Jellyfin reads and writes create different system loads because large media transfers, small database updates, cached pages, and durable writes follow different I/O paths.
A server may stream several movies from an HDD with low apparent effort, then feel sluggish when a scan, metadata refresh, watch-state update, and transcode-cache write overlap. The important variable is not simply “disk activity”; it is whether the workload is sequential or random, read-heavy or write-heavy, cacheable or durability-sensitive, and competing with other services for the same queue.
Media Playback Is Usually a Large Sequential Read Workload
Direct Play commonly reads a file forward at approximately the delivered media bitrate, with seeks occurring only when the client jumps around. Sequential access lets storage devices and operating-system readahead work efficiently, so a mechanical disk can often sustain ordinary playback even though its random-access latency is much worse than an SSD. The server’s visible CPU load may stay small at the same time.
Jellyfin’s storage guidance explicitly separates media files from Jellyfin’s own files: media primarily need sequential throughput above their bitrate, whereas application files see substantial random access. That media-versus-application storage split explains why a drive can pass a multi-gigabyte copy test yet still be a poor place for a busy database and metadata tree.
The boundary is bitrate bursts and concurrency. Multiple high-bitrate reads, remote filesystem latency, fragmented storage, or competing seeks can remove the sequential advantage. Measure delivered throughput and device queueing during the actual playback mix instead of assuming every movie stream behaves like a single uninterrupted file copy.
Database and Metadata Work Produces Smaller, Less Sequential I/O
Library scans, search indexing, artwork updates, user state, and configuration changes touch many records and files rather than reading one large object from start to finish. Small operations make access latency and IOPS more visible, especially when the working set is larger than memory. The same amount of transferred data can therefore feel much more expensive than a media read.
This difference is why the ZimaSpace buffering guide recommends separating low-latency application state from bulk media when mixed workloads become the problem. Its mixed I/O explanation describes how scans, downloads, backups, and metadata activity can disturb playback even though each task alone appears reasonable.
The boundary is causality: moving every file to SSD is unnecessary if the observed delay comes from CPU conversion or a congested network. First compare application-state latency with media-read latency under the same overlap. Only storage work that tracks the symptom should drive a placement change.
The Page Cache Makes Reads and Writes Look Asymmetric
Buffered reads can become memory hits after their pages have been fetched once, while buffered writes often return after modifying memory pages and leave the kernel to flush those dirty pages later. This makes short observations misleading: a write burst can appear cheap initially and then produce delayed device activity, while repeated reads can appear almost free because the disk is no longer involved.
The Linux page-cache model describes both paths: ordinary reads populate cached pages, and writes can create dirty pages whose persistence is deferred until writeback or an explicit synchronization boundary. That write-back behavior explains why Jellyfin can show bursty storage activity after the user-facing operation that originally created the data has already completed.
The boundary is durability and memory pressure. Database software may request stronger persistence guarantees than ordinary cache files, and a memory-constrained host can be forced to write dirty pages or evict useful read pages sooner. Do not infer device capability from an operation that was satisfied mostly in RAM.
Concurrent Reads and Writes Compete Through the Same Device Queue
A disk or SSD ultimately has finite service capacity, so playback reads, database commits, downloads, backups, and transcode segments can queue behind one another. On HDD, head movement amplifies the penalty when sequential reads are interrupted by unrelated small writes. SSDs reduce seek latency dramatically, but queueing can still appear when write amplification, flushes, or other containers push the device toward saturation.
The storage saturation test frames this as a resource problem: utilization alone is not enough, because queue length and latency reveal whether demand is waiting for service. A disk at moderate average bandwidth can still be the bottleneck if small synchronous operations queue long enough to delay Jellyfin’s interactive database requests.
The boundary is repeated correlation. A one-time latency spike during a scheduled backup is not proof that the storage design is inadequate for normal playback. Reproduce the same overlap, pause one writer, and check whether Jellyfin latency falls; if it does, scheduling or isolating that writer may solve the issue without replacing the entire storage tier.
Build a Read-Write Matrix Before Changing Storage
Test four states with the same media and client: playback alone, playback plus a library scan, playback plus a sustained external write, and the full normal peak. Record media throughput, application-state latency, device queue depth, dirty-page or writeback activity when available, and first-frame or seek delay. This matrix shows whether the problem follows reads, writes, or only their overlap.
A warm-cache control is also necessary because repeated library navigation may no longer touch the device. The cold-versus-warm control keeps the comparison honest: run one cold case and one repeated case so a cache hit is not mistaken for storage headroom or a cache miss for permanent underperformance.
Keep the existing layout when playback remains stable, queueing stays bounded, and application-state latency does not rise materially during the normal overlap. Split app data, cache, or write-heavy jobs onto another tier when the same interference reproduces consistently. Escalate beyond storage when the queue stays healthy but compute, memory, or network metrics fail instead.
| Test | What it isolates | Interpretation |
| Playback only | Sequential read baseline | Establish media path |
| Playback + scan | Read + metadata writes | Expose app-state interference |
| Playback + external write | Shared device queue | Expose write contention |
| Warm repeat | Page/cache reuse | Separate RAM from device I/O |
