For a quiet living space, choose Jellyfin hardware by sustained heat and storage noise first, then buy only the transcode capacity your client mix requires.
Set the room constraint before comparing hardware
Define the listening distance, acceptable idle noise, night-time temperature, and whether hard drives can live outside the room. A fanless box is not automatically quiet if its external disks vibrate, and a powerful desktop is not a good fit if its fan curve stays audible during every transcode.
Use the room as a hard filter: if storage must be silent, move bulk media to a separate enclosure and keep the Jellyfin compute node on SSD. The independent hardware-acceleration guidance from JellyWatch treats codec and transcode workload as the sizing input rather than a universal model recommendation (codec and transcode workload guide).
Establish the minimum useful performance
List the devices that will stream, the percentage that direct play, the number of likely simultaneous transcodes, subtitle use, and whether HDR tone mapping is required. Start with the lowest compute tier that passes one direct play and the measured transcode mix. Keep memory for the host and database, but do not use excess RAM to hide a missing hardware-video path.
Trade peak performance for thermal stability
Compare idle power, sustained package power, cooling layout, and storage vibrationโnot just CPU names. A lower-power processor with working hardware acceleration can be quieter than a faster CPU forced into software transcoding. Run a 30โ60 minute representative playback test and record fan speed, surface temperature, and playback mode.
Reject a candidate if it is quiet only at idle or if its thermal throttling causes playback to fall back to software. A ZimaCube 2 AI NAS is worth considering only when its storage and expansion roles fit the measured workload and the enclosure can be placed without adding audible drive noise.
Check storage, network, and maintenance noise
Use SSD for the application database and cache, isolate spinning disks with vibration control, and place backups on a schedule that does not overlap evening playback. A wired network reduces retransmits and avoids adding radio noise or placement compromises. Verify that the device can restart after a power interruption and that filters and fans are serviceable without moving the whole media rack.
Choose, skip, or defer
Choose efficient hardware when transcodes are predictable, storage can be isolated, and the sustained test stays below the roomโs noise boundary. Choose a separate compute and storage layout when drive vibration is the problem. Skip an upgrade when current hardware direct-plays the household library and the only complaint is a fixable fan curve or disk placement.
Buying Guide
