Hardwareanforderungen: RAM, CPU, Speicher und Geschäftsunterlagen und Hintergrundprozesse
Planen Sie RAM, CPU, persistenten Speicher und Service-Abhängigkeiten mit einer workloadbasierten Dimensionierung für ZimaOS, Backups und praktischen Hardware-Empfehlungen.
Assets hardware requirements at a glance
Personal net worth and investment tracker. Size the complete deployment around active modules, simultaneous transactions, reports, imports and background jobs. Different business modules have different worker and database costs. Protect consistent database/attachment backups and time realistic reports rather than sizing only logins.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist business database, uploaded documents, attachments, configuration and scheduled-job state.
Required services
Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite. These may include optional integrations or alternatives; install only the services required by the selected deployment.
Main sizing variable
Practical Zima starting point
Plan the complete Assets workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite. These may include optional integrations or alternatives; install only the services required by the selected deployment.
    Test a representative busy operation: active modules, simultaneous transactions, reports, imports and background jobs Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist business database, uploaded documents, attachments, configuration and scheduled-job state. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    On ZimaOS, use a compatible amd64 container through Custom Install and reproduce all required services, volume mappings and device access. Different business modules have different worker and database costs. Protect consistent database/attachment backups and time realistic reports rather than sizing only logins.
  • Realistic peak activity
Reviewed November 2, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Assets official requirements
Different business modules have different worker and database costs. Protect consistent database/attachment backups and time realistic reports rather than sizing only logins. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist business database, uploaded documents, attachments, configuration and scheduled-job state.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite. These may include optional integrations or alternatives; install only the services required by the selected deployment.Include every stateful companion service in the host budget.
Persistent statePersist business database, uploaded documents, attachments, configuration and scheduled-job state.An image rebuild or container replacement is not a backup.
Deployment boundaryDifferent business modules have different worker and database costs. Protect consistent database/attachment backups and time realistic reports rather than sizing only logins.Check the linked project instructions for the selected edition and release.
Use observed Assets workload pressure to decide when an upgrade is warranted.
active modules, simultaneous transactions, reports, imports and background jobs Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist business database, uploaded documents, attachments, configuration and scheduled-job state. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Custom install Assets in ZimaOS
Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite. These may include optional integrations or alternatives; install only the services required by the selected deployment. Persist: Persist business database, uploaded documents, attachments, configuration and scheduled-job state.
Custom install Assets in the ZimaOS app ↗
Review Assets deployment details ↗
Which Zima hardware fits Assets?
Which workload best matches your Assets deployment?
Modest Assets deployment
ZimaBoard 2 1664 Modest Assets workload active modules, simultaneous transactions, reports, imports and background jobs
ZimaCube 2 Pro More processing or shared-service headroom Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite. These may include optional integrations or alternatives; install only the services required by the selected deployment.
16 GB
10GbE plus 2.5GbE
Answers to Assets RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Assets?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: active modules, simultaneous transactions, reports, imports and background jobs
Persist business database, uploaded documents, attachments, configuration and scheduled-job state. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Different business modules have different worker and database costs. Protect consistent database/attachment backups and time realistic reports rather than sizing only logins. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Assets hardware guide?
This guide was reviewed against the linked project deployment documentation on November 2, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Assets official setup / requirements
  2. Assets configuration / deployment
  3. Assets official repository and releases
  4. ZimaBoard 2 specifications
  5. Assets image source: public project material
