Local LLM output breaks a valid JSON schema when generation, constraint handling, stopping rules, and validation do not enforce the same contract.
A self-hosted workflow may supply a standards-compliant schema for file metadata, smart-home actions, document extraction, or tool arguments and still receive malformed or rejected output. โValid schemaโ describes the schema document, not the full execution path. The model must understand the task, the decoder must support the relevant schema features, generation must finish before a stop condition cuts it off, the parser must recover a complete JSON value, and the application validator must apply the expected draft and coercion rules.
Valid JSON and Schema-Valid JSON Are Different Outcomes
An object can parse successfully while violating required fields, types, enums, array limits, or conditional branches. It can also contain correct field names but add properties the schema forbids.
Pythonโs JSON module defines the syntax layer for decoding a JSON document, but parsing does not apply a separate JSON Schema contract.
This cause is recognizable when the output loads without a syntax error yet fails only after schema validation. A missing brace or trailing explanation is a serialization failure; a string where an integer is required is a contract failure.
Schema Composition Can Create Hard-to-Satisfy Branches
Keywords such as allOf, anyOf, oneOf, and not combine constraints. A branch may be valid in isolation while the combined object satisfies none or several of the allowed alternatives.
JSON Schema guidance explains how schema composition keywords change whether one or multiple subschemas must match.
A local model often handles a flat list of properties more reliably than nested conditional logic. If failures cluster around unions or mutually exclusive object shapes, the primary pressure comes from branch selection rather than basic JSON punctuation.
The Constrained Decoder May Support Only Part of the Schema
Structured-output engines translate schemas into token constraints, grammars, regexes, or backend-specific rules. They do not all implement every JSON Schema draft or keyword.
vLLM exposes several structured-output backends, showing that JSON schema, grammar, regex, and fixed-choice constraints are separate execution modes.
This cause appears when the same schema validates correctly in a standards validator but fails only under one inference backend. Unsupported recursion, references, patterns, or conditional keywords may be simplified, ignored, or rejected before the model generates anything.
Prompt Instructions Can Conflict With the Schema
The user prompt may request commentary, citations, explanations, optional omissions, or natural-language uncertainty while the schema requires a single object with fixed fields.
The model then has two competing success criteria: answer the user conversationally and emit only tokens legal under the machine contract. A smaller local model may follow the more recent or more salient instruction rather than reconcile both.
These failures often add a preamble, markdown fence, explanation after the object, or a value that satisfies the prose request but violates the declared enum. The schema is valid; the instruction hierarchy is inconsistent.
Truncation Can Leave a Correct Plan as Invalid Output
Nested arrays and objects require enough generated tokens to close every structure. A token limit, stop string, canceled request, or interrupted stream can end the response before the final delimiters arrive.
Transformers exposes maximum token and stopping controls that determine when generation terminates.
This root cause is distinguished by valid prefixes that end abruptly, especially on larger arrays or long string fields. Repeated type violations near the beginning point elsewhere; missing closing brackets near the output limit indicate incomplete generation.
Validator Semantics Can Reject Values the Model Considered Equivalent
A model may emit "3" for an integer, null for an omitted field, a lowercase enum, or an ISO date that the application expects in another format.
Pydantic documents distinct validation error categories for missing values, invalid JSON, enum mismatch, forbidden extra fields, and incompatible types.
If every failure reaches the same field with a parseable but rejected value, the cause is not random schema breakage. It is a disagreement about coercion, strictness, nullability, casing, or application-level formats.
Grammar Constraints Can Preserve Syntax but Not Business Meaning
A grammar can block illegal braces and keys while still allowing a semantically impossible combination such as an end date before a start date or a nonexistent file path.
llama-cpp-python provides grammar-constrained generation as an inference control, but the grammar governs allowed token structure rather than external truth.
A schema failure caused by cross-field rules may appear only in a second validation layer. The output can be syntactically and structurally valid while still being unusable for the home-server workflow.
Post-Processing Can Corrupt Otherwise Valid Model Output
Applications sometimes strip markdown, extract the first brace-delimited block, merge streaming chunks, repair commas, or convert values before validation.
A valid model response can become invalid when a stream chunk is duplicated, Unicode is decoded incorrectly, an escape sequence is removed, or a repair function edits nested content. Conversely, a repair step can hide that the raw model output was invalid.
ZimaSpaceโs explanation of why small local models hallucinate during JSON output provides the adjacent boundary: schema validity and factual correctness must be measured separately, and the raw response should be retained before application transformations.
Does valid JSON prove the output matches the schema?
No. JSON parsing checks syntax. Schema validation separately checks required properties, types, enums, branches, limits, and other declared constraints.
Will temperature zero prevent schema failures?
No. It can make one decoding path more repeatable, but it does not add unsupported schema features, prevent truncation, or resolve conflicting instructions.
Does constrained decoding guarantee a usable automation record?
No. It can guarantee supported structural constraints, but business rules, source grounding, file existence, permissions, and cross-field consistency still need application validation.
