Why Does Jellyfin Look Faster After Its Cache Warms Up?
Jellyfin often feels faster after its cache warms because repeated requests reuse metadata, thumbnails, pages, or prepared segments instead of rebuilding them.
On a home server, the first browse or playback request may read from disk, parse media, and fetch artwork; later requests can stay in memory or local cache. That changes time to response, but it does not create more CPU, GPU, network, or storage capacity for new simultaneous work.
Observe the Cold Request Before It Repeats
The first browse, search, or playback request feels slow. The relevant relationship is The server reads source data, parses metadata, fetches assets, and builds objects before a reusable result exists.
The observable effect is First access has higher latency and more storage or network reads than the next access. This is why the result changes with the stated condition. cache miss
The boundary is specific: A cold miss is expected; repeated misses for the same key indicate eviction, path changes, or ineffective caching. The practical implication is Record first-request latency and resource reads as the cold baseline.
Follow Reuse Into a Warm Request
The same request is repeated with the server still running. The relevant relationship is Cached metadata, decoded pages, thumbnails, or segments reduce source reads and repeated parsing.
The observable effect is The second request returns sooner with fewer reads, even though the underlying media and CPU are unchanged. This is why the result changes with the stated condition. metadata reuse
The boundary is specific: Only data represented by the cache benefits; a new item or changed query can remain cold. The practical implication is Compare identical requests, not different library items.
Separate Perceived Speed From Throughput
Warm requests are fast but new clients still compete for resources. The relevant relationship is Warm state removes repeated setup work, while new decodes, transcodes, and writes still consume the same engines and queues.
The observable effect is Browsing feels instant while a new HDR transcode still saturates the accelerator. This is why the result changes with the stated condition. capacity ceiling
The boundary is specific: Warm cache cannot repair a full disk, weak network, missing codec, or overloaded encoder. The practical implication is Measure first-response latency and steady-state throughput separately.
State When Warm Cache Stops Helping
Warm requests appear fast under a stable session. The relevant relationship is Restart, eviction, new media, changed metadata, or many simultaneous misses removes reuse and returns source work.
The observable effect is Latency rises after restart or when a new library is scanned, even though the server hardware is unchanged. This is why the result changes with the stated condition. cold and warm runs
The boundary is specific: Warm behavior cannot be used as a universal performance claim outside the same cache state. The practical implication is Benchmark both cold and warm cases and report which one represents the household.
