A single 2.5GbE port is enough for many small-office NAS workloads when most users open documents, sync ordinary files, run staggered backups, and do not demand high-speed transfers at the same time. The port becomes the wrong purchase when aggregate concurrent traffic regularly approaches its roughly 2.5Gb/s line rate, when several creative or technical users move large files together, or when the office needs network-path redundancy. Size the uplink from simultaneous bandwidth, not headcount.
Start With the Aggregate Port Ceiling, Not the Number of Employees
A 2.5GbE link has a theoretical raw line rate of 2.5 gigabits per second, or 312.5 megabytes per second before protocol overhead. That is a shared ceiling for every client using that one NAS port at the same time. Ten light users can stay far below it, while two workstations copying large files can consume most of it.
ITPro measured a small-business TerraMaster NAS over one 2.5GbE link at about 2.2 to 2.3Gb/s for sequential transfers. That real-world result is a useful shopping reference: a single port can move substantially more than Gigabit Ethernet, but it is still one finite aggregate pipe.
Estimate the busiest five-minute window in the office. Add the large transfers that can overlap: workstation backups, video or CAD files, VM images, cloud-sync pulls, media exports, and normal file access. Do not add every theoretical client maximum if those workloads never occur together.
The ZimaSpace guide comparing HDD and SSD NAS storage also separates storage speed from the network ceiling. A faster array cannot deliver more than the uplink allows, while a slow two-drive HDD mirror may never fully use a faster port.
Small Office Traffic Is Usually Bursty, Not Permanently Saturated
Office documents, PDFs, spreadsheets, email attachments, and ordinary synced folders create short bursts rather than continuous high-rate traffic. That makes one 2.5GbE port surprisingly capable for a small team even when several people use the NAS all day. The problem begins when the workload changes from bursty access to sustained shared transfers.
A 2025 small-business networking guide makes the same distinction: two heavy media users can stress a 2.5GbE link while many office-document users may not. That is the correct buying axis for a small office NAS.
Schedule full-machine backups outside the busiest editing or collaboration window when possible. Rate-limit cloud replication if it competes with interactive file access. If those simple controls keep aggregate traffic well below the link ceiling, paying for 10GbE may not change user experience.
The stop boundary is when normal work requires those heavy transfers to overlap. If the team regularly waits for shared storage because a backup, ingest, or export job consumes the port, the network is no longer merely bursty and the uplink deserves more headroom.
Check Whether the Clients and Switch Can Even Use More Than 2.5GbE
A NAS uplink upgrade only helps when the path between server and clients can carry the extra traffic. If most workstations are still on 1GbE, Wi-Fi, or a switch with only 2.5GbE ports, installing 10GbE in the NAS may provide little immediate benefit to an individual user. It can still help aggregate traffic, but only if the switch has a faster uplink path.
XDA describes 2.5GbE as a practical sweet spot for many modern home and small-network deployments because it offers a large step over Gigabit without requiring every endpoint to move directly to 10GbE. That endpoint-compatibility trade-off matters just as much in a small office.
Inventory the switch, cabling, workstation adapters, Wi-Fi access points, and any router path used by the NAS. If one 10GbE NAS port would terminate into a switch whose other useful paths are all 1GbE, the faster NIC may be waiting on the rest of the network rather than solving an active bottleneck.
Upgrade the server uplink first when many 2.5GbE clients need to talk to it concurrently through a switch with 10GbE or faster uplinks. Upgrade endpoints first when one or two workstations are the only machines that need high-speed transfers and they are still limited to Gigabit.
A Single Port Also Creates a Single Network Failure Point
Bandwidth is not the only reason to want a second NIC. A small office that depends on the NAS for active projects, business documents, or application data may value a second network path for failover, maintenance, or separation between user traffic and another storage or management network. One 2.5GbE port cannot provide that by itself.
TechRadar’s 2026 Synology DS725+ review describes a setup using its 2.5GbE port for normal NAS traffic and a separate 1GbE line for potential failover. That redundant-path example shows why a second port can matter even when one 2.5GbE link is fast enough.
Do not buy dual ports and assume they automatically double speed. Link aggregation, SMB Multichannel, MPIO, bonding, and failover have different requirements and behavior. The switch, NAS operating system, client protocol, and network design all have to support the chosen method.
If downtime from a cable, switch port, or NIC failure is acceptable, one port remains a rational low-complexity design. If the office cannot work while a single network path is repaired, redundancy becomes a purchasing requirement independent of bandwidth.
Multiple 2.5GbE Ports Help Only When the Workload Can Use Them
Two 2.5GbE interfaces can provide more aggregate capacity or redundancy, but only when traffic is distributed across them. A single ordinary SMB transfer will not necessarily jump from one 2.5GbE port to an automatic 5GbE result. The architecture must intentionally support multiple paths or multiple clients.
ServeTheHome demonstrated SMB3 Multichannel across a multi-gigabit switch using multiple 2.5GbE paths from a NAS toward a faster client. That multi-path SMB example is useful because it shows that extra ports are valuable when the protocol and network are designed to exploit them.
For several office users, dual 2.5GbE can also be useful without one 5Gb/s client: different connections may distribute across links, keeping aggregate traffic from piling onto one port. But test the operating system and switch behavior rather than buying two ports from the assumption that aggregation is universal.
If the office wants one workstation to move files faster than a single 2.5GbE link and cannot or will not use a supported multi-channel design, a native 10GbE path is usually cleaner than trying to combine several smaller links.
Move to 10GbE When the Busy Window, Not the Benchmark, Crosses the Line
A single 2.5GbE port is a good stopping point when the busiest real office window stays comfortably below the practical link ceiling and file-access latency remains acceptable. Move beyond it when simultaneous large-file users, workstation backups, VM storage, database traffic, or creative workflows create repeated saturation during normal working hours.
UGREEN’s guidance for multi-user NAS performance notes that 1GbE or 2.5GbE can suit small offices while heavier concurrent large-file workloads benefit from 10GbE. The useful part is not the brand recommendation; it is the same aggregate-workload threshold.
| Office workload | Single 2.5GbE port | Upgrade signal |
| Documents, PDFs, shared folders | Usually enough | Rarely network-limited |
| Several scheduled PC backups | Often enough if staggered | Backups collide with interactive work |
| Large photo/CAD/project files | Depends on concurrency | Two or more active users regularly saturate the uplink |
| Video editing / large ingest | Can become restrictive quickly | Sustained transfers approach the port ceiling |
| VM or database storage | Workload-specific | Latency and aggregate bandwidth affect application response |
A ZimaBoard 2 already provides dual 2.5GbE, making it a sensible compact platform when a small office wants one primary multi-gigabit link plus room for a second path, segmentation, or supported multi-channel use. The 832 fits straightforward file sharing and everyday apps; the 1664 is the better fit when more containers, indexing, media, or virtual machines share the NAS.
A ZimaCube 2 Standard is justified when the office also needs six drive bays, longer retention, or more storage growth, not simply because it has multiple users. Move to ZimaCube 2 Pro when measured aggregate traffic, creative collaboration, or another defined workload makes its 10GbE port useful. A single 2.5GbE port is enough until the office can show where that shared 2.5Gb/s ceiling is being consumed.
Buying Guide
How to Choose a Plex Server for a Multi-User Household
A scenario-fit guide for households that turns “many users” into concrete playback, uptime, storage, and recovery requirements.
How to Choose Plex Server Hardware for Multiple Simultaneous Streams
A sizing-first buying guide for multi-stream Plex servers that prioritizes the workload bottleneck and deweights specs that do not raise real capacity.
Do You Need a Dedicated Plex Server? Who Should—and Shouldn’t—Buy One
A scenario-fit buying guide that makes “keep using your current PC” a valid answer when Plex does not need its own always-on hardware.
