5 Hermes Plugins Worth Installing With DeepSeek: Give Your Agent Eyes, Memory, and More
Lauren Pan is the founder of ZimaSpace and the architect behind the acclaimed ZimaBoard series. Blending industrial design with embedded engineering, Lauren launched ZimaSpace with a clear mission: to democratize personal cloud computing. He operates on the belief that hardware should be both "hackable" and beautifulโ€”closing the divide between industrial-grade servers and consumer gadgets. Today, he leads the engineering team in building tools that give creators full control over their digital lives.
A DeepSeek-powered Hermes Agent can already reason, use tools, remember information, and run persistent workflows. But the biggest upgrades do not always come from switching to a larger model. Sometimes the more useful change is giving the agent an ability it did not have before: eyes for screenshots, deeper long-term memory, a design workspace, access to your private cloud, or a way to stop dragging unnecessary context through every request.
That is how we picked the five additions below. They are not simply the most popular Hermes projects. Each one changes a practical capability of a DeepSeek + Hermes setup. If you are still building the base environment, start with our Hermes Agent self-hosted setup guide before adding more moving parts.
A terminology note: we use โ€œpluginโ€ loosely in this article. The Hermes ecosystem includes traditional plugins, skills, memory providers, MCP integrations, and tools that sit beside the agent. Hindsight, for example, is now a native Hermes memory provider rather than a separate plugin you should install.
Why DeepSeek + Hermes Gets More Useful Once You Add the Right Plugins
The useful question is not how many plugins Hermes can run. It is what new capability each addition creates. Hermes already provides a substantial agent layer around the model, including persistent memory, tools, scheduling, messaging surfaces, and delegation. Adding another generic tool that duplicates those functions may increase complexity without changing what the agent can actually accomplish.
That is why this list focuses on five different bottlenecks. ModLens addresses vision. Hindsight strengthens long-term memory. Open Design adds an artifact-oriented visual workflow. Hermes Nextcloud connects the agent to self-hosted personal data. LLMTrim attacks the context overhead that appears as an agent accumulates tools, results, and conversation history. You can review the underlying Hermes environment and model-sizing boundary separately in our Hermes Agent hardware requirements guide.
The result is a more useful way to think about an AI agent stack: eyes โ†’ memory โ†’ creation โ†’ private data โ†’ efficiency. You do not necessarily need all five on day one. Start with the capability that is currently stopping your agent from doing useful work.
Plugin or Add-On What It Adds Best For Install Priority
ModLens Vision for text-only DeepSeek models Screenshots, UI, OCR, diagrams, visual debugging Highest for text-only DeepSeek
Hindsight Structured long-term memory Long projects, preferences, recurring work High for persistent agents
Open Design Visual artifact creation Web pages, dashboards, slides, prototypes High for creators and builders
Hermes Nextcloud Private data access Files, notes, calendars, tasks, contacts High for self-hosted personal agents
LLMTrim Context compression Long sessions and tool-heavy workflows Useful as workflows grow
1. ModLens โ€” Give DeepSeek Hermes Eyes
If your DeepSeek model is text-only, ModLens creates the most obvious before-and-after difference on this list. Instead of requiring you to manually describe a screenshot, paste OCR text, or translate a visual problem into words, the vision layer can inspect the image first and turn what it sees into evidence the text model can reason about.
ModLens was built first as a vision plugin for DeepSeek Harness. Its documented workflow can turn pasted images into structured visual evidence including OCR, layout, and semantics. In a DeepSeek-centered stack, it effectively becomes the visual front end: a vision-capable engine interprets the pixels, then the text-only DeepSeek model continues the reasoning process.
The important distinction is that this is more useful than plain OCR. OCR answers โ€œwhat text is in this image?โ€ A useful visual agent also needs to understand where information appears, which objects belong together, what a UI state means, and which part of a screenshot is relevant to the task. That makes ModLens useful for dashboards, application screenshots, diagrams, error dialogs, web layouts, and image-heavy documentation.
Imagine troubleshooting a home server. Without a visual bridge, you might type: โ€œThe storage widget is orange and one drive says degraded.โ€ With ModLens in the DeepSeek side of the workflow, the interaction becomes much closer to: โ€œLook at this dashboard screenshot and tell me what I should investigate first.โ€ The difference is not a slightly better answer. It is the removal of an entire manual translation step between you and the agent.
There is one boundary worth keeping clear. ModLens is currently documented most strongly as a DeepSeek Harness integration, so we would treat it as the DeepSeek-side vision layer rather than pretend it is a native Hermes core plugin. That distinction matters when you decide where image handling occurs in a combined DeepSeek and Hermes workflow.
2. Hindsight โ€” Give Hermes a Better Long-Term Memory
Hermes already has memory, so Hindsight should not be described as the thing that suddenly makes Hermes remember. The real upgrade is what happens when an agent has months of conversations, projects, corrections, preferences, and recurring tasks and needs to retrieve the right part of that history at the right moment.
Current Hermes builds support Hindsight as a memory provider. The integration can automatically recall relevant information before model calls and retain conversations for future sessions, while also exposing explicit retain, recall, and reflect operations. The old standalone Hindsight-Hermes plugin is deprecated; the correct current path is the native Hindsight memory provider for Hermes.
That distinction becomes important in a persistent personal agent. Saving a fact is easy. Deciding which old facts matter to the current task is harder. A long-running agent may need to connect a decision made six weeks ago with a new request today, distinguish an old preference from a later correction, or remember how a recurring server problem was solved without loading every previous conversation into the prompt.
A practical example is a long home-server project. You might spend several weeks changing storage paths, container policies, backup rules, and application settings. When you return later and ask Hermes to modify one part of that system, good memory is not simply โ€œhere are 500 previous messages.โ€ It is the ability to retrieve the small set of prior decisions that constrain the new action.
Hindsight therefore makes the most sense when Hermes is becoming a persistent workspace rather than a disposable chat session. If you only use the agent for isolated questions, the difference may be modest. If it manages projects, recurring research, or personal infrastructure for months, memory quality becomes part of the agent architecture.
3. Open Design โ€” Turn Hermes From a Coding Agent Into a Visual Creator
Generating HTML or React is not the same thing as completing design work. A coding agent can produce a page that technically renders while still leaving you to make the visual decisions: hierarchy, spacing, style direction, iteration, preview, and delivery. Open Design tries to close that gap by putting an artifact-oriented design workflow around the agent.
Open Design describes itself as a local-first design workspace that can use existing coding agents as the design engine, and Hermes is among its supported agent integrations. Its workflow covers outputs such as prototypes, landing pages, dashboards, slides, images, and video rather than limiting the model to prose or source-code suggestions.
That changes the prompt from โ€œwrite some CSS for this dashboardโ€ to something closer to โ€œbuild this dashboard, establish a visual direction, generate the artifact, review it, and iterate.โ€ For a creator, developer, small team, or homelab user building custom interfaces, that is a much more tangible capability increase than another general-purpose coding skill.
It also fits naturally with DeepSeek because the design layer and reasoning model do not have to be the same product. DeepSeek can remain part of the reasoning and coding stack while Open Design provides the workspace, templates, skills, previews, and artifact pipeline around it. That separation is useful if you prefer bringing your own model rather than locking the entire workflow to one hosted design service.
The limitation is equally important: visual generation adds another layer of tools and sometimes additional model or media-provider requirements. If Hermes is mainly doing server administration or research, Open Design may be optional. If the agent regularly produces web interfaces, presentations, marketing assets, or internal dashboards, it becomes much easier to justify.
4. Hermes Nextcloud โ€” Connect Your Agent to Private Files, Calendars, and Tasks
This is where Hermes starts to feel less like an AI tool and more like a personal agent. A model can know a great deal about the public world and still know almost nothing about the files, notes, calendars, and tasks that actually determine what you need to do today. A self-hosted data layer changes that.
The community-built Hermes Nextcloud bridge exposes Nextcloud data to Hermes through interfaces including WebDAV, the Nextcloud Notes API, CalDAV, and CardDAV. That allows workflows around files, notes, calendars, tasks, and contacts without turning a browser session into the only way the agent can reach those resources.
For a home-server user, this creates some of the most immediately useful agent requests in the article. โ€œFind the PDFs I uploaded yesterday and compare them.โ€ โ€œCheck my calendar and tell me which afternoon is free.โ€ โ€œCreate a task from these meeting notes.โ€ โ€œLook through my private project folder and summarize what changed.โ€ Those are not model benchmarks. They are jobs people actually delegate.
The self-hosting angle matters as well. Nextcloud can live on infrastructure you control, and Hermes can live beside it as another service in the same private environment. If you are planning that side of the stack, our Nextcloud hardware requirements guide explains how CPU, RAM, storage, databases, and user count change the server requirements.
Private hosting does not automatically make the workflow safe. An agent with access to calendars, contacts, and writable files has a larger blast radius than a chatbot with read-only public search. Start with the narrowest permissions you need, use dedicated application credentials where possible, and decide explicitly which data Hermes should be allowed to read or change.
5. LLMTrim โ€” Keep Long Hermes Sessions From Eating Too Much Context
The first four additions make Hermes capable of doing more. The fifth addresses what happens after it actually starts doing all of that work. Long-running agents accumulate context: tool definitions, terminal output, MCP responses, scraped pages, conversation history, intermediate reasoning artifacts, and results returned from other tools. Some of that information remains useful. Some is repeated baggage.
LLMTrim sits between the agent and the model endpoint as a local proxy. Its Hermes-specific guidance explains that it can compress repeated tool schemas, conversation history, MCP tool output, and scraped content before the request is sent to the model. The Hermes and LLMTrim integration is therefore different from a normal skill: it changes the transport path rather than teaching Hermes a new task.
This becomes more relevant as your DeepSeek + Hermes environment gains tools. Imagine an agent that has browser tools, several MCP servers, Nextcloud access, long-term memory, terminal output, and a long conversation. If every turn sends large amounts of repeated structure back to the model, the cost of maintaining the agent loop can rise even when the actual new question is short.
Context reduction is not magic, and aggressive compression always deserves testing. Removing the wrong detail can damage a later answer just as surely as adding irrelevant context can distract the model. The useful goal is not โ€œmake every prompt as small as possible.โ€ It is โ€œstop paying context for information that no longer contributes to the next decision.โ€
There is also a security consideration. A local proxy positioned between Hermes and the model provider necessarily sees request content passing through it. Treat that as part of your trust boundary, especially if Hermes processes personal files, credentials, private notes, or other sensitive material.
Which Hermes Plugin Should You Install First?
If you are running a text-only DeepSeek model and only want to try one upgrade, ModLens is the clearest first choice. Vision creates the most obvious new capability because it removes the need to manually translate screenshots and images into text before the model can help.
After that, the right choice depends on what is limiting the agent rather than on a universal ranking. Choose Hindsight when historical context is becoming difficult to reuse. Add Open Design when the output itself needs to be visual. Add Hermes Nextcloud when the useful information lives in your private cloud. Add LLMTrim when long, tool-heavy sessions start carrying more context than the task appears to require.
If You Want Hermes To... Start With Why
Understand screenshots, interfaces, and images ModLens Adds a visual interpretation layer to text-only DeepSeek workflows
Reuse knowledge from long-running projects Hindsight Improves structured long-term recall and reflection
Create websites, dashboards, or visual assets Open Design Adds an artifact-oriented design workflow
Work with your own files and schedule Hermes Nextcloud Connects the agent to self-hosted personal data
Reduce repeated context in long sessions LLMTrim Compresses request payloads before they reach the model
If you are still choosing what belongs on the server in the first place, the ZimaOS App Hardware Requirements catalog is a useful next step for comparing AI and self-hosted application workloads before stacking several services on one machine.
The Better Way to Think About Hermes Plugins
The most useful Hermes extensions are not necessarily the ones with the longest feature lists. They are the ones that remove a specific boundary. ModLens removes the image boundary. Hindsight improves the memory boundary. Open Design expands the output boundary. Nextcloud crosses the boundary between public model knowledge and your private working data. LLMTrim manages the context boundary created when all of those tools start operating together.
That creates a much clearer architecture than simply installing every interesting project you find. Start with a capable model such as DeepSeek, use Hermes as the persistent agent layer, and add external capabilities only when a real workflow requires them. A smaller stack with five clearly justified integrations is usually easier to understand, secure, update, and troubleshoot than an agent with dozens of overlapping tools.
The end goal is also more interesting than building a chatbot with extra buttons. A self-hosted DeepSeek + Hermes environment can gradually become a private AI workspace that can see what you see, remember what matters, create useful artifacts, work with data you control, and stay efficient as its responsibilities grow. That is the point where plugins stop being accessories and start becoming part of the agent's architecture.
