Quick Answer
AI NAS hardware requirements depend on the workload, not on the AI NAS label alone. A system that performs background OCR or photo indexing needs a very different hardware profile from one running local LLMs, real-time camera detection, long-context RAG, or multi-user inference.
For many storage-first AI workloads, a practical starting configuration is:
- A modern multi-core CPU
- 16GB of system RAM
- HDD storage for protected source files and bulk capacity
- An SSD or NVMe tier for applications, databases, thumbnails, indexes, and models
- 1GbE or 2.5GbE networking, depending on file size and user count
- Optional iGPU, NPU, TPU, or GPU acceleration when the target software supports it
More demanding systems may need 32GB to 64GB or more RAM, larger NVMe capacity, a discrete GPU or high-capacity unified memory, stronger cooling, and 10GbE networking when AI compute runs on a separate server.
There is no universal minimum specification for every AI NAS. The correct configuration depends on:
- The AI task
- The size of the file library
- Whether processing is real-time or background
- The model and context size
- The number of concurrent users
- Whether the AI runs directly on the NAS or on another local machine
- Whether the software can use the selected accelerator
The most important rule is simple: start with the workload, then size CPU, memory, acceleration, storage, network, and cooling around that workload.
What Do AI Server Requirements Actually Depend On?
An AI NAS performs two different jobs at the same time. It must remain a dependable storage system while also processing the data stored on it.
A traditional NAS may mainly handle:
- File sharing
- Computer and phone backups
- Snapshots and version history
- Media storage and streaming
- User permissions
- Remote access
An AI-aware system may add:
- OCR and document parsing
- Photo recognition
- Object detection
- Speech transcription
- Embedding generation
- Vector and hybrid search
- Private RAG
- Local LLM inference
The difference between these two roles is explained further in AI NAS hardware compared with traditional NAS requirements .
Workload Type
Different AI tasks stress different parts of the system.
| Workload | Main Hardware Pressure | Typical Processing Pattern |
| OCR and document indexing | CPU, system RAM, database storage, and NVMe latency | Usually batch or background processing |
| Photo recognition | CPU, RAM, thumbnails, embeddings, and optional vision acceleration | Heavy initial import followed by incremental updates |
| Semantic search | RAM, active storage, embedding model, and vector index | Background indexing with interactive retrieval |
| Private RAG | Document extraction, RAM, NVMe, retrieval services, and optional generation hardware | Background ingestion plus interactive questions |
| Security camera detection | Video decoding, detector acceleration, continuous storage writes, and network stability | Continuous real-time processing |
| Local LLM chat | RAM or VRAM, memory bandwidth, context cache, and model loading | Interactive inference |
| Multi-user AI services | Memory capacity, concurrency, GPU throughput, and cooling | Sustained parallel inference |
Background vs Real-Time Processing
Background workloads can tolerate slower hardware because they can run overnight or during periods of low storage activity.
Examples include:
- Scanning a new photo library
- Generating thumbnails
- Running OCR on incoming scans
- Building embeddings
- Updating document indexes
Real-time workloads require lower latency and more sustained performance.
Examples include:
- Security camera object detection
- Interactive local LLM chat
- Live transcription
- Several simultaneous RAG users
- Real-time multimodal inference
A NAS may run background indexing successfully on modest hardware while delivering a poor experience for interactive LLM inference. Processing urgency is therefore as important as the task itself.
Model and Library Size
Hardware demand grows through two independent dimensions:
- The size of the AI model
- The size of the data library being indexed
A small model can still create a heavy workload when it must process millions of images, hundreds of thousands of documents, or years of video.
A large model can create high memory pressure even when the document collection is small.
Plan for both:
- Model files
- Context and runtime memory
- Application databases
- Thumbnails and previews
- OCR output
- Embeddings and vector indexes
- Temporary processing files
- Growth of the original data library
Number of Users and Parallel Requests
A system that serves one person intermittently has different requirements from a shared service handling several simultaneous queries.
The official Ollama memory and concurrency documentation explains that concurrent model loading depends on available system RAM or VRAM. It also notes that parallel requests increase the effective context allocation and that required memory scales with parallel requests and context length.
This means that sizing a local model only by its download size is incomplete. The system also needs memory for:
- Runtime overhead
- Context and KV cache
- Parallel requests
- Additional loaded models
- NAS services and containers
AI on the NAS vs Separate Compute
Running AI directly on the NAS reduces data movement and may simplify storage-adjacent workflows. Separating AI compute gives users more freedom to upgrade GPUs, memory, cooling, and model runtimes independently.
Run the workload directly on the NAS when it is:
- Closely connected to stored files
- Light or moderate
- Mostly background processing
- Supported by the NAS operating system and applications
- Unlikely to disrupt backup and file services
Consider a separate AI server when the workload is:
- GPU-intensive
- Real-time
- Multi-user
- Frequently updated or experimental
- Too hot, noisy, or power-hungry for the NAS
Three Practical AI NAS Hardware Tiers
The following tiers are planning profiles rather than universal vendor minimums. Actual requirements vary by application, model, context length, quantization, data volume, and user concurrency.
| Hardware Tier | Typical Workloads | System RAM | Acceleration | Active Storage | Network |
| Tier 1: Storage-First AI | OCR, metadata extraction, light photo indexing, small embeddings, basic classification | 16GB is a practical starting point | CPU or supported iGPU/NPU optional | SSD or NVMe for apps and databases | 1GbE may be sufficient; 2.5GbE adds headroom |
| Tier 2: Integrated Local AI | Photo recognition, document RAG, semantic search, multiple containers, small local models | 32GB is a stronger planning target | Supported iGPU, NPU, TPU, or entry-level GPU | NVMe for models, indexes, databases, and containers | 2.5GbE is practical; 10GbE for high-volume external access |
| Tier 3: Heavy AI Server | Larger LLMs, long context, multi-camera AI, multimodal inference, multiple users | 64GB or more depending on model and concurrency | Discrete GPU or high-capacity unified memory | Larger NVMe working tier with protected source storage | 10GbE becomes more relevant when compute is separate |
Tier 1: Storage-First AI and Background Indexing
This tier is appropriate when storage remains the main responsibility and AI runs as a background enhancement.
Typical workloads include:
- OCR for scanned documents
- Basic document classification
- Metadata extraction
- Light photo tagging
- Small embedding jobs
- Occasional local queries
A dedicated GPU may not be necessary. CPU processing can be acceptable when users are willing to wait for background jobs.
Important priorities are:
- Enough RAM for applications and databases
- An SSD or NVMe tier for active app data
- Reliable HDD capacity for source files
- Stable storage and backup behavior
Tier 2: Integrated Local AI and Private RAG
This tier fits users running several AI-aware applications on the same system.
Examples include:
- Photo recognition and semantic media search
- Private document search
- Local RAG
- Vector databases
- Multiple Docker applications
- Lightweight local LLMs
At this level, 32GB RAM provides more room for databases, indexes, application containers, caching, file services, and local generation.
The hardware differences between local photo AI and document RAG workloads are important because visual indexing and private document retrieval create different CPU, memory, storage, and acceleration demands.
Tier 3: Heavy Inference and Multi-User AI
This tier is closer to a dedicated local AI server than a conventional low-power NAS.
- Larger local language models
- Long-context document analysis
- Multiple simultaneous users
- Real-time multi-camera detection
- Multimodal models
- Image generation
- Several models loaded concurrently
Users should plan for:
- More system RAM
- Sufficient VRAM or unified memory
- Strong cooling
- Higher power draw
- Fast NVMe storage
- More separation between AI compute and core NAS services
A comparison of a used server, mini PC, and NAS for local AI workloads can help determine whether a storage-first enclosure remains the right compute platform.
How Much Memory Does an AI NAS Need?
Memory is often the first limit users encounter because AI NAS workloads consume several different memory pools.
The most useful planning formula is:
Practical Memory Requirement = Model Weights + Runtime Overhead + Context Cache + Parallel Requests + Databases and Indexes + NAS and Container Headroom
System RAM, VRAM, and Unified Memory Are Different
| Memory Type | Primary Role | Typical AI NAS Use |
| System RAM | General operating memory | File services, containers, databases, CPU inference, OCR, indexes, and virtualization |
| VRAM | Dedicated GPU memory | GPU-resident models, context cache, vision models, and accelerated inference |
| Unified memory | Shared memory pool available to CPU and GPU | Flexible model loading when supported by the platform and runtime |
System RAM is required even when inference runs on a GPU. The NAS operating system, file services, databases, containers, indexes, and background applications continue to use system memory.
VRAM determines how much of a model can remain on the GPU and how much room is available for context and parallel requests.
Unified memory can reduce the rigid division between system RAM and VRAM, but it remains limited by total capacity, bandwidth, software support, and thermal behavior.
Why Model Size Is Only the Starting Point
A model file that appears to fit inside available memory may still require additional headroom for:
- Runtime libraries
- Temporary buffers
- Prompt processing
- Parallel requests
- Other loaded models
- The operating system and applications
Ollama can report whether a model is loaded entirely on GPU, entirely in system memory, or split between CPU and GPU. Its documentation also explains that multiple models can remain loaded only when sufficient memory is available. Ollama model-loading and memory behavior provides the relevant runtime details.
Context Length, KV Cache, and Concurrency
Longer context windows increase memory requirements because the runtime must retain more attention state.
Parallel users increase the requirement again. A server handling several simultaneous requests may allocate substantially more context memory than a single-user system.
When planning local LLM hardware, test:
- The actual context length required
- The number of simultaneous users
- The number of models kept loaded
- Whether GPU inference requires complete VRAM residency
- Whether KV cache quantization is supported
What 16GB, 32GB, and 64GB+ Can Realistically Support
| System RAM | Reasonable Planning Direction | Main Limitation |
| 16GB | NAS services, a few containers, OCR, light photo indexing, metadata extraction, and small databases | Limited room for several heavy apps or larger local models |
| 32GB | Multiple containers, photo AI, document search, vector database, private RAG, and light local generation | Model and concurrency limits still depend on acceleration and runtime |
| 64GB+ | Larger indexes, multiple users, virtualization, heavier CPU or unified-memory inference, and several AI services | More memory does not solve weak acceleration, storage latency, or software incompatibility |
These ranges are not guarantees. A well-optimized application may use less, while a large library, long context, several services, or multiple users may require more.
Quantization and CPUโGPU Offloading
Quantization reduces model memory requirements by storing weights at lower precision. The tradeoff can include reduced accuracy or changes in performance, depending on the model and quantization format.
llama.cpp CPUโGPU hybrid inference can partially accelerate models that are larger than total VRAM capacity by dividing work between CPU and GPU.
This expands compatibility but should not be treated as equivalent to loading the complete model into fast GPU memory. Offloading may reduce speed because data must move across memory and bus boundaries.
What CPU Does an AI NAS Need?
CPU Responsibilities Beyond AI Inference
The CPU coordinates the complete system even when a GPU, NPU, iGPU, or TPU performs part of the inference workload.
The CPU may handle:
- NAS file services
- Encryption
- Container orchestration
- Database operations
- Document parsing
- Image preprocessing
- Media decoding
- Network traffic
- Feeding data to accelerators
A powerful accelerator can remain underused when the CPU cannot prepare, decode, or deliver data quickly enough.
Mixed NAS and Container Workloads
AI NAS systems often run several services simultaneously:
- SMB or NFS file sharing
- Backup jobs
- Media servers
- Photo applications
- Document databases
- Vector search
- Model runtimes
Multiple cores and threads provide more scheduling headroom for these mixed workloads. Core count alone is not enough, however. Architecture, instruction support, clock behavior, video engines, power limits, and software compatibility also matter.
Before choosing hardware, align the operating system with the intended mix of storage and applications. The home server OS requirements for NAS and Docker applications explain why storage-first, app-first, and virtualization-first systems prioritize hardware differently.
When CPU-Only AI Is Practical
CPU-only processing can be practical when:
- The workload runs in the background.
- The file library is modest.
- The model is small or heavily quantized.
- Latency is not critical.
- Only one user runs occasional requests.
CPU-only setups become less attractive when users expect:
- Fast interactive LLM responses
- Several simultaneous users
- Real-time video analysis
- Large multimodal models
- High-volume embedding generation
Does an AI NAS Need an NPU, TPU, iGPU, or GPU?
An AI NAS does not automatically need a discrete GPU. It needs an accelerator only when that accelerator improves the target application.
| Compute Type | Best Fit | Main Advantage | Main Limitation |
| CPU | OCR, parsing, small embeddings, metadata, and background tasks | Broad compatibility and simple deployment | Slower sustained inference |
| iGPU | Video decoding, supported vision models, and light inference | Low additional power and integrated media engines | Limited model and runtime support |
| NPU | Supported low-power vision, classification, or background inference | Efficient always-on processing | Application support is highly workload-specific |
| TPU or edge detector | Supported object-detection pipelines | Low inference latency and reduced CPU load | Limited model formats and use cases |
| Discrete GPU | Local LLMs, multimodal models, image generation, and multi-user inference | High throughput, memory bandwidth, and broader AI framework support | Power, heat, noise, VRAM, driver, and container requirements |
Hardware Video Decoding and AI Detection Are Different
Camera workloads demonstrate why one accelerator specification cannot describe the complete system.
A camera AI pipeline may include:
- Receiving the network stream
- Decoding the video
- Running motion detection
- Preparing frames
- Running object detection
- Writing recordings and event metadata
Video decoding may run on an iGPU or media engine, while object detection runs on another detector.
The Frigate detector and hardware support matrix documents multiple acceleration paths and explains that a supported detector can reduce detection latency and CPU load.
Why Software Support Matters More Than TOPS
TOPS is a theoretical compute metric. It does not prove that the userโs applications can use the hardware.
Before purchasing an accelerator, verify:
- Operating-system support
- Driver availability
- Container passthrough
- Runtime compatibility
- Supported model formats
- Application-level integration
- Documented performance for the actual workload
The better hardware choice is often the accelerator with mature application support, not the one with the largest advertised number.
How Should an AI NAS Split HDD and NVMe Storage?
HDDs for Source Data and Capacity
HDDs remain appropriate for:
- Photo and video libraries
- Document archives
- Security camera recordings
- Backups
- Large datasets
- Long-term source files
They provide lower cost per terabyte and allow an AI NAS to preserve large private archives without requiring an all-flash storage pool.
NVMe for Apps, Models, Databases, and Indexes
Active AI application data usually benefits from lower latency.
NVMe storage is useful for:
- Container volumes
- AI models
- Thumbnails
- OCR output
- Embedding databases
- Vector indexes
- Cache
Running all active services directly from a mechanical drive array can make the system feel slow even when CPU and GPU resources are available.
Storage Overhead From AI Applications
AI-aware applications create more data than the original file library alone.
Plan capacity for:
- Preview images
- Thumbnails
- Face data
- OCR text
- Transcripts
- Indexes
- Embeddings
- Model files
- Application logs
Determine which derived data must be backed up and which can be regenerated from protected source files.
How Fast Should the Network Be?
Network speed does not directly accelerate a model running inside the NAS. It affects how quickly source files, datasets, models, and results move between storage, users, and external compute.
| Network Tier | Reasonable Use | Potential Limitation |
| 1GbE | Basic home storage, backups, light photo access, and AI running on the NAS | Large transfers and external compute can become constrained |
| 2.5GbE | Large media libraries, faster backups, several users, and moderate local workflows | May still limit high-throughput video or external AI servers |
| 10GbE | External AI compute, NVMe-backed shares, multi-user video, and large datasets | Higher switch, cabling, adapter, and storage-performance requirements |
When 1GbE Is Enough
1GbE may remain sufficient when:
- AI processing runs directly on the NAS.
- Most jobs run in the background.
- Only one or two users access the system.
- Large source files do not move frequently.
When 2.5GbE Is a Useful Upgrade
2.5GbE provides more headroom for:
- Large photo imports
- Faster local backups
- Several active users
- Large media files
- Moving model files
It is a useful middle tier, but it should not be treated as a universal minimum for every AI NAS.
When 10GbE Matters for External AI Compute
10GbE becomes more relevant when the NAS supplies data to another machine repeatedly.
Examples include:
- A GPU server reading private RAG documents
- A workstation processing video stored on the NAS
- Several users editing large media files
- High-speed backups to another local server
- NVMe-backed shared datasets
Hardware Requirements by AI Workload
| AI Workload | Main Pressure | Real-Time Requirement | Acceleration Priority | Storage Priority |
| OCR and document indexing | CPU, RAM, database, and file parsing | Usually low | Optional | NVMe for database and index |
| Photo recognition | Initial indexing, thumbnails, embeddings, and database growth | Usually low | Optional but useful when supported | HDD archive plus NVMe working tier |
| Semantic search and RAG | RAM, extraction, embeddings, vector storage, and generation | Interactive retrieval | Optional for embeddings; useful for local generation | NVMe for active index and model data |
| Security camera detection | Video decoding, object detector, network streams, and storage writes | High | Supported iGPU, NPU, TPU, or GPU | Continuous recording capacity |
| Local LLM inference | RAM or VRAM, context cache, memory bandwidth, and model loading | Interactive | GPU or unified memory preferred | NVMe for model files |
| Multi-user local AI | Concurrency, memory, GPU throughput, cooling, and queue management | High | Stronger dedicated compute | NVMe and reliable shared storage |
OCR and Document Indexing
Document workflows are usually batch-oriented. The most important requirements are often:
- A capable CPU
- Enough RAM for several containers and databases
- Fast active storage
- Reliable source-file storage
The Paperless-ngx document intake and OCR workflow illustrates how document processing includes consumption, OCR, metadata, indexing, and preservation of the original file.
Photo Recognition
Photo AI creates heavy initial processing but may not require real-time responses. CPU and RAM handle application services, while optional acceleration can improve face, object, or visual embedding jobs.
The Immich Smart Search and media-indexing features show how contextual search, OCR text, recognized people, metadata, location, date, and camera information can become part of one search system.
Local RAG and Semantic Search
Local RAG is a pipeline, not one model. Hardware may be needed for:
- Document extraction
- Chunking
- Vector storage
- Retrieval
- Reranking
- Local answer generation
Embedding and indexing may run in the background, while answer generation is interactive. Users can therefore run retrieval locally and move only the heavier generation stage to another machine when necessary.
Security Camera Detection
Camera AI is one of the most demanding always-on workloads because it combines:
- Several continuous network streams
- Video decoding
- Motion analysis
- Object detection
- Event metadata
- Continuous storage writes
Camera count, resolution, frame rate, substream configuration, model type, and retention period may matter more than one generic GPU specification.
Local LLMs and Multi-User Inference
Interactive local LLM workloads are primarily constrained by:
- Model memory
- Context length
- Memory bandwidth
- Parallel requests
- GPU or unified-memory capacity
A small model for one user may run on moderate hardware. A larger model serving several users can require a substantially stronger compute node.
Should AI Run on the NAS or a Separate AI Server?
Run Storage-Adjacent Background Tasks on the NAS
Tasks that naturally belong near stored data include:
- Photo indexing after backup
- OCR for new scanned files
- Document embedding updates
- Thumbnail generation
- Light classification
These workloads benefit from direct file access and can often run in the background without workstation-class hardware.
Separate Heavy, Hot, or Frequently Updated Workloads
A separate AI server is more attractive for:
- Larger local LLMs
- Image generation
- Several camera streams
- Multi-user inference
- Frequently changing models and drivers
- Hardware that produces substantial heat and noise
The workload-placement decision is covered in more detail in GPU and external AI server requirements for NAS workloads .
Keep Storage Reliable When AI Services Fail
A split design can prevent an experimental model runtime or GPU driver update from affecting primary storage.
The NAS can remain responsible for:
- Original files
- User permissions
- Snapshots
- Backups
- Application database copies
The AI server can remain responsible for:
- Model inference
- GPU drivers
- Embedding jobs
- Experimental containers
- Heavy camera detection
What Hardware Specifications Do Not Tell You
Accelerator Support Depends on Software
A specification sheet cannot confirm whether an application supports:
- The selected driver
- The container runtime
- The model format
- The accelerator API
- The exact hardware generation
Check the applicationโs current compatibility documentation before assuming a GPU, NPU, or TPU will be used.
TOPS Does Not Measure the Complete Workflow
TOPS does not describe:
- Available memory
- Memory bandwidth
- Model compatibility
- Database performance
- Video decoding
- Storage latency
- Network throughput
- Application quality
A balanced system with supported software may outperform a higher-TOPS device that cannot run the required workload efficiently.
A Powerful AI Server May Still Be a Poor NAS
A gaming PC or workstation may provide excellent inference performance but still lack:
- Efficient always-on operation
- Convenient drive expansion
- Storage-pool management
- Quiet cooling
- Backup integration
- Predictable file permissions
Conversely, a low-power NAS may be excellent for storage and unsuitable for heavy local AI.
Use the compute, memory, storage, and network bottleneck checklist to identify which part of the system is limiting the actual workflow.
AI NAS Hardware Buying Checklist
Define the exact workload.
Specify whether the system will run OCR, photo indexing, camera detection, RAG, a chatbot, image generation, or another task.
Decide whether processing is background or real-time.
Background jobs can tolerate slower hardware. Real-time services require more sustained performance.
Estimate the data-library size.
Include original files, thumbnails, OCR output, databases, indexes, models, and future growth.
Estimate model memory and context.
Include runtime overhead, KV cache, parallel users, and other applications.
Verify software support for the accelerator.
Check drivers, container passthrough, runtime support, and model formats.
Separate HDD capacity from active NVMe storage.
Protect source data on the capacity tier and place active databases and models on fast storage.
Choose networking for the architecture.
1GbE may be enough for local processing; 10GbE becomes more relevant when AI compute is separated.
Protect NAS reliability.
Confirm that indexing and inference will not disrupt backups, recordings, file access, or storage health.
Plan power, cooling, and noise.
Evaluate both idle efficiency and sustained AI load.
Decide whether an external compute node is easier to upgrade.
Do not force heavy inference into the NAS when a split architecture is more practical.
Conclusion
AI NAS hardware requirements cannot be reduced to one minimum CPU, one RAM number, or one GPU recommendation.
The correct system depends on the workload:
- OCR and light indexing may run on a capable CPU with 16GB RAM and fast application storage.
- Photo recognition, document RAG, and several containers benefit from more RAM and an NVMe working tier.
- Local LLMs, multi-camera AI, long context, and multiple users may require a discrete GPU, more memory, stronger cooling, and separate compute.
System RAM, VRAM, and unified memory solve different problems. Model weights are only one part of memory demand; context, concurrency, databases, indexes, and NAS services also require capacity.
HDDs remain useful for protected source data, while NVMe is better for active applications, models, caches, and indexes. Network speed should match how much data moves between the NAS and any external AI server.
The best AI NAS is not the system with the largest GPU or highest TOPS rating. It is the system that runs the intended workload reliably without compromising storage, backups, power efficiency, or maintainability.
What is a practical starting configuration for an AI NAS?
A modern multi-core CPU, 16GB RAM, HDD storage for source files, an SSD or NVMe tier for applications and indexes, and 1GbE or 2.5GbE networking can be a practical starting point for light background workloads.
This is not a universal minimum. Heavier applications may require more RAM, acceleration, storage performance, or separate compute.
Can I run AI on a NAS without a dedicated GPU?
Yes. OCR, document indexing, metadata extraction, small embeddings, and background photo processing may run on CPU hardware.
A GPU becomes more useful for local LLMs, multimodal models, image generation, high-volume inference, and several simultaneous users.
Is 16GB RAM enough for an AI NAS?
16GB can be enough for a few containers, light OCR, metadata extraction, and background indexing.
It may become restrictive when the system also runs large photo libraries, document RAG, vector databases, virtualization, local models, or several simultaneous services.
When should I choose 32GB RAM?
32GB is a stronger target when running several AI-aware applications, larger indexes, private RAG, photo recognition, databases, and light local generation on the same system.
When does 64GB or more RAM make sense?
64GB or more becomes relevant for larger indexes, virtualization, several users, long-context workflows, CPU or unified-memory inference, and multiple AI services.
How much VRAM does a local LLM need?
VRAM requirements depend on model architecture, quantization, context length, KV cache, runtime overhead, and concurrency.
Use the target runtime to estimate total memory rather than relying only on parameter count or model-download size.
Is an NPU enough for local LLMs?
Usually not for heavier general-purpose local LLM workloads. NPUs are often better suited to efficient supported inference, vision, classification, or background tasks.
Software compatibility determines whether an NPU provides practical value.
Should AI NAS applications run from HDDs or NVMe?
Original media, documents, recordings, and backups can remain on HDD storage. Models, containers, databases, thumbnails, cache, embeddings, and indexes are usually better placed on SSD or NVMe storage.
Does an AI NAS need 10GbE?
No. 1GbE may be sufficient when AI runs directly on the NAS and large files do not move frequently.
10GbE becomes more useful for external AI servers, NVMe-backed shared data, large media workflows, and several active users.
Does faster networking make local LLM inference faster?
Not when the model and data are already on the same machine. Networking mainly affects data movement between the NAS, users, workstations, and external compute nodes.
Should heavy AI inference run outside the NAS?
Often, yes. Larger models, image generation, multi-user inference, and continuous camera AI may be easier to upgrade and cool on a separate server.
The NAS can remain responsible for reliable storage, permissions, snapshots, and backups.
What is the biggest AI NAS hardware mistake?
The most common mistake is buying one impressive component without checking the rest of the pipeline.
A strong GPU cannot compensate for insufficient RAM, slow active storage, unsupported software, weak cooling, or unreliable storage design.
References
Runtime State vs Persistent State in Home Assistant: What Must Survive Restart?
Home Assistant does not persist every live value; config, registries, selected restored states, history, and deployment data play different restart roles.
How Does Home Assistant Authenticate Local and Remote Sessions?
Local and remote Home Assistant sessions use the same server-side identity model; remote access changes the route and TLS boundary, not the core token...
Why Can Home Assistant History Queries Slow as Recorder Data Grows?
Recorder growth can raise History query cost when the requested range touches more rows, cache misses increase, or storage and index work become slower.
