BetterDB Monitor-Hardwareanforderungen: RAM, CPU, Speicherplatz & Trace-Volumen und Aufbewahrungsdauer
Planen Sie besser mit BetterDB: Überwachen Sie RAM, CPU, dauerhaften Speicher und Dienstabhängigkeiten, und wählen Sie anhand der Workload-Größe das passende ZimaOS, Backups und praktische Hardware.
BetterDB Monitor hardware requirements at a glance
BetterDB Monitor is a monitoring dashboard for Valkey, Redis and Dragonfly that persists slowlogs, command patterns and client activity for historical debugging, exports Prometheus metrics and OTLP telemetry, and detects anomalies in real time. Observability storage is separate from the models being observed. Size the documented database/analytical/object-store stack and limit retention; evaluation model calls can run elsewhere.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist traces, events, evaluations, datasets, artifact/object storage and metadata database.
Required services
Use the supported upstream runtime and complete service topology for the selected release. The repository references PostgreSQL, SQLite, Redis / Valkey. These may be optional integrations or alternatives; install only services required by your chosen deployment.
Main sizing variable
events per second, payload size, retention, background evaluations and query concurrency
Practical Zima starting point
Plan the complete BetterDB Monitor workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported upstream runtime and complete service topology for the selected release. The repository references PostgreSQL, SQLite, Redis / Valkey. These may be optional integrations or alternatives; install only services required by your chosen deployment.
    Test a representative busy operation: events per second, payload size, retention, background evaluations and query concurrency Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist traces, events, evaluations, datasets, artifact/object storage and metadata database. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Observability storage is separate from the models being observed. Size the documented database/analytical/object-store stack and limit retention; evaluation model calls can run elsewhere.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 4, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review BetterDB Monitor official requirements
Observability storage is separate from the models being observed. Size the documented database/analytical/object-store stack and limit retention; evaluation model calls can run elsewhere. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist traces, events, evaluations, datasets, artifact/object storage and metadata database.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported upstream runtime and complete service topology for the selected release. The repository references PostgreSQL, SQLite, Redis / Valkey. These may be optional integrations or alternatives; install only services required by your chosen deployment.Include every stateful companion service in the host budget.
Persistent statePersist traces, events, evaluations, datasets, artifact/object storage and metadata database.An image rebuild or container replacement is not a backup.
Deployment boundaryObservability storage is separate from the models being observed. Size the documented database/analytical/object-store stack and limit retention; evaluation model calls can run elsewhere.Check the linked project instructions for the selected edition and release.
Use observed BetterDB Monitor workload pressure to decide when an upgrade is warranted.
events per second, payload size, retention, background evaluations and query concurrency Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist traces, events, evaluations, datasets, artifact/object storage and metadata database. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
Observability storage is separate from the models being observed. Size the documented database/analytical/object-store stack and limit retention; evaluation model calls can run elsewhere. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review BetterDB Monitor deployment details ↗
Which Zima hardware fits BetterDB Monitor?
Which workload best matches your BetterDB Monitor deployment?
Modest BetterDB Monitor deployment
ZimaBoard 2 1664 Modest BetterDB Monitor workload events per second, payload size, retention, background evaluations and query concurrency
ZimaCube 2 Pro More processing or shared-service headroom Use the supported upstream runtime and complete service topology for the selected release. The repository references PostgreSQL, SQLite, Redis / Valkey. These may be optional integrations or alternatives; install only services required by your chosen deployment.
16 GB
10GbE plus 2.5GbE
Answers to BetterDB Monitor RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for BetterDB Monitor?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: events per second, payload size, retention, background evaluations and query concurrency
Persist traces, events, evaluations, datasets, artifact/object storage and metadata database. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Observability storage is separate from the models being observed. Size the documented database/analytical/object-store stack and limit retention; evaluation model calls can run elsewhere. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this BetterDB Monitor hardware guide?
This guide was reviewed against the linked project deployment documentation on November 4, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. BetterDB Monitor official setup / requirements
  2. BetterDB Monitor configuration / deployment
  3. BetterDB Monitor official repository and releases
  4. ZimaBoard 2 specifications
  5. BetterDB Monitor image source: public project material
