A second unrecoverable read error becomes critical during a degraded NAS RAID rebuild because the first failed member has already consumed part or all of the redundancy that normally covers missing information. If another required block cannot be read, the array may have more unknown data than its remaining mirror copies or parity equations can reconstruct.
The word โsecondโ describes a second unavailable input during recovery, not necessarily a second complete drive failure. The unreadable block may sit on a surviving drive that otherwise appears online. Its consequence depends on the RAID level, stripe location, available replicas, and whether the filesystem can identify another verified copy.
What Changes When a RAID Array Enters Degraded Mode?
A healthy redundant array can lose information from one member and still answer a read by using another mirror copy or calculating the missing block from parity. Once a drive has failed, the same array enters degraded mode: data remains available, but one of its normal recovery paths is already in use.
During reconstruction, the replacement drive contains no valid copy of the missing memberโs blocks. Every reconstructed region depends on the surviving members returning the required data. The rebuild is therefore not merely a large copy job. It is a temporary state in which the array must continuously recreate information while operating with a smaller error margin.
An unrecoverable read error is a sector or block the device cannot return correctly after its own error-correction and retry procedures. In a healthy array, redundancy may hide that failure from the application. In a degraded array, the same unreadable block can become the additional unknown that prevents reconstruction.
Where Can a Second Read Error Break Reconstruction?
Parity RAID reconstructs missing data one stripe at a time. A single-parity stripe can solve for one unknown block because the remaining data blocks and parity still define the missing value. If one drive is already absent and a different required block in the same stripe becomes unreadable, the stripe now contains two unknowns but only one parity relationship.
The failure is local to the reconstruction dependency, not automatically every byte in the array. Some implementations may stop the entire rebuild, some may report one damaged region or file, and others may continue while recording an uncorrectable error. The important mechanism is that the affected stripe no longer contains enough trustworthy information for the original calculation.
A mirror has a similar boundary in a different form. After one mirror member fails, the remaining member is the only complete online source. If a block on that source cannot be read and no third replica or backup is available, the mirror has no independent copy from which to recover that block.
Why Does High Capacity Increase Exposure Rather Than Guarantee Failure?
Higher-capacity drives increase rebuild exposure by increasing the amount of data that may need to be examined or reconstructed. More required reads create more opportunities to encounter a latent sector problem that ordinary workloads have not touched recently. A slower rebuild also keeps the array degraded for longer, extending the period in which another fault has a larger consequence.
| Variable | How It Changes Rebuild Exposure |
| Used data | Allocation-aware rebuilds may process less than total raw capacity, while traditional layouts may read a broader address range. |
| Drive capacity | Larger members can extend the amount of reconstruction work. |
| Array width | More members change stripe geometry and the number of devices participating in recovery reads. |
| Normal workload | Applications competing for I/O can lengthen the degraded interval. |
| Read retries | Weak sectors can reduce effective rebuild speed even when most reads eventually succeed. |
Capacity is therefore an exposure multiplier, not a deterministic failure switch. A well-maintained high-capacity array can rebuild successfully, while a smaller array with weak media, stale errors, poor cooling, or unstable power can fail much earlier.
The practical comparison is therefore based on allocated data, rebuild behavior, and sustained read speed rather than enclosure size alone. A physically larger NAS can finish sooner than a smaller array if it has less data to reconstruct and fewer retry delays.
How Does the RAID Level Change the Remaining Margin?
RAID 5 normally uses one parity block per stripe, so a failed member consumes the stripeโs single-failure tolerance. RAID 6 retains another parity margin, which usually leaves another reconstruction margin after the first drive failure. Mirrors depend on how many complete replicas remain.
| Layout | State After One Drive Fails | Effect of Another Required Unreadable Block |
| Two-way mirror | One complete online copy remains | The affected block has no second mirror source. |
| RAID 5 | Single parity is already reconstructing the missing member | A second unknown in the same stripe may be unsolvable. |
| RAID 6 | One additional parity relationship usually remains | The stripe may still be reconstructable, depending on the failure combination. |
| Three-way mirror | Two complete replicas may remain | One unreadable copy can be compared with another surviving replica. |
Dual parity improves the number of simultaneous missing inputs the array can tolerate, but it does not protect against every controller failure, filesystem error, accidental deletion, or corruption copied consistently across all online versions.
The label on the RAID level is only the starting point. Controller behavior, filesystem checksums, replica placement, and backup availability determine whether the remaining margin can identify and repair the affected block.
Why Is a Published URE Rate Not a Rebuild Countdown?
Drive specifications often express nonrecoverable read error rate as a maximum statistical rate per number of bits read. That figure is useful for understanding scale and comparing device classes, but it is not a timer that predicts the exact byte at which an individual disk must fail.
Actual behavior depends on media condition, firmware recovery, workload, temperature, vibration, interface stability, and how the RAID implementation handles retries. A drive may read far beyond a simple calculated threshold without a URE, while a damaged sector can fail much earlier. Treating the specification as a deterministic probability for one rebuild creates precision the specification cannot provide.
The defensible conclusion is narrower: a rebuild that reads more data and lasts longer exposes the degraded array to more opportunities for an existing fault to become relevant.
What Reduces the Consequence Before the Rebuild Starts?
The strongest protection is created before a drive fails. Delayed scrubs leave latent errors undiscovered, while scheduled scrubs or patrol reads can expose cold unreadable regions while full redundancy is still available. Monitoring can reveal rising read retries, pending sectors, interface errors, or temperature problems before replacement becomes urgent.
Array design also changes the consequence. Extra parity or an additional mirror copy preserves more reconstruction choices, while a tested backup provides a recovery source outside the array. Stable power, sufficient cooling, available spare capacity, and a rebuild policy that avoids unnecessary competing work reduce the time spent in degraded mode.
None of these controls guarantees a clean rebuild. Together they prevent one hidden block error from being the only point between an online array and unrecoverable data.
Does one URE always destroy a degraded RAID array?
No. The result depends on the RAID level, the affected stripe, remaining replicas, controller behavior, and whether another verified copy exists. It may damage one region, stop reconstruction, or be repaired.
Is RAID 6 immune to read errors during rebuild?
No. RAID 6 usually retains more parity margin after one failure, but additional errors, another drive failure, controller faults, or shared corruption can still exceed its protection.
Can a successful scrub guarantee the next rebuild?
No. A a scrub verifies stored block checksums and shows that the checked data was readable and internally verifiable at that time. It cannot guarantee that every device will remain healthy during a later reconstruction.
Should rebuild speed always be set to maximum?
Not automatically. Faster completion reduces degraded time, but aggressive rebuilding can compete with applications and stress marginal hardware. The useful setting balances recovery duration, device behavior, and service requirements.
Final Takeaway
A second unreadable block matters because degraded mode has already spent the arrayโs normal recovery margin. High capacity can broaden the amount of data and time exposed to that condition, but RAID layout, verified redundancy, maintenance history, and an independent backup determine whether the error becomes repairable damage or permanent loss.
