SSD garbage collection can slow a home NAS during peak writes, but only when block reclamation starts competing with incoming I/O. As clean blocks become scarce, the controller must move valid data and erase old blocks while the NAS is still accepting backups, sync jobs, database updates, or other writes. That extra internal work can raise latency and reduce sustained throughput.
A falling transfer rate does not prove that garbage collection is responsible. An exhausted pseudo-SLC cache, thermal throttling, RAID work, filesystem behavior, PCIe limits, or the network can create the same symptom. Ask what changed in the storage path when speed fell.
What Is SSD Garbage Collection Actually Doing?
NAND flash does not update data in the same way as magnetic storage. Data is programmed into pages, but previously used space is generally reclaimed at the larger block level. When a block contains both invalid pages and pages that still hold valid data, the controller cannot erase it immediately without preserving the valid pages first.
The controller copies those valid pages elsewhere, erases the old block, and returns the reclaimed space to its pool of writable blocks. KIOXIA's description of the NAND garbage-collection process also explains why this relocation creates write amplification: the flash may receive more physical writes than the host originally requested.
With enough clean blocks and idle time, this housekeeping can remain unobtrusive. When reclamation runs in the foreground, host writes and internal data movement use the controller and NAND resources together. Users then observe longer I/O completion times, uneven write speed, or delayed application responses.
Why Do Peak Writes Expose Work That Usually Stays Hidden?
A short burst can finish before the drive exhausts its easiest writable space. A home NAS under sustained load behaves differently. A large backup may arrive while photo indexing, file synchronization, container logs, and a database are also writing. The controller receives less idle time in which to prepare blocks before the next host request arrives.
Write shape matters as much as write volume. Sequential data can often be placed more efficiently, while random overwrites and mixed streams leave valid and invalid pages distributed across more blocks. Reclaiming one of those blocks may require copying more useful data. An analytical write-amplification model shows why available spare area is an important variable, although its assumptions should not be treated as a benchmark for every NAS drive.
The visible slowdown begins when incoming writes plus internal relocation demand more service capacity than the SSD can provide at that moment. Average throughput may fall, but tail latency can be the more disruptive result. A file copy may merely take longer, while a database, virtual machine, or metadata-heavy service can feel unresponsive because a small number of requests take much longer than usual.
Which Home NAS Conditions Increase GC Pressure?
Low capacity headroom is one condition. The operating system's free-space figure is not identical to the controller's clean-block reserve, but a heavily occupied active range gives the drive fewer easy placement choices. Micron's SSD over-provisioning brief explains that spare NAND capacity provides workspace for background operations and that limited headroom can hinder some heavy workloads near full capacity.
Workload history is another condition. A fresh or recently erased SSD can show elevated performance before it enters a repeatable steady state. The SNIA steady-state test method requires preconditioning because active range, write history, block size, read-write mix, and queue depth can materially change the result. That is why one short copy test cannot establish how an SSD will behave during a long NAS workload.
The following table is a diagnostic map, not a set of universal drive specifications. Several conditions may exist together, so the observable pattern should be used to choose the next measurement rather than to declare a cause immediately.
| NAS condition | Possible internal activity | Observable pattern | What else to rule out |
| Low free-space headroom | More valid-page relocation to reclaim blocks | Higher latency or uneven sustained writes | Filesystem allocation and RAID capacity |
| Long sequential write | Cache folding, block allocation, and possible GC | Fast start followed by a lower plateau | Pseudo-SLC cache exhaustion |
| Mixed random overwrites | Relocation across fragmented blocks | Latency spikes and fluctuating throughput | Database sync writes and filesystem overhead |
| High controller temperature | Normal writes under reduced clock or power limits | Speed falls as temperature rises | Thermal throttling before GC |
| Stable transfer ceiling | SSD may still have unused performance | Similar limit across repeated workloads | Network, PCIe, CPU, or RAID path |
Why Is Every SSD Write Cliff Not a Garbage-Collection Event?
Pseudo-SLC cache exhaustion is the most common source of confusion. Many SSDs initially write into a faster cache region and later fold that data into denser NAND. Once the available cache is consumed, throughput may drop to the drive's slower native-write rate. Garbage collection can occur during the same transfer, but cache exhaustion and block reclamation are not interchangeable terms.
Thermal throttling usually follows a different signal: drive temperature climbs before performance is reduced, and cooling changes the behavior. Interface and network limits tend to look more like a stable ceiling than an internal latency storm. RAID parity, copy-on-write filesystems, synchronous writes, and application-level fsync behavior can also add work above the SSD layer.
This distinction changes the remedy. A faster network will not create clean NAND blocks, while reserving SSD space will not fix a saturated network. Scheduling TRIM will not cool an overheating controller. Garbage collection should remain a hypothesis until the slowdown follows storage occupancy, workload history, write shape, or idle recovery more closely than competing explanations.
What Do TRIM and Free Space Actually Change?
Deleting a file changes filesystem metadata, but the SSD also needs to know that the corresponding logical addresses no longer contain useful data. TRIM for ATA devices and deallocation or discard mechanisms for other storage paths communicate that information. A technical explanation of TRIM and garbage collection describes this coordination between the operating system and the drive.
TRIM does not command every affected NAND block to be erased immediately. It tells the controller which logical data no longer needs preservation, allowing later garbage collection to avoid copying invalid content. More free or over-provisioned space can also give the controller additional placement options. Both can reduce reclaim pressure, but neither guarantees a particular throughput or removes the need for garbage collection.
How discard reaches the device depends on the operating system, filesystem, storage stack, and array configuration. Continuous online discard can itself have a cost. For XFS, the Linux discard guidance recommends the periodic fstrim approach instead of the discard mount option because of the latter's performance impact. That filesystem-specific advice should not be generalized into one setting for every NAS.
What Should You Measure Before Blaming Garbage Collection?
Start with a timeline rather than a single speed number. Record throughput and latency from the beginning of the write until after the slowdown appears. At the same time, observe device utilization, I/O queue behavior, temperature, CPU load, and network throughput. Available SMART or NVMe health logs may provide additional context, although exposed fields vary by controller and firmware.
Then isolate the path. Compare a local write with a network transfer, keep the data set and destination constant, and repeat the test with a stable temperature. Separate short bursts from sustained sequential writes and mixed random writes. The SSD performance measurement primer emphasizes that methodology and environment can change reported results, so comparisons need consistent conditions.
Finally, observe recovery. Improvement after idle time is consistent with background maintenance, but it is not proof of garbage collection because caches may fold, temperatures may fall, and other jobs may finish. A stronger diagnosis combines sustained write pressure, limited headroom, latency variation, excluded bottlenecks, and a repeatable response to changed workload conditions.
Does SSD garbage collection affect read-heavy NAS traffic?
Pure reads do not consume clean blocks in the same way as writes, so a read-heavy workload is less likely to create new garbage-collection pressure. Reads can still experience higher latency when they share controller and NAND resources with simultaneous relocation and erase work triggered by other writes.
Can a faster network hide SSD garbage collection?
No. A faster network can remove a transfer ceiling and may make an SSD-side slowdown easier to observe, but it cannot eliminate internal block reclamation. If the network is slower than the affected SSD, however, the network cap may conceal the change in drive throughput.
Why can write speed recover after the NAS sits idle?
Idle time may let the controller prepare clean blocks, fold cached data, or finish other maintenance without competing with host writes. Recovery supports a background-work hypothesis, but it cannot identify garbage collection by itself because cooling and completed NAS tasks can produce a similar improvement.
Can one benchmark run confirm a garbage-collection problem?
No. SSD state depends on prior writes, active range, cache state, temperature, and workload parameters. A useful test must be repeatable and long enough to move beyond the initial burst, while keeping the network, filesystem, data set, and temperature as controlled as practical.
Do enterprise SSDs eliminate garbage collection?
No. NAND-based enterprise SSDs still reclaim blocks. They may provide more over-provisioning, different firmware policies, steadier latency, or endurance designed for sustained workloads, but those characteristics change how garbage collection is managed rather than removing the underlying process.
Final Takeaway
SSD garbage collection matters when reclaiming NAND blocks becomes foreground work that competes with sustained NAS writes. Treat it as the likely cause only after workload shape, capacity headroom, latency behavior, and idle recovery support the patternโand after cache exhaustion, temperature, RAID, interface, CPU, and network limits have been checked.
10 Best Self-Hosted GitHub Copilot Alternatives in 2026
Compare self-hosted Copilot alternatives for private autocomplete, local models, coding agents, IDE workflows, and on-prem development.
How to Run Qwen3.8-27B Locally: RAM, VRAM, Quantization, and Ollama Guide
Run Qwen3.8-27B locally with the right GGUF quant, RAM, VRAM, context size, and Ollama or llama.cpp setup for your hardware.
Qwen3.8-Flash-Next Locally: What 6B Active Parameters Really Mean for RAM, VRAM, and NVMe
A practical guide to Qwen3.8-Flash-Next memory needs, covering 6B active parameters, GGUF size, RAM, VRAM, NVMe, and long context.
