Home Assistant outages expand when apparently separate features share one power, host, storage, network, identity, or gateway dependency that fails.
A dashboard, automation engine, database, broker, radio coordinator, DNS resolver, and mobile client may run as distinct components yet still collapse together when their common host or route disappears. Failure-domain analysis traces each household outcome through those dependencies, identifies correlated loss, and sets a recovery order. Redundancy helps only when the alternate path does not share the same hidden cause.
Start With Household Outcomes, Not Containers
Define outcomes such as local lighting, heating safety, alarm visibility, remote access, and history retention. For each outcome, trace the required components from sensor or client through network, Home Assistant, integrations, broker, database, and actuator. A running container is irrelevant if the household outcome still depends on a failed gateway.
High-availability discussions repeatedly expose the difference between keeping a process alive and keeping an automation path usable. This high-availability discussion surfaces state synchronization, radio ownership, and failover questions that a simple second instance does not solve.
Stop the map at components whose loss changes the outcome. Optional analytics may not belong in a lighting-control domain, while DNS may be essential for a database hostname. The boundary prevents a giant inventory from obscuring the small set of dependencies that actually determines an outage.
Shared Infrastructure Creates Correlated Loss
Two containers on one host share its kernel, power supply, storage controller, and often the same filesystem. Two hosts can still share a switch, UPS, resolver, or credential provider. Replicas reduce risk only when the failure being mitigated does not remove every replica and the coordination data needed to select one.
A practical Home Assistant clustering design illustrates the number of layers involved in real failover. The replicated cluster design separates replicated storage, service placement, and client access, showing why an extra application process alone is not an independent failure domain.
Correlated risk is acceptable when its consequence fits the household tolerance and recovery is fast. It becomes dangerous when the same host holds the live service, its only database, and the only backup. Label each shared physical and administrative dependency before buying or configuring redundancy.
Dependencies Determine the Recovery Sequence
Recovery should proceed from foundational services outward: power and storage, host and network, DNS and identity, databases and brokers, Home Assistant, integrations, then clients and automations. Starting a consumer before its dependency is ready can create misleading errors, retries, or partial availability that complicates diagnosis.
Power-loss reports show how one event can surface later as storage, networking, or application symptoms. This account of post-outage symptoms is a useful reminder to locate the earliest failed layer rather than repairing every downstream warning independently.
The failure boundary is a dependency that cannot be restored or verified without destructive changes. Preserve logs and known-good state there. Rebuilding downstream integrations before the database, broker, or name service is stable may erase evidence while leaving the actual outage cause untouched.
Produce a Failure-Domain Test Card
Create one row per household outcome with columns for required components, shared dependencies, detection signal, degraded behavior, recovery owner, and maximum outage. Add a test that safely removes one dependency at a time and records which outcomes fail, which continue locally, and how automatically they recover.
Use the local-control component map when the map shows one dependency coupling too many required outcomes.
Accept the architecture when every critical outcome has a known failure scope, an alert that detects it, and a recovery sequence that fits the target. Change the topology only where a tested failure crosses the tolerance. A diagram without a controlled failure test is an assumption, not resilience evidence.
Open Models Are Catching Frontier AI—Is 2026 the Year Local AI Becomes Good Enough?
Open models are getting good enough for more local AI workloads, while frontier cloud models remain useful for the hardest reasoning and agent tasks.
NVIDIA PAIR Turns Your Home Network Into a Local AI Cluster—Do You Still Need One Big GPU Server?
NVIDIA PAIR spreads local AI requests across multiple PCs, making compute more elastic while one home server can keep data and state persistent.
Why Does Immich Feel Faster on LAN Than on Remote Connections?
LAN requests usually take a shorter, lower-latency path. Remote access adds WAN capacity limits and may add DNS, TLS, proxy, VPN, or relay hops.
