Plex can behave differently after a container restart because the persistent data may survive while the runtime environment is rebuilt around it.
A restart does not make a compatible file incompatible by itself, and it should not erase properly mounted Plex state. What can change is timing: storage may not be ready, a device mapping may return differently, networking may come up later, or caches and startup jobs may be cold. Compare the rebuilt runtime with the known-working one before changing the library or media.
A Restart Recreates Runtime State Without Replacing Persistent State
The container filesystem, process tree, sockets, and temporary runtime state are recreated when a container restarts. Persistent Plex configuration should live outside that disposable layer so the new process sees the same database, metadata, preferences, and identity.
Container volumes exist specifically so application state survives restarts. If Plex starts against a different or empty host path, the result can look like a fresh server even though the media files themselves never moved.
First compare the actual host-side configuration mapping with the known-working definition. If the path, contents, and ownership are unchanged, keep the persistent state intact and move to runtime dependencies rather than rebuilding the library.
Mount Readiness Can Change What Plex Sees at Startup
Media may live on a NAS, USB enclosure, pooled filesystem, or remote mount that becomes available after the container runtime starts. Plex can therefore launch successfully while its library path is missing or empty at that moment.
Persistent storage and bind mounts need both the correct definition and an available source. Host data must be mounted explicitly rather than assumed to exist inside the recreated container.
If the library appears unavailable immediately after restart, test the mount from the host and from inside the container before scanning or removing anything. A later service restart that suddenly restores the library is strong evidence that startup order, not Plex metadata, was the changing variable.
Device and Network Bindings Can Return in a Different Order
Hardware acceleration, network interfaces, DNS, and remote storage all depend on resources outside the Plex process. A container can restart before one of those dependencies is ready or with a different device mapping after a host change.
Bind mounts depend on host paths, and the same principle applies to devices and network-facing dependencies: the container definition may be unchanged while the host-side object it refers to is not yet usable.
Compare device visibility, route and name resolution, and any network share from inside the restarted container. If Direct Play works but hardware conversion fails, the media path may be healthy while accelerator access changed; if media is missing, verify storage before tuning playback.
Cold Cache and Startup Work Can Change Early Behavior
A freshly started Plex process may need to reopen the database, repopulate caches, reconnect to services, and resume scheduled work. Early browsing or playback can therefore feel different from the same request after the server has settled even when no persistent setting changed.
Startup authentication and configuration can be timing-sensitive. Treat community reports as examples of a possible restart boundary, not as proof that every Docker restart has the same cause.
Wait for the normal startup sequence to finish, then repeat one known request. If the difference disappears only after caches and dependencies settle, measure that window rather than altering database or media settings that were already correct.
Reproduce the Same Session After the Runtime Settles
The clean comparison uses one file, client, quality, audio track, subtitle state, and network path before and after restart. Record whether Plex reports Direct Play, Direct Stream, or Transcode and whether the container sees the same persistent paths and devices.
Runtime health can diverge from simple process status. A process that exists is not proof that every dependency or request path is healthy.
If the restart changes persistence or mapping, protect that boundary with the container configuration recovery path. If all runtime inputs match and the symptom remains, investigate the specific playback, database, or network branch instead of blaming the restart as a single cause.
