Choose hardware for Plex and Overseerr by sizing Plex first, then adding enough memory, persistent storage, and service isolation for the request-management stack.
Let Plex Set the Compute Floor
Overseerr does not transcode video, so it should not be the reason to buy a much larger CPU. The compute floor comes from the hardest Plex playback path: Direct Play, hardware transcode, software fallback, subtitles, and the number of concurrent sessions.
On one N100 host, a 4K HDR stream that stuttered under CPU conversion became smooth after the transcode moved to the GPU, showing why the acceleration path belongs in the purchase gate.
Define the hardest required Plex session before comparing processors. If the candidate cannot pass that session, extra RAM for Overseerr will not rescue the purchase.
Treat Overseerr as Persistent Service State, Not a Second Media Engine
Overseerr adds its own configuration, database, user workflow, and network endpoint. That increases backup and container-management responsibility more than video-processing demand.
Plex, Overseerr, download tools, monitoring, and related services can coexist in one Plex and Overseerr stack, so the purchase should account for the whole service graph rather than only the Plex binary.
Reserve persistent storage for Overseerr config and enough memory that the request layer can remain responsive while Plex is busy. Keep its state on a documented volume so a container replacement does not become a rebuild from memory.
Budget for the Other Services That Usually Arrive With It
The heavier purchase risk is rarely Overseerr alone. Downloaders, indexers, automation, backups, and monitoring may share the same host and create CPU, memory, and storage overlap.
Explicit container resource limits matter once several services share the box, because Docker otherwise allows a single workload to consume all available host resources.
List the services you actually plan to run in the first year and test the busiest overlap. Upgrade memory or storage only when that stack—not a hypothetical future lab—crosses a measured constraint.
Choose One Box Unless a Heavy Companion Justifies a Split
An all-in-one server is the simplest choice when Plex passes its peak workload and companion apps remain light. A second machine becomes useful when AI, backups, or other heavy work must run concurrently and repeatedly degrades Plex.
The same decision appears in separating Plex from heavier compute: split roles when the workload demands it, not because the application list looks long.
Buy one host when it passes the combined peak with recovery headroom. Choose a two-box design only when a specific companion workload needs independent compute, storage, or upgrade timing.
Buying Guide
How to Compare Three or More Jellyfin Server Candidates Without Chasing Specs
Eliminate Jellyfin candidates that fail the workload first, then compare only decision-changing specs, ownership cost, and recovery between the survivors.
How to Evaluate Warranty, Replacement, and Recovery Costs for Jellyfin
The cheaper Jellyfin server is the one with the lower recoverable ownership cost, not necessarily the lowest checkout price or longest warranty.
Which Jellyfin Workloads Actually Benefit From More CPU Cores?
Buy more CPU cores only when measured Jellyfin work is CPU-parallel; Direct Play and hardware-accelerated video usually shift the limit elsewhere.
