Hardwareanforderungen für Container Census: RAM, CPU, Speicherplatz & Prüfungen, Agents & Verlauf
Planen Sie RAM, CPU, persistenten Speicher und Dienstabhängigkeiten Ihrer Container, mit einer workloadbasierten Dimensionierung von ZimaOS, Backups und praktischen Hardwareempfehlungen.
Container Census hardware requirements at a glance
Collect Docker container inventories and reports; collection cadence, host count and retained observations determine local resources. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist check definitions, credentials, agent/host mappings and configured historical records. Preserve a matched set and keep independent recovery copies.
Required services
Use the supported Container Census runtime and full upstream deployment topology. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. The reviewed repository references PostgreSQL, SQLite; include each only when required by the chosen mode, not simply because the name appears in the repository.
Main sizing variable
check count, interval, timeouts, network discovery and retained history
Practical Zima starting point
Plan the complete Container Census workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported Container Census runtime and full upstream deployment topology. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. The reviewed repository references PostgreSQL, SQLite; include each only when required by the chosen mode, not simply because the name appears in the repository.
    Test a representative busy operation: check count, interval, timeouts, network discovery and retained history Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist check definitions, credentials, agent/host mappings and configured historical records. Preserve a matched set and keep independent recovery copies. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Collect Docker container inventories and reports; collection cadence, host count and retained observations determine local resources. Many monitoring apps need host sockets, agents, network discovery or device access. Expose only required privileges and include the execution cost of plugins or polling on monitored hosts. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 24, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Container Census official requirements
Collect Docker container inventories and reports; collection cadence, host count and retained observations determine local resources. Many monitoring apps need host sockets, agents, network discovery or device access. Expose only required privileges and include the execution cost of plugins or polling on monitored hosts. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist check definitions, credentials, agent/host mappings and configured historical records. Preserve a matched set and keep independent recovery copies.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported Container Census runtime and full upstream deployment topology. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. The reviewed repository references PostgreSQL, SQLite; include each only when required by the chosen mode, not simply because the name appears in the repository.Include every stateful companion service in the host budget.
Persistent statePersist check definitions, credentials, agent/host mappings and configured historical records. Preserve a matched set and keep independent recovery copies.An image rebuild or container replacement is not a backup.
Deployment boundaryCollect Docker container inventories and reports; collection cadence, host count and retained observations determine local resources. Many monitoring apps need host sockets, agents, network discovery or device access. Expose only required privileges and include the execution cost of plugins or polling on monitored hosts. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes.Check the linked project instructions for the selected edition and release.
Use observed Container Census workload pressure to decide when an upgrade is warranted.
check count, interval, timeouts, network discovery and retained history Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist check definitions, credentials, agent/host mappings and configured historical records. Preserve a matched set and keep independent recovery copies. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
Collect Docker container inventories and reports; collection cadence, host count and retained observations determine local resources. Many monitoring apps need host sockets, agents, network discovery or device access. Expose only required privileges and include the execution cost of plugins or polling on monitored hosts. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review Container Census deployment details ↗
Which Zima hardware fits Container Census?
Which workload best matches your Container Census deployment?
Modest Container Census deployment
ZimaBoard 2 832 Modest Container Census workload check count, interval, timeouts, network discovery and retained history
ZimaBoard 2 1664 More processing or shared-service headroom Use the supported Container Census runtime and full upstream deployment topology. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. The reviewed repository references PostgreSQL, SQLite; include each only when required by the chosen mode, not simply because the name appears in the repository.
Answers to Container Census RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Container Census?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: check count, interval, timeouts, network discovery and retained history
Persist check definitions, credentials, agent/host mappings and configured historical records. Preserve a matched set and keep independent recovery copies. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Collect Docker container inventories and reports; collection cadence, host count and retained observations determine local resources. Many monitoring apps need host sockets, agents, network discovery or device access. Expose only required privileges and include the execution cost of plugins or polling on monitored hosts. Polling interval, targets, retained history and enabled actions drive use. Verify actual sockets, remote access and network visibility. The monitoring host does not supply the resources of the devices it observes. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Container Census hardware guide?
This guide was reviewed against the linked project deployment documentation on November 24, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Container Census official setup / requirements
  2. Container Census configuration / deployment
  3. Container Census official repository and releases
  4. ZimaBoard 2 specifications
  5. Container Census image source: public project material
