At ZimaSpace, we are always excited to see how creators push the boundaries of home server setups with our hardware. In this article, we revisit a detailed hands-on experiment by the YouTube creator Smart Home, aber sicher, who migrated his long-running Raspberry Pi 4 setup to ZimaBoard 2.
We sincerely thank the creator for this transparent and data-driven evaluation. His video walks through a complete real-world migration, including benchmarks, power consumption comparisons, and practical lessons learned. Based on his experience, this article distills the key insights to help you understand whether upgrading to zimaboard 2 is worth it for your own home server or homelab.
From “Good Enough” to Bottlenecked
For years, the creator relied on a Raspberry Pi 4 (8GB RAM) running Debian with multiple Docker containers. The setup handled Home Assistant, databases like InfluxDB, visualization tools like Grafana, and network services such as Pi-hole.
“It worked reliably for years—but it was never truly optimal.”
Despite its stability, performance issues appeared under load. Database writes became sluggish, container startups slowed down, and storage performance was limited by the USB-connected SSD. These small inefficiencies accumulated into noticeable friction in daily use.
ZimaBoard 2: Compact but Powerful
The transition to zimaboard 2 immediately changed expectations. Although physically small, the board introduces a completely different performance class thanks to its x86 architecture and upgraded hardware design.
“Smaller than a book, silent—and surprisingly powerful.”
Key hardware advantages include:
- Intel N100 processor with significantly higher performance than Raspberry Pi CPUs
- 16GB RAM, doubling the previous setup
- Native SATA and PCIe support for real storage and expansion
- Dual 2.5G Ethernet ports for advanced networking
Unlike ARM-based systems, zimaboard 2 removes Docker compatibility issues, allowing users to run standard images without workarounds.
Storage Design That Actually Matters
One of the most important upgrades comes from how storage is handled. Instead of relying on USB adapters, the creator used a SATA SSD directly connected to the board.
“Cleaner setup, fully enclosed, and more than enough performance for a 24/7 server.”
This native connection eliminates unnecessary overhead and creates a more stable, production-ready environment. While NVMe could provide higher speeds, SATA offered a cleaner and safer physical setup for continuous operation.
Benchmark Results: Where the Difference Shows
The real turning point comes from measurable performance gains. Direct comparisons between the Raspberry Pi 4 and zimaboard 2 revealed dramatic improvements.
- 100% higher throughput
- 50% lower latency
- 50% lower CPU usage under load
These results stem primarily from eliminating the USB bottleneck. On the Raspberry Pi, storage traffic must pass through a USB controller, increasing latency and CPU overhead. In contrast, zimaboard 2 uses direct SATA access, reducing latency from around 200 ms to under 50 ms.
“The Raspberry Pi hits its limits quickly—ZimaBoard still has headroom.”
Power Consumption and Efficiency
Performance gains always raise questions about power usage. In this case, the difference is measurable but reasonable.
- Raspberry Pi 4: ~8W average
- ZimaBoard 2: ~12W average
- Annual difference: ~35 kWh (~€10/year)
“For the performance gain, this is absolutely a fair trade.”
For a 24/7 system, this slight increase is often justified by the significant improvement in responsiveness and stability.
Silent Operation and Better Thermals
Another standout advantage of zimaboard 2 is its thermal design. Unlike the Raspberry Pi setup, which required a fan and custom enclosure, the new system runs entirely passively.
“No fan. No noise. Just passive cooling.”
Even under load, the device remains only warm to the touch. This makes it especially suitable for home environments where noise and heat matter.
Network and System Architecture Upgrade
Beyond raw performance, the architectural improvements are equally impactful. The addition of dual Ethernet ports opens the door to advanced networking configurations such as VLANs and firewall setups.
At the same time, the shift from ARM to x86 simplifies the entire software ecosystem. Docker images run without compatibility concerns, and the system integrates more naturally with standard Linux tools and workflows.
Migration Experience: Faster Than Expected
The migration process itself turned out to be surprisingly smooth. The creator transferred Docker volumes and configurations, restored them on the new system, and quickly resumed operations.
- Stop all Docker services
- Backup volumes and configurations
- Transfer data via SCP
- Restore and restart containers
“99% of everything worked immediately.”
This highlights the portability of containerized environments and reduces the barrier to upgrading hardware.
Proxmox and a Cleaner System Design
Switching to Proxmox introduced a more structured approach to managing services. Instead of running everything in a single OS, the system was divided into virtual machines and containers.
- One Debian VM for main Docker workloads
- Two LXC containers for Pi-hole and other services
- Independent IP assignments for better network control
“Finally, a clean architecture instead of everything in one system.”
This separation improves stability, scalability, and long-term maintainability.
Lessons Learned from the Migration
Not everything went perfectly. Some IoT devices were configured with fixed IP addresses tied to the old system, which caused temporary issues after migration.
- Devices failed to reconnect due to IP changes
- Solution: switch to hostname-based configurations
- Result: easier future migrations
A small adjustment that prevents larger problems later.
Final Verdict
“ZimaBoard 2 is not a Raspberry Pi replacement—it’s a different class of performance.”
The upgrade delivers meaningful improvements across performance, usability, and system design. While power consumption increases slightly, the trade-off is minimal compared to the gains.
For users running home servers, Docker environments, or smart home systems, zimaboard 2 provides a clear step forward in both capability and reliability.
Zima Campaign Hub
Why I Replaced Rack Servers With a ZimaCube 2 — A Homelab Evolution Story
ZimaCube 2 replaces noisy rack servers and limited mini PC setups with a quiet all-in-one homelab for Docker, ZFS storage, NVMe, backups, self-hosting, and...
Running Docker, CI/CD, and 10+ Self-Hosted Services on the ZimaCube 2
This community spotlight features ZimaCube 2 Pioneer Michael Luckenbill’s full self-hosted infrastructure test. Running 10+ Docker containers, local GitHub Actions CI/CD, dual ZFS HDD/NVMe...
What Happens When Two AI Agents Fight Over One Server?
Zero Noichi’s AI cybersecurity experiment used two ZimaBoard 2 devices to simulate attacker and defender agents, showing how homelab servers can support safe AI,...
