A second NAS can become cheaper than expanding cloud backup when the protected dataset is large, grows predictably, and will stay large for several years—but only if the second NAS can be placed somewhere that actually protects against a site-level loss. The comparison should include drives, hardware replacement, electricity, administration, and the value of a fast local-style restore. Cloud still wins easily for small critical datasets, irregular growth, or users who do not want to maintain another machine.
Compare the Cost of the Protected Dataset, Not the Size of the Primary NAS
A 40TB primary NAS does not automatically require 40TB of cloud or secondary-NAS capacity. Some data may be replaceable media, temporary downloads, caches, or replicated application state. The cost comparison starts with the amount of data that would actually need to be recovered after losing the primary system.
Backblaze's NAS-versus-cloud comparison separates local hardware strengths from cloud scalability and maintenance-free off-site storage. That capacity-and-operations distinction is the right frame for a second-NAS decision as well.
Estimate today's protected data, annual growth, retention overhead from versions or snapshots, and any staging space the backup system needs. Then compare that five-year capacity requirement against both paths. For cloud, include the storage and recovery model you would actually use. For a second NAS, include chassis, drives, replacement reserves, power, and periodic refresh.
A second NAS becomes economically interesting when capacity is high and stable enough that repeated rental of the same storage dominates the comparison. If the protected set is only a few hundred gigabytes of documents and family photos, buying and maintaining another server is often the more expensive way to solve a simple off-site problem.
A Second NAS Only Competes With Cloud Backup When It Is Truly Off-Site
Two NAS systems in the same rack protect against a single chassis failure, but they do not solve fire, theft, flood, major electrical damage, or another event that removes the whole room. That means an on-site second NAS and cloud backup are not equivalent products. The physical location must be included in the buying decision.
Veeam's 3-2-1 backup guidance retains the core requirement for an off-site copy and extends modern backup planning with immutability and recovery verification. That off-site requirement is the minimum boundary a second NAS must cross before it can replace part of a cloud-backup plan.
A remote family home, studio, office, or another physically independent site can turn the second NAS into a legitimate disaster-recovery target. The remote site still needs reliable power, internet access, secure connectivity, and someone who can replace a failed drive when necessary.
If there is no practical second location, cloud backup keeps a structural advantage that a second box in the same house cannot match. In that case, a second NAS may still be useful for fast local recovery, but it should supplement rather than replace the off-site copy.
Data Growth and Version Retention Determine the Break-Even Point
The cost curve changes as protected capacity grows. Cloud storage scales smoothly in small increments, while a NAS is bought in larger steps: another drive, a larger mirrored pair, or an additional pool. That means cloud can be more economical at low capacity even when the long-run per-terabyte cost appears higher.
Cloudwards' 2026 NAS backup guide shows how cloud services differ in NAS compatibility, backup tooling, and storage models. That service-model variation is why a break-even calculation should use the provider and retention policy you would really deploy rather than a generic monthly cloud number.
Model the second NAS in capacity steps. If the remote system would be nearly empty for years, you are paying for unused headroom early. If the backup set is already large enough to fill most of a practical drive group, the hardware may be used efficiently from the first year and the economics improve.
The ZimaSpace home server backup guide reinforces the more important rule: cost optimization should happen after the recovery design is sound. A cheaper copy that does not survive the same disasters as the primary system is not equivalent protection.
Restore Time Can Be Worth More Than the Storage Savings
A backup is valuable only when it can restore the data within an acceptable window. Large cloud restores may be limited by download speed, provider retrieval behavior, or local write speed. A remote NAS can also be bandwidth-limited, but it gives you the option to physically move the backup system or drives to the recovery site if the situation allows it.
NAS Compares' backup-method guide emphasizes how network bandwidth changes the practicality of moving very large datasets to and from remote storage. That restore-path constraint should be treated as part of cost, because a multi-day recovery can be more expensive than the storage itself for a household business or creative workflow.
Test the slowest credible restore, not only the daily incremental backup. Estimate how long a full photo library, project archive, or business share would take to recover over the internet connection available after a primary-NAS failure. If the answer is measured in days, the second NAS may be justified even before its storage cost breaks even.
Cloud can still provide excellent recovery for smaller critical folders while the remote NAS holds the bulk archive. Splitting the dataset by recovery priority often produces a better result than forcing every byte into one backup destination.
Cloud Backup Still Wins When Simplicity and Elastic Capacity Matter More
Cloud backup removes a long list of ownership tasks. There is no second chassis to monitor, no remote drive to replace, no UPS to maintain at the other site, and no capacity upgrade to schedule when the backup pool becomes full. Those avoided tasks have value even when the storage bill is recurring.
WIRED's backup guidance recommends an off-site copy because physical separation protects against disasters that can remove local hardware together. That separate-copy principle is especially attractive when the user wants off-site resilience without becoming the administrator of another location.
Cloud also fits uncertain growth. If a new video project suddenly doubles the protected dataset, service capacity can usually expand without a hardware migration. A second NAS has a stronger economic case when growth is predictable enough that its drive plan will remain sensible.
For many homes, the cheapest strategy is not “all cloud” or “all second NAS.” It is a small cloud tier for the irreplaceable set and a larger local or remote hardware copy for bulky data whose recovery speed or long retention would be expensive to rent indefinitely.
Choose a Second NAS When Capacity, Location, and Recovery Speed Align
The second NAS becomes the stronger buy when four conditions are true together: the protected dataset is already large, future capacity is predictable, a genuinely separate location is available, and fast recovery of the full dataset has meaningful value. Miss any one of those and cloud often regains the advantage.
TechRadar's 2026 personal-cloud build guidance highlights the upfront hardware model of NAS ownership compared with recurring hosted services. That upfront-versus-recurring ownership model is exactly why the break-even point varies so much by dataset and retention horizon.
A ZimaBoard 2 - Mini Home Server for Your Big Idea can serve as a compact remote backup target when the protected set is bounded and two direct-attached drives are enough. A ZimaCube 2 Personal Cloud Home NAS is the clearer choice when the second site needs multi-bay capacity, longer retention, more concurrent access, or substantial room to grow.
Do the comparison with your real backup set and a fixed ownership horizon. If the second NAS wins only after assuming zero maintenance, zero drive replacement, free electricity, and no off-site-location cost, it has not actually beaten the cloud. If it still wins after those costs and materially shortens recovery, the hardware premium is buying both capacity and control.
Buying Guide
How to Choose Low-Power Hardware for Always-On Home Assistant
Compare Home Assistant systems by wall power and workload. Buy when energy, noise, reliability, or a measured service limit justifies replacement.
How to Choose a Home Assistant Server for a Shared Household
Size Home Assistant for household workloads, not headcount. Use measured peaks, durable storage, separate identities, and tested recovery to choose a host.
How to Choose a Home Assistant Server for Internet Outages
Outage-ready Home Assistant hardware starts with the local control path. Size power, storage, and recovery around actions that must continue without the WAN.
