What Is Trace Sampling, and When Can It Hide an AI Workflow Failure?
Trace sampling keeps only selected request traces, reducing storage and processing while risking the loss of the exact workflow path needed for diagnosis.
A local AI request can cross a gateway, model router, vector search service, tool sandbox, and home automation bridge, producing many spans per interaction. Recording every path indefinitely is expensive. Sampling decides which complete traces or partial observations survive, but the time and criteria of that decision determine whether a rare timeout, denied tool call, or silent fallback remains visible.
Trace Sampling Selects Request Histories, Not Individual Facts
A trace represents one request as related spans across services. Sampling chooses whether that request history is recorded or exported, usually by probability, attributes, or a policy. Metrics and logs may still exist, but they cannot reconstruct the same causal path unless they retain compatible identifiers.
The sampling concepts documentation separates head sampling, decided near request start, from tail sampling, decided after most spans arrive. Head sampling is simple and cheap, while tail sampling can retain traces according to final latency, error status, or attributes discovered later.
Sampling therefore changes diagnostic coverage rather than application behavior. A request can complete or fail identically whether its trace is kept, yet the operator sees a different body of evidence after the event. This distinction remains visible during later household testing.
Head Decisions Cannot See a Failure That Happens Later
A probability decision made on the root span cannot know that the final tool call will time out or that a downstream service will return an error. If the request is dropped at the head, all later spans may be unavailable even though the event is operationally important.
An OpenTelemetry tail-based retention example describes retaining failed activities with a tail-oriented approach. It illustrates the central advantage: the decision can use the completed outcome instead of guessing importance from attributes present at the beginning.
Head sampling still works for broad performance trends when rates are stable and identifiers are propagated consistently. It becomes risky when failures are rare, clustered by a low-volume route, or discoverable only after several agent steps.
Tail Policies Add State, Delay, and Their Own Blind Spots
Tail sampling buffers spans until a decision window closes, groups them by trace ID, and applies ordered policies. Late spans, split routing, collector restarts, memory pressure, or a window shorter than the workflow can leave the sampler with an incomplete trace.
The collector requirements warns that all spans for a trace must reach the same collector instance and that pending spans consume memory. Those requirements matter on a small home server where the observability process competes with inference for RAM.
The failure boundary is a workflow whose decisive error span arrives after the sampler decides, reaches another collector, or lacks the status attribute used by policy. Tail sampling improves selection only when trace assembly itself remains reliable.
Run a Known-Failure Trace Coverage Test
Create controlled workflows that fail at the router, retrieval service, model server, tool sandbox, and final home automation call. Assign a test correlation ID, record the expected span sequence, and repeat each failure enough times to exercise the configured probability and tail policies.
Use the service map in end-to-end tracing to verify that every kept failure trace contains its root, intermediate calls, final error, and relevant policy attributes. Separately count failed requests in an unsampled metric so missing traces can be detected rather than mistaken for absent failures.
Pass only when critical failures are retained at the required rate and incomplete traces are explicitly measurable. Reserve always-sample rules for high-value error classes, cap buffer memory, and test collector restart and late-span conditions before relying on traces for incident reconstruction.
