auto-mcs-Hardwareanforderungen: RAM, CPU, Speicher und Authentifizierung und dauerhafter Status
Planen Sie RAM, CPU, persistenten Speicher und Dienstabhängigkeiten für Auto-MCS – mit einer ZimaOS-Dimensionierung nach Workload, Backups und praktischen Hardware-Empfehlungen.
auto-mcs hardware requirements at a glance
Cross-platform Minecraft server manager. Authentication throughput depends on hashing and policy work rather than registered-user count alone. Preserve encryption/signing keys with the database and plan a recovery path before dependent apps rely on it.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist identity/directory database, secrets, signing keys, certificates, policy and audit state.
Required services
Use the supported upstream runtime and complete service topology for the selected release.
Main sizing variable
login bursts, password hashing, directory sync, tokens and active access sessions
Practical Zima starting point
Plan the complete auto-mcs workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported upstream runtime and complete service topology for the selected release.
    Test a representative busy operation: login bursts, password hashing, directory sync, tokens and active access sessions Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist identity/directory database, secrets, signing keys, certificates, policy and audit state. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Authentication throughput depends on hashing and policy work rather than registered-user count alone. Preserve encryption/signing keys with the database and plan a recovery path before dependent apps rely on it.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 4, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review auto-mcs official requirements
Authentication throughput depends on hashing and policy work rather than registered-user count alone. Preserve encryption/signing keys with the database and plan a recovery path before dependent apps rely on it. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist identity/directory database, secrets, signing keys, certificates, policy and audit state.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported upstream runtime and complete service topology for the selected release.Include every stateful companion service in the host budget.
Persistent statePersist identity/directory database, secrets, signing keys, certificates, policy and audit state.An image rebuild or container replacement is not a backup.
Deployment boundaryAuthentication throughput depends on hashing and policy work rather than registered-user count alone. Preserve encryption/signing keys with the database and plan a recovery path before dependent apps rely on it.Check the linked project instructions for the selected edition and release.
Use observed auto-mcs workload pressure to decide when an upgrade is warranted.
login bursts, password hashing, directory sync, tokens and active access sessions Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist identity/directory database, secrets, signing keys, certificates, policy and audit state. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
Authentication throughput depends on hashing and policy work rather than registered-user count alone. Preserve encryption/signing keys with the database and plan a recovery path before dependent apps rely on it. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review auto-mcs deployment details ↗
Which Zima hardware fits auto-mcs?
Which workload best matches your auto-mcs deployment?
Modest auto-mcs deployment
ZimaBoard 2 832 Modest auto-mcs workload login bursts, password hashing, directory sync, tokens and active access sessions
ZimaBoard 2 1664 More processing or shared-service headroom Use the supported upstream runtime and complete service topology for the selected release.
Answers to auto-mcs RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for auto-mcs?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: login bursts, password hashing, directory sync, tokens and active access sessions
Persist identity/directory database, secrets, signing keys, certificates, policy and audit state. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Authentication throughput depends on hashing and policy work rather than registered-user count alone. Preserve encryption/signing keys with the database and plan a recovery path before dependent apps rely on it. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this auto-mcs hardware guide?
This guide was reviewed against the linked project deployment documentation on November 4, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. auto-mcs official setup / requirements
  2. auto-mcs configuration / deployment
  3. auto-mcs official repository and releases
  4. ZimaBoard 2 specifications
  5. auto-mcs image source: public project or official store material
