately from remote mail storage. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist mailboxes, queue, domains, credentials, keys, aliases and filtering state. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the supported upstream runtime and complete service topology for the selected release. | Include every stateful companion service in the host budget. |
| Persistent state | Persist mailboxes, queue, domains, credentials, keys, aliases and filtering state. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | This is a webmail client/aggregator that connects to existing accounts, not a full SMTP/IMAP mailbox server. Size the PHP application, session/configuration state and configured caching separately from remote mail storage. | Check the linked project instructions for the selected edition and release. |
Use observed Cypht workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist mailboxes, queue, domains, credentials, keys, aliases and filtering state. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 832 or ZimaBoard 2 1664 according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
This is a webmail client/aggregator that connects to existing accounts, not a full SMTP/IMAP mailbox server. Size the PHP application, session/configuration state and configured caching separately from remote mail storage. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official Cypht deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review Cypht official installation ↗Check workload-specific deployment details
Review Cypht deployment details ↗Which Zima hardware fits Cypht?
Which workload best matches your Cypht deployment?
- Workload optionZimaBoard 2 832
- Workload optionZimaBoard 2 1664
| ZimaBoard 2 832 | Modest Cypht workload | message throughput, mailbox retention, spam/antivirus processing and simultaneous clients |
This is an editorial host choice, not an official app minimum or a guaranteed user/device capacity. | Get Now |
| ZimaBoard 2 1664 | More processing or shared-service headroom | Use the supported upstream runtime and complete service topology for the selected release. |
Size the combined stack and active working set; more RAM does not fix remote API limits or missing dependencies. | Get Now |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to Cypht RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Cypht?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: message throughput, mailbox retention, spam/antivirus processing and simultaneous clients
Persist mailboxes, queue, domains, credentials, keys, aliases and filtering state. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
This is a webmail client/aggregator that connects to existing accounts, not a full SMTP/IMAP mailbox server. Size the PHP application, session/configuration state and configured caching separately from remote mail storage. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Cypht hardware guide?
This guide was reviewed against the linked project deployment documentation on November 2, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
