events per second, payload size, retention, background evaluations and query concurrency Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.AgentLogs-Hardwareanforderungen: RAM, CPU, Speicherplatz und Trace-Volumen und Aufbewahrungsdauer
Planen Sie RAM, CPU, persistenten Speicher und Dienstabhängigkeiten für AgentLogs mit einer auf die Workload abgestimmten ZimaOS-Dimensionierung, Backups und praxisnaher Hardwareauswahl.
AgentLogs hardware requirements at a glance
Shared agent-engineering activity and retained run observations. Collectors, retained observations, storage/indexing and queries need separate budgets. Event rate, payload size, cardinality and retention drive growth; observed applications and model evaluations remain independently provisioned.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist traces, events, evaluations, datasets, artifact/object storage and metadata database.
- Required services
- Use the documented AgentLogs runtime and selected service topology. Collectors, retained observations, storage/indexing and queries need separate budgets. Event rate, payload size, cardinality and retention drive growth; observed applications and model evaluations remain independently provisioned. Upstream references include SQLite. Verify which apply to your selected mode; a mention is not a mandatory dependency.
- Main sizing variable
- events per second, payload size, retention, background evaluations and query concurrency
- Practical Zima starting point
- Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Shared agent-engineering activity and retained run observations. Collectors, retained observations, storage/indexing and queries need separate budgets. Event rate, payload size, cardinality and retention drive growth; observed applications and model evaluations remain independently provisioned.
Plan the complete AgentLogs workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the documented AgentLogs runtime and selected service topology. Collectors, retained observations, storage/indexing and queries need separate budgets. Event rate, payload size, cardinality and retention drive growth; observed applications and model evaluations remain independently provisioned. Upstream references include SQLite. Verify which apply to your selected mode; a mention is not a mandatory dependency.
Confirm your needs
Test a representative busy operation: events per second, payload size, retention, background evaluations and query concurrency Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist traces, events, evaluations, datasets, artifact/object storage and metadata database. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Shared agent-engineering activity and retained run observations. Collectors, retained observations, storage/indexing and queries need separate budgets. Event rate, payload size, cardinality and retention drive growth; observed applications and model evaluations remain independently provisioned.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 20, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Shared agent-engineering activity and retained run observations. Collectors, retained observations, storage/indexing and queries need separate budgets. Event rate, payload size, cardinality and retention drive growth; observed applications and model evaluations remain independently provisioned. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist traces, events, evaluations, datasets, artifact/object storage and metadata database. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the documented AgentLogs runtime and selected service topology. Collectors, retained observations, storage/indexing and queries need separate budgets. Event rate, payload size, cardinality and retention drive growth; observed applications and model evaluations remain independently provisioned. Upstream references include SQLite. Verify which apply to your selected mode; a mention is not a mandatory dependency. | Include every stateful companion service in the host budget. |
| Persistent state | Persist traces, events, evaluations, datasets, artifact/object storage and metadata database. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Shared agent-engineering activity and retained run observations. Collectors, retained observations, storage/indexing and queries need separate budgets. Event rate, payload size, cardinality and retention drive growth; observed applications and model evaluations remain independently provisioned. | Check the linked project instructions for the selected edition and release. |
Use observed AgentLogs workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist traces, events, evaluations, datasets, artifact/object storage and metadata database. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 1664 or ZimaCube 2 Pro according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
Shared agent-engineering activity and retained run observations. Collectors, retained observations, storage/indexing and queries need separate budgets. Event rate, payload size, cardinality and retention drive growth; observed applications and model evaluations remain independently provisioned. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official AgentLogs deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review AgentLogs official installation ↗Check workload-specific deployment details
Review AgentLogs deployment details ↗Which Zima hardware fits AgentLogs?
Which workload best matches your AgentLogs deployment?
- Supporting hardware onlyZimaBoard 2 1664
| ZimaBoard 2 1664 | Conditional lab or supporting-service role | events per second, payload size, retention, background evaluations and query concurrency |
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Shared agent-engineering activity and retained run observations. Collectors, retained observations, storage/indexing and queries need separate budgets. Event rate, payload size, cardinality and retention drive growth; observed applications and model evaluations remain independently provisioned. | Get Now |
| ZimaCube 2 Pro | Conditional lab or supporting-service role | Use the documented AgentLogs runtime and selected service topology. Collectors, retained observations, storage/indexing and queries need separate budgets. Event rate, payload size, cardinality and retention drive growth; observed applications and model evaluations remain independently provisioned. Upstream references include SQLite. Verify which apply to your selected mode; a mention is not a mandatory dependency. |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to AgentLogs RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for AgentLogs?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: events per second, payload size, retention, background evaluations and query concurrency
Persist traces, events, evaluations, datasets, artifact/object storage and metadata database. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Shared agent-engineering activity and retained run observations. Collectors, retained observations, storage/indexing and queries need separate budgets. Event rate, payload size, cardinality and retention drive growth; observed applications and model evaluations remain independently provisioned. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this AgentLogs hardware guide?
This guide was reviewed against the linked project deployment documentation on November 20, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
