Smart doorbell faces can look different after correction because undistortion remaps wide-angle pixels into a new geometry and sampling grid.
A visitor near the side of a doorbell frame may appear wider before correction and narrower afterward, even though no face filter was applied. The software is attempting to reverse lens projection, then resampling the result into a rectangle. Position, calibration, and crop policy determine how natural that remapped face appears.
Undistortion Changes Coordinates, Not Just Straight Lines
Barrel distortion pushes scene geometry outward in a nonlinear way. Correction calculates where each output pixel should sample the original image, straightening walls and door frames while also relocating facial features. A face near the optical center changes little; one near the corner can change substantially.
A technical overview of lens distortion explains that short focal lengths commonly bend lines outward. Because a face is embedded in the same projection, correcting the frame necessarily changes its apparent width and feature spacing too.
The corrected face is not automatically less truthful. In many cases it is geometrically closer to a pinhole view, but viewers may be accustomed to the raw doorbell image. Familiarity with the distorted version can make accurate correction look like alteration.
Resampling Redistributes Facial Detail
Correction stretches some regions and compresses others, so output pixels are interpolated from neighboring sensor samples. Near the edge, the software may invent intermediate values across sparse source pixels, softening eyes or skin texture. Cropping then removes blank borders and can reposition or enlarge the face.
Research on camera-distance robustness shows that camera distance and magnification distortions affect the usefulness of a face image as a reference. Correction and cropping can therefore alter matching evidence even when the visitor has not moved.
A doorbell may run face detection before correction but display video after correction, or do the reverse. If boxes and crops come from different coordinate spaces, the face shown in an alert can differ from the pixels used for recognition. That pipeline distinction matters more than visual preference.
Where Lens Correction Is Not the Explanation
Correction cannot explain a face that changes between adjacent frames when the visitor stays in the same position and the mapping is fixed. Auto exposure, HDR blending, rolling shutter, bitrate changes, or a switch between main and substreams can alter appearance independently. Some apps also enhance alert snapshots separately from live video.
A systematic study of face image resolution found that recognition performance can deteriorate below resolution thresholds. A correction profile cannot recreate facial detail that the sensor never resolved, and enlarging the corrected crop may only enlarge interpolation.
The lens mechanism also fails if central faces change as much as edge faces, which suggests a global resize or image-processing difference. It is invalid when raw and corrected images come from different timestamps. Compare synchronized frames before attributing identity changes to geometry.
Compare Raw and Corrected Faces at Fixed Positions
Record a visitor moving through center, mid-frame, and edge positions, then preserve synchronized raw and corrected frames. Overlay calibration points and compare inter-eye distance, face-box dimensions, sharpness, and crop boundaries. Keep HDR, exposure, stream, and application version fixed during the sample.
A local-first processing path can keep correction and recognition close to the stored footage, reducing ambiguity about which remote service produced an alert crop. Retain both coordinate mappings with the event record.
Accept lens correction as causal when geometry changes grow toward the edge and repeat consistently at the same positions. Suspect calibration when straight lines remain curved or faces become asymmetrical. Suspect another processing path when changes are uniform, time-varying, or appear only in app-generated snapshots.
