Structured output constrained decoding enforces a schema or grammar during generation by allowing only next tokens that can still lead to a valid structure.
That mechanism matters when a local model feeds JSON, tool arguments, SQL-like structures, or machine-readable records into another program. Prompting can request a format and post-generation validation can reject bad output, but constrained decoding changes the sampling process itself. It prevents many structural failures before they exist, while leaving factual correctness, tool authorization, and schema semantics as separate responsibilities.
Constrained Decoding Restricts the Next Token Before It Is Sampled
Ordinary decoding scores the model's vocabulary and samples from the allowed distribution. A constrained decoder inserts another step that checks the current structured-output state and removes tokens that would make the target grammar impossible to complete.
A vocabulary-sized token mask can mark which tokens remain legal at each generation step.
The model still supplies probabilities among the surviving choices. The constraint engine does not write the answer; it narrows the path so an illegal quote, bracket, field position, or grammar transition cannot be selected at that moment.
A Schema or Grammar Must Become a Decoder Constraint
A JSON Schema, regular expression, or EBNF grammar describes allowed structure at a higher level than token IDs. The runtime must compile or translate that description into a representation it can update while tokens are emitted.
A schema can define rules for describing and validating structure, but those rules do not automatically perform token-level decoding without a backend that maps them into generation.
This distinction explains why two runtimes can advertise JSON output yet support different schema features. The model is not the only compatibility layer; the constrained decoder must understand the rule set too.
Unsupported keywords or complex recursive structures can therefore fail before generation or fall back to weaker validation, even when the language model itself could have produced the requested text.
Grammar State Changes the Legal Vocabulary After Every Token
The legal token set depends on what has already been generated. After an opening brace, a key name may be valid; after a numeric field's colon, a quote may be invalid; after a complete object, only delimiters or the end of output may remain legal.
Rejecting inadmissible tokens during decoding prevents an invalid partial sequence from surviving until the complete output is checked.
The constraint state therefore advances with generation. A parser, finite-state machine, pushdown structure, or equivalent representation determines which continuations keep the partially generated object valid.
Structural Validity Does Not Make the Values True
Constrained decoding can guarantee that a temperature field contains a number and that required keys appear in the proper object. It cannot prove that the number came from the correct sensor or that the requested device actually exists.
JSON Schema, regex, and EBNF can serve as generation-time structure constraints, which should be interpreted as syntax control rather than factual verification.
For home-server tools, the executor must still validate resource identity, permissions, preconditions, and real-world state. A perfectly valid JSON command can still target the wrong container or request an unsafe side effect.
The related JSON-schema failure analysis explains why structured output breaks, while constrained decoding explains one mechanism for preventing invalid structure during generation.
Complex Constraints Add Decoder Work
Every generation step now includes constraint-state processing and token masking in addition to model inference. Efficient implementations cache grammar state and compress legal-token sets, but the overhead is not zero.
Finite-state or grammar machinery can constrain output efficiently, but structured generation overhead still depends on implementation details that affect latency and memory.
The overhead is usually justified when downstream parsing failures are expensive. It matters less for free-form prose where strict structure does not control a machine action or data pipeline.
Constrained Decoding Matters When Output Becomes Machine Input
The strongest use case is a boundary where generated text stops being merely descriptive and is consumed by deterministic software. Tool calls, configuration records, API payloads, database mutations, and workflow state all benefit from a narrow accepted language.
A local agent should still pair structured generation with schema validation after decoding. The two layers catch different problems: the decoder prevents illegal continuations, while validation confirms that the completed object satisfies the full contract before execution.
Treat constrained decoding as one reliability layer, not a complete safety system. It controls form; authorization controls authority; approval controls whether a specific valid action should be released.
What Is Embedding Drift, and When Does a Private Search Index Need Rebuilding?
Decode model, preprocessing, corpus, and query drift; distinguish monitoring from incompatibility; and decide when a private index needs rebuilding.
What Is Tokenizer Compatibility, and Why Can It Break Model Switching?
Decode vocabulary identity, special-token semantics, chat templates, cached tokens, adapters, and compatibility checks for local model switching.
What Is Model Residency, and When Should a Local AI Service Keep Weights Loaded?
Decode weight residency, cache levels, cold starts, eviction, multiplexing, memory pressure, and when a home AI service should stay warm.
