event ingestion, data retention, query scans, refresh frequency and dashboard concurrency Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Betterlytics-Hardwareanforderungen: RAM, CPU, Speicher und Datenerfassung, Abfragen und Aufbewahrung
Plane den RAM-, CPU- und persistenten Speicherbedarf sowie die Dienstabhängigkeiten für Betterlytics – mit einer auf die Workload abgestimmten Dimensionierung von ZimaOS, Backups und praktischen Hardware-Empfehlungen.
Betterlytics hardware requirements at a glance
Website events, replays, errors and retained performance reports. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist events, metadata, analytical database/indexes, imported data and retained reports.
- Required services
- Use the documented Betterlytics runtime and selected service topology. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. Upstream references include PostgreSQL, ClickHouse. Verify which apply to your selected mode; a mention is not a mandatory dependency.
- Main sizing variable
- event ingestion, data retention, query scans, refresh frequency and dashboard concurrency
- Practical Zima starting point
- Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Website events, replays, errors and retained performance reports. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity.
Plan the complete Betterlytics workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the documented Betterlytics runtime and selected service topology. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. Upstream references include PostgreSQL, ClickHouse. Verify which apply to your selected mode; a mention is not a mandatory dependency.
Confirm your needs
Test a representative busy operation: event ingestion, data retention, query scans, refresh frequency and dashboard concurrency Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist events, metadata, analytical database/indexes, imported data and retained reports. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Website events, replays, errors and retained performance reports. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 20, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Website events, replays, errors and retained performance reports. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist events, metadata, analytical database/indexes, imported data and retained reports. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the documented Betterlytics runtime and selected service topology. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. Upstream references include PostgreSQL, ClickHouse. Verify which apply to your selected mode; a mention is not a mandatory dependency. | Include every stateful companion service in the host budget. |
| Persistent state | Persist events, metadata, analytical database/indexes, imported data and retained reports. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Website events, replays, errors and retained performance reports. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. | Check the linked project instructions for the selected edition and release. |
Use observed Betterlytics workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist events, metadata, analytical database/indexes, imported data and retained reports. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 1664 or ZimaCube 2 Pro according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
Website events, replays, errors and retained performance reports. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official Betterlytics deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review Betterlytics official installation ↗Check workload-specific deployment details
Review Betterlytics deployment details ↗Which Zima hardware fits Betterlytics?
Which workload best matches your Betterlytics deployment?
- Supporting hardware onlyZimaBoard 2 1664
| ZimaBoard 2 1664 | Conditional lab or supporting-service role | event ingestion, data retention, query scans, refresh frequency and dashboard concurrency |
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Website events, replays, errors and retained performance reports. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. | Get Now |
| ZimaCube 2 Pro | Conditional lab or supporting-service role | Use the documented Betterlytics runtime and selected service topology. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. Upstream references include PostgreSQL, ClickHouse. Verify which apply to your selected mode; a mention is not a mandatory dependency. |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to Betterlytics RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Betterlytics?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: event ingestion, data retention, query scans, refresh frequency and dashboard concurrency
Persist events, metadata, analytical database/indexes, imported data and retained reports. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Website events, replays, errors and retained performance reports. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Betterlytics hardware guide?
This guide was reviewed against the linked project deployment documentation on November 20, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
