You have a photo library. Years of memories. Albums you carefully organized. Faces you tagged. Shared links you sent to family.
Then you upgrade your NAS — and realize moving the files is not enough. Without the database, you lose every album, every face tag, every memory you curated. The photos are there, but the organization is gone.
I just moved 14,505 photos and 925 videos — 134 GiB total — from a DIY ZimaOS server to the ZimaCube 2. Every album survived. Every face tag came through. Every shared link still works.
Here is exactly how I did it, what almost went wrong, and what the ZimaCube 2 brought to the table that my old setup could not.
Why Immich, Why Now
Immich has become the go-to self-hosted photo solution for a reason. It gives you Google Photos-level features — facial recognition, semantic search, automatic backups from your phone, shared albums — without sending your photos to someone else's server.
But Immich stores its soul in PostgreSQL. The database holds albums, face vectors, people clusters, CLIP embeddings for smart search, and every piece of metadata that makes the library feel like yours. Move the files without the database, and you get a folder full of photos and a blank Immich instance.
This migration had one rule: zero data loss. The old server would not be wiped until the new one was verified.
What Immich Actually Stores (and Why It Matters)
Before touching any files, I mapped out exactly what needed to move:
| Component | Location | Contents | Must Migrate? |
| pgdata | /DATA/AppData/immich/pgdata | Full PostgreSQL — albums, faces, people, metadata | ✅ Critical |
| model-cache | /DATA/AppData/immich/model-cache | Downloaded CLIP/facial recognition models | ✅ Saves re-download |
| Photo library | /DATA/Gallery/immich | 14,505 photos + 925 videos + thumbnails (134 GiB) | ✅ Actual media |
| Auto-backups | /DATA/Gallery/immich/backups | Last 14 daily database snapshots | 💡 Already present |
Immich also creates automatic database backups daily at 2:00 AM, keeping the last 14 in the backups directory. Before running a manual dump, check if a recent auto-backup is already sitting there.
The Method: ZimaOS Files App (LAN Copy)
Both machines run ZimaOS on the same LAN. That meant I could use the built-in Files app for a direct LAN transfer — no external drives, no SCP commands, no intermediate storage.
Step 1: Mount the Source Machine
On the ZimaCube 2, open the Files app → + Add Storage → LAN Storage → enter the source machine local IP and authenticate. The source machine filesystem now appears as browsable storage on the ZimaCube 2.
Step 2: Stop Immich on the Source
This is the step people skip and regret. Stop Immich before copying. A running PostgreSQL instance is constantly writing — you need the database in a consistent, flushed state. On the source machine: ZimaOS App Store → Immich → Stop.
Step 3: Copy Both Directories
From the ZimaCube 2 Files app, navigate to the mounted source and select:
| Source Path | Destination Path on ZimaCube 2 |
| /DATA/AppData/immich | /DATA/AppData/immich |
| /DATA/Gallery/immich | /DATA/Gallery/immich |
Select both locations, hit Migrate. Choose: Overwrite at destination and Retain originals on source — do not delete the source until verified.
Step 4: Install Immich on the ZimaCube 2
Open the ZimaOS App Store and search for Immich. Critical warning: the App Store may show multiple Immich variants. You must install the exact same variant your source machine uses:
Immich (official ZimaOS/CasaOS app) — use this if that is what you had before
BigBearCasaOS Immich — different docker-compose variables, different postgres credentials, different database name — incompatible with a direct pgdata copy from the official app
After installation, do not start the app immediately. Immich will detect the existing pgdata directory on first launch and connect to it rather than initializing a new empty database.
Step 5: Log In With Existing Credentials
Open Immich at http://192.168.x.x:2283 and log in with the same username and password from the source instance. Your full library — albums, faces, people, settings — will be exactly as they were.
Step 6: Verify Job Queues
Navigate to Profile → Administration → Job Queues. After a pgdata migration, the database already contains all previously processed results, so most queues should show Active: 0 / Waiting: 0.
If any queue shows a count under Missing, click the Missing button to process only unprocessed assets:
| Queue | When to Run Missing |
| Generate Thumbnails | If any photos show blank previews |
| Extract Metadata | If assets are missing GPS/location/date |
| Smart Search | If semantic search returns no results |
| Face Detection | If face data appears incomplete |
The Migration Stats
| Metric | Value |
| Photos migrated | 14,505 |
| Videos migrated | 925 |
| Total data | 134 GiB |
| Transfer time (2.5GbE) | ~12 minutes |
| Albums preserved | All |
| Face tags preserved | All |
| Shared links preserved | All |
| Data loss | Zero |
Why the ZimaCube 2 Made This Worth Doing
I did not migrate just to land on the same experience. The ZimaCube 2 brings three upgrades that my old DIY ZimaOS box could not match:
2.5GbE transfers. Photo libraries grow. Every full backup, every large import, every migration benefits from the 2.5× bandwidth over standard gigabit. The ZimaCube 2 dual 2.5GbE means I can saturate a backup while the rest of the network stays responsive.
NVMe storage for the database. Immich PostgreSQL database performs dramatically better on NVMe than spinning rust. Thumbnail generation, smart search queries, face recognition — all of it reads from pgdata. On the ZimaCube 2 NVMe pool, database operations that previously stuttered on HDD are now instant.
6-bay expandability. 134 GiB today. What about next year? The ZimaCube 2 has six SATA bays plus four M.2 slots in the 7th Bay, meaning this photo library can grow for years without hitting a storage wall.
Migrate your photo library to ZimaCube 2 →
Building your self-hosted photo setup? Read our Personal Cloud Storage Device guide, our Docker & CI/CD on ZimaCube 2 deep dive, and our ZimaCube 2 Pro Unboxing.
Frequently Asked Questions
Can I migrate Immich to the ZimaCube 2 without losing my albums and face tags?
Yes — but you must copy both the photo files and the pgdata directory (PostgreSQL database). The database stores all albums, face vectors, people clusters, and metadata. Moving photos alone gives you files without organization. Copy both directories together, and your library survives intact.
What is the fastest way to transfer Immich data to the ZimaCube 2?
If both machines are on the same LAN and run ZimaOS, use the built-in Files app with LAN Storage mounting. Over the ZimaCube 2 2.5GbE connection, 134 GiB transfers in about 10–15 minutes. For larger libraries or machines on different networks, an external USB drive is the next best option.
Does the Immich App Store version matter when migrating?
Yes — critically. The ZimaOS App Store may show multiple Immich variants (official vs BigBearCasaOS). They use different docker-compose variables — postgres credentials, database names, and network configs are incompatible. Install the exact same variant your source machine uses, or the restored database will not connect.
Do I need to stop Immich on the source before copying?
Yes. A running PostgreSQL instance writes continuously. Copying a live database risks an inconsistent state. Stop Immich on the source machine, copy the folders, then start it on the destination. The source machine can remain off or stay on as a backup until you have verified the migration.
How much storage does Immich need on the ZimaCube 2?
Plan for your photo library size plus room for the PostgreSQL database (which grows with your library), thumbnail cache, and transcoded video versions. A 134 GiB library with 14,500 photos uses roughly 150–160 GiB total with overhead. The ZimaCube 2's six SATA bays give you room to grow.
Zima Campaign Hub
A ZimaBoard 2 Prototype with Two 22 TB Drives on the Test Bench
Explore sabitech2k’s early ZimaBoard 2 drive test, the reported power conditions, and the existing ZimaBoard used for Proxmox backups.
A Quiet ZimaCube and ZimaBoard Homelab with Debian and Docker
A ZimaCube and ZimaBoard split everyday applications from smart-home services, with Debian, Docker, Pi-hole and a Homepage dashboard.
A LEGO Rack for a First ZimaBoard 2 Home Server
See how a first-time builder organized a ZimaBoard 2 and two SSDs in a LEGO rack, with Home Assistant and home-office storage planned next.
