Why Separate AI Runtime State From Model Files on a Home Server?
AI runtime state should be separated from model files because immutable weights and mutable caches require different permissions, backups, upgrades, and recovery rules.
A local AI container may read a model checkpoint while continuously writing download metadata, compiled kernels, prompt caches, conversation state, temporary uploads, lock files, logs, and allocator snapshots. Placing all of those files in one writable directory makes it difficult to tell what is authoritative, disposable, private, version-specific, or safe to delete. The sections below explain how a split layout protects model integrity while allowing runtime state to evolve, expire, and recover independently.
Model Artifacts and Runtime State Have Different Lifecycles
Model weights, tokenizer assets, configuration, and quantization metadata normally change only when a specific model revision is installed. Runtime files can change on every request or restart.
Harborโ€™s model-management guidance applies artifact immutability to large AI files so a named revision remains reproducible. Mixing mutable cache entries into that artifact path weakens the meaning of a model version.
A clean boundary treats the model directory as versioned input and the runtime directory as generated state. The runtime can be rebuilt without silently changing the installed weights.
A Read-Only Model Path Limits Accidental and Malicious Changes
An inference service usually needs to read model files, not rewrite them during every request. Mounting that path read-only prevents a compromised plugin, faulty cleanup job, or mistaken container command from replacing checkpoint shards.
Container security guidance recommends narrow writable paths for logs, cache, and temporary files rather than giving the process a fully writable application tree.
Read-only storage does not prove the model is trustworthy, but it preserves the installed bytes after verification and makes unexpected writes fail visibly.
New model revisions should arrive through a controlled import or deployment step, not through the same permissions used to serve user prompts.
Compiled Kernels and Execution Caches Belong to Runtime State
Inference engines may compile kernels or execution graphs for one GPU model, driver, framework build, tensor shape, and configuration. Those artifacts can speed later starts but are derived from the environment.
NVIDIA engineering describes initialized runtime state as a separate source of cold-start delay from the model weights themselves. A driver or runtime update may invalidate that state even though the checkpoint remains unchanged.
Store compilation and kernel caches under a versioned runtime-cache root. They can then be purged or regenerated without deleting the authoritative model copy.
Conversation and Prefix Caches Carry User-Specific Data
KV cache, prompt cache, retrieved passages, temporary uploads, and session memory may contain or encode household context. Their privacy and expiration rules are not the same as public model weights.
LMCacheโ€™s architecture separates KV cache state from inference workers so cache reuse can survive worker changes. That separation also makes ownership, retention, and cleanup a distinct operational responsibility.
ZimaSpaceโ€™s guide to per-user context shows why runtime caches must follow user identity rather than inherit the broad sharing policy of one common model directory.
Do not back up transient prompt state automatically just because model files are backed up. First decide whether the state is required, private, reproducible, and still within its retention window.
Separate Paths Make Upgrades and Rollback Predictable
An update should be able to replace the runtime image or activate a new model revision while preserving only compatible state. When code, model files, and generated data are mixed, rollback can restore an incoherent combination.
An immutable deployment pattern keeps application state locations explicit. A failed runtime upgrade can be replaced while persistent paths remain inspectable and model revisions remain unchanged.
Use revisioned model directories and an atomic active pointer rather than overwriting weights in place. Give each runtime version a compatible cache namespace when compiled artifacts cannot be shared safely.
Backup and Cleanup Policies Should Follow Data Value
Model files may be redownloadable, locally fine-tuned, licensed, or expensive to reconstruct. Runtime state ranges from disposable temporary files to valuable conversations and irreplaceable local adapters.
Model artifact strategy emphasizes model lineage so the exact weights and configuration behind a deployment can be identified. Runtime backups should instead be selected by business value, privacy, and recoverability.
Exclude regenerable kernel caches, incomplete downloads, and temporary tensors from routine backup. Protect fine-tunes, adapters, user-approved histories, and configuration through their own tested restore paths.
Disk cleanup becomes safer when cache eviction cannot traverse into model weights and model pruning cannot erase active user state.
Build the Storage Layout Around Explicit Contracts
Use separate paths for immutable model revisions, active model selection, downloads in progress, compiled artifacts, prompt or KV cache, user sessions, logs, and temporary uploads. Record owner, permissions, quota, retention, and backup policy for each.
A cloud-native model registry pattern uses versioned model artifacts so deployment state can point to a specific model without treating generated runtime files as part of that revision.
Test by making the model path read-only, deleting only the cache path, restarting the runtime, rolling back its image, and restoring user state without restoring compiled artifacts. Each operation should affect only the layer named in the procedure.
Should downloaded model files and the model cache be separated?
At minimum, separate complete verified revisions from incomplete downloads and mutable metadata. A shared content-addressed download cache can still feed a read-only deployed model path.
Can runtime cache be deleted safely?
Only after identifying its contents. Kernel and compilation caches are usually regenerable, while prompt, user-session, adapter, or application database state may not be.
Does separation require different physical drives?
No. Separate datasets, volumes, directories, permissions, and backup rules can establish the lifecycle boundary on one storage pool. Different devices are useful when performance or failure isolation requires them.
