event volume, number of active agents, enabled rules, inspection work and retention. Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Beelzebub-Hardwareanforderungen: RAM, CPU, Speicher & Ereigniserfassung & Erkennung
Plane RAM, CPU, persistenten Speicher und Service-Abhängigkeiten für Beelzebub – mit workloadbasierter Dimensionierung von ZimaOS, Backups und praktischen Hardware-Empfehlungen.
beelzebub hardware requirements at a glance
beelzebub supports honeypot listeners, configured protocol emulation and event forwarding. Size the complete deployment around event volume, number of active agents, enabled rules, inspection work and retention. Honeypot protocol emulation, logging and optional AI integrations have different demands. Follow the selected module and listener prerequisites on an isolated suitable environment; do not expose unnecessary production NAS privileges.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist security rules, enrolled-agent state, event indexes, retained logs and dashboard/configuration data as used by the selected deployment.
- Required services
- Use the service topology in the linked primary deployment source for your selected edition and release; include all required persistence, worker and runtime services. The source references PostgreSQL, Redis / Valkey, MariaDB / MySQL. These can be integrations or alternative backends; this list does not require all of them to be installed together.
- Main sizing variable
- event volume, number of active agents, enabled rules, inspection work and retention.
- Practical Zima starting point
- ZimaBoard 2 1664 with SSD-backed active state is an editorial starting point for modest use. Include the OS and all companion services; it is not a measured capacity guarantee.
Plan the complete beelzebub workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the service topology in the linked primary deployment source for your selected edition and release; include all required persistence, worker and runtime services. The source references PostgreSQL, Redis / Valkey, MariaDB / MySQL. These can be integrations or alternative backends; this list does not require all of them to be installed together.
Confirm your needs
Test a representative busy operation: event volume, number of active agents, enabled rules, inspection work and retention. Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist security rules, enrolled-agent state, event indexes, retained logs and dashboard/configuration data as used by the selected deployment. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
On ZimaOS, use a compatible amd64 container through Custom Install and reproduce all required services, volume mappings and device access. Honeypot protocol emulation, logging and optional AI integrations have different demands. Follow the selected module and listener prerequisites on an isolated suitable environment; do not expose unnecessary production NAS privileges.
- Exact edition and stable release
- Compatible amd64 image/runtime
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 2, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Honeypot protocol emulation, logging and optional AI integrations have different demands. Follow the selected module and listener prerequisites on an isolated suitable environment; do not expose unnecessary production NAS privileges. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist security rules, enrolled-agent state, event indexes, retained logs and dashboard/configuration data as used by the selected deployment. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the service topology in the linked primary deployment source for your selected edition and release; include all required persistence, worker and runtime services. The source references PostgreSQL, Redis / Valkey, MariaDB / MySQL. These can be integrations or alternative backends; this list does not require all of them to be installed together. | Include every stateful companion service in the host budget. |
| Persistent state | Persist security rules, enrolled-agent state, event indexes, retained logs and dashboard/configuration data as used by the selected deployment. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Honeypot protocol emulation, logging and optional AI integrations have different demands. Follow the selected module and listener prerequisites on an isolated suitable environment; do not expose unnecessary production NAS privileges. | Check the linked project instructions for the selected edition and release. |
Use observed beelzebub workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist security rules, enrolled-agent state, event indexes, retained logs and dashboard/configuration data as used by the selected deployment. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 1664 or ZimaCube 2 Pro according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported beelzebub deployment first
Review supported upstream deployment ↗Use the official beelzebub deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review beelzebub official installation ↗Check workload-specific deployment details
Review beelzebub deployment details ↗Which Zima hardware fits beelzebub?
Which workload best matches your beelzebub deployment?
- Workload optionZimaBoard 2 1664
- Workload optionZimaCube 2 Pro
| ZimaBoard 2 1664 | Modest beelzebub workload | event volume, number of active agents, enabled rules, inspection work and retention. |
This is an editorial host choice, not an official app minimum or a guaranteed user/device capacity. | Get Now |
| ZimaCube 2 Pro | More processing or shared-service headroom | Use the service topology in the linked primary deployment source for your selected edition and release; include all required persistence, worker and runtime services. The source references PostgreSQL, Redis / Valkey, MariaDB / MySQL. These can be integrations or alternative backends; this list does not require all of them to be installed together. |
Size the combined stack and active working set; more RAM does not fix remote API limits or missing dependencies. | Get Now |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to beelzebub RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for beelzebub?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: event volume, number of active agents, enabled rules, inspection work and retention.
Persist security rules, enrolled-agent state, event indexes, retained logs and dashboard/configuration data as used by the selected deployment. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Honeypot protocol emulation, logging and optional AI integrations have different demands. Follow the selected module and listener prerequisites on an isolated suitable environment; do not expose unnecessary production NAS privileges. Do not assume a generic ZimaOS custom-container install meets these prerequisites.
Honeypot protocol emulation, logging and optional AI integrations have different demands. Follow the selected module and listener prerequisites on an isolated suitable environment; do not expose unnecessary production NAS privileges. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this beelzebub hardware guide?
This guide was reviewed against the linked project deployment documentation on November 2, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
