What Is Diarization Error Rate, and What Does It Exclude From Speech Accuracy?
Diarization Error Rate measures time assigned to missed speech, false speech, or the wrong speaker, not whether the spoken words were transcribed correctly.
A meeting archive can achieve a low DER while spelling names badly, omitting key words, or labeling speakers with anonymous but internally consistent IDs. Conversely, accurate transcription can have poor diarization if every word is assigned to the wrong person. DER is useful only when its scoring rules and companion speech metrics match the intended search or review task.
DER Adds Three Time-Based Error Components
Missed speech is reference speech the system marks as silence, false alarm is nonspeech marked as speech, and speaker confusion is speech attributed to the wrong reference speaker after optimal label mapping. Their durations are summed and divided by total reference speech.
The DER definition reference defines diarization error rate and exposes parameters for collars and overlapping speech. These choices affect what time intervals enter the numerator and denominator, so a reported DER is incomplete without the evaluation configuration.
Because the metric is duration-based, one long misassigned segment can outweigh many brief boundary errors. It also allows values above one hundred percent in difficult cases when overlapping or excess hypothesized speech produces accumulated error.
Collars and Overlap Rules Change the Score
A collar excludes a small region around annotated speaker boundaries, acknowledging that exact transition times can be ambiguous. Some evaluations score overlapping speech while others skip it; ignoring overlap usually makes a household conversation with interruptions look easier.
The original diarization scoring paper states the false-alarm, missed-detection, and confusion formula and notes support for overlapping speech. It also documents related purity and coverage measures that reveal clustering behavior not summarized by one DER.
Two systems can therefore report different DERs on the same audio because of annotation, collar, overlap, or speaker-count assumptions. Reproducible comparison requires identical reference files, preprocessing, and scoring options. This distinction remains visible during later household testing.
Word Accuracy and Speaker Identity Remain Outside DER
DER does not measure word error rate, punctuation, timestamps at the word level, semantic completeness, language identification, or whether anonymous speaker A is correctly named Alice. It evaluates who spoke when, under the reference and mapping rules.
A practical DER components breaks DER into missed speech, false alarm, and confusion and explains how overlap contributes to errors. That decomposition helps determine whether voice activity detection or speaker assignment is the limiting stage.
The failure boundary is using a low DER as proof that an audio archive is searchable or factually correct. Search also needs transcription quality, word-to-speaker alignment, identity resolution, and retrieval evaluation on the household vocabulary.
Score Speaker Timing and Words Separately
Create representative audio with quiet speech, interruptions, television noise, distant speakers, and overlapping conversation. Annotate speaker turns and exact words, then compute DER with declared collar and overlap settings plus word error rate and speaker-attributed word error rate.
Use the searchable-audio stages in searchable home audio to test whether each retrieved word points to the correct speaker and timestamp. Inspect error components by room and acoustic condition rather than relying on a single aggregate percentage.
Pass only when diarization and transcription both meet their task-specific thresholds. Keep anonymous clustering and real identity assignment as separate evaluations, and publish scoring settings whenever DER is compared across models or releases. The intermediate result must remain inspectable before automation follows.
