Why Jellyfin May Reprocess Existing Media After an Upgrade
Jellyfin may reprocess existing media after an upgrade when analysis logic or stored media attributes change, even though source files remain untouched.
A new version can need fresh analysis data for playback or matching, creating CPU and disk activity across an existing library. That finite queue is different from a scan, metadata refresh, or a job that repeats forever. Watch progress and completion before treating the activity as a fault.
Analysis Data Can Change Without Media Changes
The server may learn additional properties or correct how it interprets existing files. Recomputing those attributes does not require the source file timestamp to change.
The post-upgrade analysis model explanation of post-upgrade analysis shows why a finite version-triggered queue can be normal.
The first question is whether the queue progresses and settles, not whether any media was added.
Re-Analysis, Scanning, and Refresh Are Different
A scan checks paths for additions or removals, metadata refresh updates descriptive information, and media analysis inspects file properties used for playback. They can overlap in dashboards but have different triggers and I/O patterns.
Use the persistent data roles state model to keep database and metadata work separate from the media files themselves.
If the same items repeat without progress, the explanation has moved beyond a one-time analysis change.
The Normal Boundary Is Finite Work
A normal post-upgrade queue grows or progresses, reaches completion, and remains complete after a restart. Repeated identical jobs, missing paths, permissions errors, or database errors point to an operational condition instead.
The post-upgrade analysis model distinction between a finite queue and recurring work provides the key boundary.
Do not interrupt a progressing queue simply because it is busy; do investigate work that never drains or returns after every restart.
Verify Completion Before Intervening
Record queue size, items processed, CPU/I/O activity, and whether completed items remain complete after one controlled restart. Avoid forcing scans or refreshes during the observation window.
Use the cold and warm benchmark benchmark discipline to hold background work and cache state steady while you observe the queue.
Stop when the queue drains and normal idle behavior returns. Escalate only when repetition, errors, or path loss persists under the same conditions.
