Thank you to u/Electronic-Sun3344 for sharing a ZimaOS homelab assembled from equipment already in the basement. An HP EliteBook 840 G3, an older hard drive and reused networking equipment now support household services and a small deployment workflow. The project gives an old laptop several concrete jobs before requiring a new hardware purchase.
The original EliteBook story includes both the physical arrangement and application screenshots. Together they show a reused computer becoming a place for DNS, photos, media and development work, with the owner's experiments continuing alongside those everyday tasks.
A Basement Find Becomes a Household Service Host
Starting with existing equipment changes the first decision. The owner can learn what the household actually uses before buying a different server. The useful result is a set of working tasks and an understanding of their needs, rather than a hardware specification chosen in advance.
The creator describes no new spending on the assembled equipment. That is a reuse story, not a universal zero-cost buying guide. The components were already available to this owner, and the source does not provide a complete energy or long-term maintenance budget.
For readers comparing dedicated storage hardware for this service category, the ZimaCube 2 personal cloud NAS is a separate hardware reference. The machine documented in this story is the owner's repurposed EliteBook.
The Basic Hardware Leaves the Workload Easy to Identify
| Part | Owner-reported detail |
| Computer | HP EliteBook 840 G3 |
| Processor | Intel Core i5; exact model not specified in the post |
| Memory | 16 GB |
| Storage | 500 GB SSD and an older HDD from a 2013 computer |
| Platform | ZimaOS |
The hardware list is enough to explain the project's scale without assigning a capacity or connection method to the older drive. Those missing details matter if another reader wants to reproduce the storage arrangement, so they should remain open.
Our rebuilt laptop motherboard running ZimaOS offers another reuse case. This creator kept a more recognizable laptop-based arrangement, while both stories give an existing computer a defined server role.
The Dashboard Connects Several Different Routines
The listed services cover household infrastructure, media and development. Those jobs share a machine, but they have different audiences. A DNS interruption affects ordinary browsing; a deployment task serves a development workflow; a photo library needs its files and metadata to remain usable.
A useful operating record would therefore pair each application with its purpose and persistent data. That makes it easier to decide which changes can be experimental and which ones need a planned maintenance window.
The source also lists an Omarchy Linux virtual machine as an experiment. That adds another learning task without establishing that every household service runs in a VM. The application inventory should not be turned into an invented virtualization diagram.
DNS Becomes Part of the Household's Everyday Dependency Chain
The owner reports using Pi-hole and Unbound together. The official Pi-hole and Unbound guide explains the roles of filtering and recursive resolution. They are related functions, while the actual client and router configuration determines how the household uses them.
In the source discussion, a secondary DNS arrangement is still being considered. That is a useful distinction: an application running successfully today and a plan for its host being unavailable are separate milestones.
For another builder, a practical check would follow an ordinary client request and record which resolver it uses. A maintenance test would then establish what happens when that service is unavailable. This is reader guidance, rather than a failover result attributed to the owner.
A GitHub Push Has a Visible Deployment Path
The Jenkins screenshot gives the development role a concrete shape. It presents a successful run through named stages, so deployment appears as a sequence the owner can inspect rather than a single unexplained action.
The Jenkins Pipeline handbook describes a versioned way to express build, test and deployment work. For a home project, that makes the process itself something that can be reviewed and improved alongside the application.
The image does not reveal the full pipeline definition, the implementation of its health check or a rollback exercise. A reader adapting the idea would still need to decide what a successful deployment should prove. A process that starts a container and a process that confirms a useful application are different levels of validation.
The Photo Library Needs Its Database as Well as Its Files
The photo-management role puts personal data on the same host as the experiments. That makes recovery planning a practical part of the setup, even if the hardware began as a no-new-purchase project.
The Immich backup and restore documentation explains that a comprehensive recovery copy needs the uploaded photos and videos together with the database. A database backup alone does not contain the media files.
For a similar household installation, the useful record identifies both locations and a compatible restore process. The source screenshot shows an application in use; it does not establish that the creator has performed a complete recovery test.
Software Readings Need a Clear Measurement Boundary
The post lists different power figures from ZimaOS and btop. It does not establish that these readings measure the whole laptop, networking equipment and attached storage at the wall. They should therefore remain software observations rather than become a complete electricity-cost claim.
The same principle applies to an operating-period report. The owner describes the setup as useful over time, but the post is not an independent availability study. Another builder can evaluate their own system by recording actual household tasks, interruptions and recovery checks.
The Pi-hole-to-family-server story offers a companion example of a small service becoming part of a larger household routine.
Does another builder need to buy the same laptop?
The story demonstrates reuse of equipment the creator already had. It does not establish that model as a required purchase.
Is a working DNS failover arrangement documented?
No. The source discusses a further change under consideration rather than a completed test.
Does the Jenkins screenshot include the complete pipeline?
It shows the stages of one run, without supplying the full configuration or recovery procedure.
Does a photo-server screenshot prove a recoverable backup?
No. Recoverability depends on the saved media, database and a usable restore process.
Conclusion
This reused EliteBook is useful because it connects old hardware to several recognizable routines. DNS supports everyday access, the photo library organizes personal data, and the deployment pipeline gives development work a repeatable path. Making those responsibilities and their recovery needs explicit is the next step in turning a successful experiment into a maintainable household server.
Zima Campaign Hub
A Ryzen ZimaOS Media Server Built from Parts Already on Hand
A Ryzen 2700X tower starts with ZimaOS, Jellyfin, Pi-hole and Tailscale, while storage upgrades and energy readings stay in their reported context.
A ZimaOS Home Server Made Easier to Use with Homarr
A first-time self-hoster uses Homarr to organize a ZimaOS home server, with selected remote access and a physical setup still being improved.
A ZimaBlade TrueNAS Storage Host in a Shelf-Sized Apartment Homelab
An apartment homelab puts ZimaBlade TrueNAS storage beside a Raspberry Pi, Mac mini and automated fans, with two 14 TB disks and a separate...
