Why Do Deduplicated Backups Look Smaller Than Their Restore Footprint?
Deduplicated backups look smaller because repeated chunks are stored once, while a restore reconstructs each logical file and independent copy.
Ten virtual-machine images may share gigabytes of identical operating-system blocks in a backup repository. Restoring them to an ordinary filesystem recreates ten address spaces, unless the destination also supports compatible sharing, sparsity, or compression. Repository size and restore capacity therefore describe different representations with different allocation rules and overhead on the selected target filesystem securely.
Deduplication Stores Identity Once and References It Many Times
Backup software divides data into chunks, fingerprints them, and stores only chunks not already present. Manifests preserve which chunks belong to each file and restore point. The repository can represent many logical copies with one physical payload plus references.
An overview of backup deduplication explains how redundant copies are eliminated from backup storage. The saving depends on repeated content, not simply on the number of files.
Restoration reverses that mapping. Each file receives its ordered bytes at the requested destination. If the target lacks block sharing, repeated chunks consume separate extents again. Data reduction was a property of the repository, not a promise that every restore target remains equally compact.
Compression, Sparsity, and Metadata Widen the Difference
Compression reduces stored bytes according to content entropy. Sparse files omit long zero regions, yet a restore option may materialize those holes. Allocation units, checksums, extended attributes, and filesystem metadata add destination overhead that repository summaries may exclude.
A storage explanation distinguishes sparse files from allocated size: a file can report a large logical length while consuming fewer physical blocks. Restore tools must preserve holes explicitly to retain that saving.
The opposite can also occur. A compressed destination or copy-on-write clone may keep restored data smaller than its logical size. There is no universal multiplier from repository bytes to restored bytes because representation, retention set, and target filesystem all matter.
Where Deduplication Is Not the Main Cause
The explanation fails when a single nonduplicated file expands unexpectedly. Encryption, precompressed media, database export formats, or a thin-provisioning change may dominate instead. A backup catalog may also display only unique data for one scope while the restore includes several selected snapshots.
A technical discussion of deduplication ratio emphasizes that logical and physical sizes must be distinguished when reporting deduplication ratios. Ratios without scope can mislead capacity planning.
The mechanism also stops applying if the restored file hashes or counts differ from the selected backup. Then the issue is selection or integrity, not expected expansion. Smaller backup bytes do not justify undersizing temporary space before verification.
Measure a Restore Instead of Trusting the Ratio
Choose a representative restore set and record logical source bytes, unique repository bytes, compressed bytes, sparse extents, file count, and target allocation unit. Restore into an isolated destination using both sparse-preserving and default options, then verify hashes and allocated space.
Use a shared model storage storage plan so the test destination cannot crowd active services. Keep repository retention and target compression settings fixed while comparing runs.
Size recovery from the larger of measured allocated output and logical dataset size plus working headroom, not the deduplicated repository number. If sparse preservation changes the result, document that dependency. If file identity or count changes, stop and resolve restore correctness before capacity tuning.
