Jellyfin can retain more temporary data than expected because transcodes, caches, generated media artifacts, and cleanup jobs all follow different lifecycles.
A growing cache or temporary directory is not automatically a leak. Some files belong to active sessions, some are reusable derived state, some wait for an age or schedule threshold, and some survive because a job ended before cleanup. Diagnose the producer and lifecycle first; deleting an unexplained directory can hide the evidence or force expensive regeneration without fixing the cause.
The Root Cause Is a Lifecycle Mismatch, Not Simply a Large Cache
Temporary data becomes suspicious when its observed lifetime no longer matches the event that created it. A transcode working set should track playback activity, reusable thumbnails or trickplay data may intentionally outlive one session, and cleanup-managed files can remain until a timer or threshold expires. Those are different contracts even if every path looks “temporary.”
Jellyfin troubleshooting guidance for heavy resource use distinguishes active transcoding from other background work, which is why active transcoding should be checked before assuming leftover files are orphaned. A file that still has an owner and a live consumer is not stale merely because it is large.
The failure condition is unexplained growth: no active producer needs the data, no reuse policy justifies keeping it, and no cleanup rule predicts when it should disappear. Once all three explanations fail, retained temporary data becomes an operational defect rather than a normal cost of derived media processing.
The Four Causes of Retained Temporary Data
Classify retained files by producer before deleting them. The useful categories are active session data, reusable derived artifacts, files waiting for policy-driven cleanup, and orphaned intermediates left by interrupted work. Each category has a different safe deletion point.
Age-based cleanup systems illustrate why “unused right now” is not the same as “eligible for deletion”: retention can be tied to timestamps, rules, and scheduled sweeps. That makes age-based cleanup rules a useful model for separating lifecycle policy from immediate session state.
Use the four signatures below to decide whether growth is expected, delayed, or orphaned. Do not apply a global size threshold until you know whether the directory contains disposable work files or reusable artifacts whose regeneration would simply recreate the same footprint.
Cause 1: Active Transcodes Still Own a Working Set
- Mechanism: a live or recently ending playback session writes temporary segments that remain useful until the transcoding pipeline releases them.
- Symptom signature: file modification time and directory growth track active transcode sessions or recent seeks.
- IF–THEN: if the working set stops changing and is released after all transcodes end, treat it as session-bound rather than orphaned.
Cause 2: Reusable Derived Artifacts Are Intentionally Persistent
- Mechanism: thumbnails, trickplay images, metadata, or other generated representations are retained because future clients can reuse them.
- Symptom signature: files remain stable across sessions and are read again during browsing or seeking; Trickplay and metadata files can therefore behave more like cacheable derived state than one-session scratch data.
- IF–THEN: if deleting the files only triggers predictable regeneration with no reduction in the long-term footprint, manage generation and retention rather than repeatedly purging them.
Cause 3: Cleanup Has Not Reached Its Age or Schedule Trigger
- Mechanism: the producer finishes, but a separate cleanup process owns deletion and runs later.
- Symptom signature: old files disappear in batches at a consistent time or age threshold instead of immediately after playback or analysis.
- IF–THEN: if retention matches the documented or observed cleanup window, adjust the policy only when disk headroom requires a shorter window.
Cause 4: Interrupted Work Leaves Orphaned Intermediates
- Mechanism: a process creates temporary files but crashes, is killed, or exits through a path that never executes cleanup.
- Symptom signature: stale files have no active owner, no reuse pattern, and timestamps clustered around interrupted jobs; real automation failures show how cleanup skipped after interruption can accumulate large working directories.
- IF–THEN: if the same job repeatedly leaves files after cancellation or failure, fix its exit cleanup and then remove only the confirmed orphan set.
Failure Boundary: Tell Expected Retention From Abnormal Growth
Do not judge from directory size alone. Record file age distribution, recent modification activity, active Jellyfin sessions, scheduled jobs, and the process that still has each suspect file open. Expected retention has an owner or rule; abnormal growth lacks both or exceeds the rule repeatedly.
Filesystem accounting can also mislead the diagnosis. On Linux, a deleted file can continue consuming blocks while a process still holds it open, so deleted files can still occupy disk space even after the visible pathname disappears. If `df` and directory totals disagree, inspect open file descriptors before deleting more data.
The boundary is crossed when the producer is gone, the expected cleanup window has passed, the files are not reusable derived state, and the footprint continues to grow or reappear after manual deletion. At that point, changing cache size alone treats the symptom. Repair the lifecycle that creates, closes, invalidates, or deletes the data.
Build a Temporary-Data Ledger Before Cleaning Anything
Create a short ledger for each large temporary path: producer, data role, active owner, oldest and newest modification time, reuse signal, expected cleanup trigger, current size, and safe deletion condition. That turns “the cache is huge” into testable statements and makes later growth comparable to a known baseline.
The ZimaSpace explanation of the read-write workload split helps distinguish data that is actively produced from data that is merely being reused. When file ownership is uncertain, Linux process inspection can identify which process still has a file open before cleanup changes the evidence.
Pass the cleanup decision only when the ledger identifies a disposable set and the producer is no longer using it. Delete a small confirmed sample, verify Jellyfin behavior, then apply the cleanup rule. If the directory immediately regrows to the same steady size, tune the producer or retention policy instead of scheduling an endless purge.
| Field | Question |
| Producer | Which Jellyfin task or process created the files? |
| Role | Active working set, reusable derived state, delayed cleanup, or orphan? |
| Owner | Does any process still hold the files open? |
| Age | When were the oldest and newest files modified? |
| Cleanup | What event, timer, or age threshold should remove them? |
| Safe action | What evidence makes deletion reversible and low-risk? |
