A multi-agent coding system coordinates several assignments; it does not become coherent simply because several models are running at once. Useful parallel work requires task boundaries, agreed interfaces, separate execution contexts, and a review process for the combined result. Without those controls, concurrency often moves effort from implementation into conflict resolution.
Conductor's move to Meta makes the orchestration layer timely, but the underlying engineering questions are independent of one product. This guide explains how tasks are decomposed, assigned, isolated, integrated, and measured. It distinguishes documented platform features from general design patterns and treats human review as part of delivery rather than an interruption to automation.
What Does Multi-Agent Coding Mean?
The term can describe several different arrangements. A developer may manually open two assistants, a script may launch independent coding jobs, or an orchestrator may maintain assignments and route their results. These setups differ in how they share state, handle dependencies, and determine whether work is complete.
An agent count is therefore an incomplete description. Ask who owns the plan, how assignments are related, and what happens when one agent changes an assumption another relies on. Two agents working against an explicit contract may be easier to supervise than ten agents interpreting the same broad request independently.
| Arrangement | Concurrency and isolation | Coordination overhead | Review burden | Suitable starting tasks |
| Single agent | Usually one active execution context | Lower task-routing overhead | One evolving diff, which can still become large | A tightly coupled change or unfamiliar problem |
| Independent parallel agents | Several contexts, isolated only if configured | Developer manually tracks assumptions and dependencies | Multiple proposals and possible duplication | Separate investigations or clearly independent changes |
| Orchestrated agent team | Assignments and execution contexts organized explicitly | Task state, routing, handoffs, and integration must be maintained | Review of individual results and combined behavior | Work with stable interfaces and observable acceptance criteria |
No row guarantees higher quality or speed. The right arrangement depends on the dependency structure and the capacity of the people reviewing the results. More concurrent output can be a liability when nobody can inspect it promptly.
How Are Large Tasks Split Into Smaller Assignments?
Split work by independently testable outcomes rather than by arbitrary file counts. An assignment should name the intended behavior, permitted scope, relevant interfaces, required evidence, and conditions that require escalation. โUpdate three filesโ describes an edit surface without explaining what a successful change does.
A hypothetical export-format change illustrates the difference. One owner defines the schema and compatibility rule. Another updates the writer, another updates the reader, and another reviews representative fixtures. The writer and reader can proceed in parallel only after the shared contract is sufficiently clear.
Identify high-contention work early: package versions, generated artifacts, shared types, database migrations, or authentication helpers. Give these a clear owner. Otherwise, several small feature assignments may each rewrite the same foundation and create a final integration problem larger than any individual task.
Our Conductor acquisition and workflow analysis explains why organizing this work is a separate product function from providing a coding model. The value of decomposition is that it makes dependencies visible before code is produced. It should also reveal when a task is too coupled to benefit from parallel execution.
Cover: Conductor official brand-kit wordmark, used unchanged for editorial identification. Product marks remain with their owner; no affiliation is implied.
How Does an Orchestrator Assign Work?
An assignment needs more than a prompt. Useful metadata includes an owner, starting revision, dependency status, allowed edit area, expected tests, and a result format. The orchestrator should track whether the work is queued, running, blocked, ready for review, or ended, rather than relying on an agent's latest chat message as the only status signal.
Route questions to the person or assignment that owns the relevant decision. If an agent encounters an unspecified schema field, allowing it to invent a value independently may break every consumer. A concise question can prevent a large patch based on an assumption that was never agreed.
The Conductor product site documents an interface for teams of coding agents and separate cloud sandboxes. That is an example of the category, not evidence that every proposed scheduling policy or coordination mechanism is implemented there. Its service-transition announcement also means it should not be presented as a normal new cloud-adoption recommendation.
Keep work assignment separate from permission escalation. A scheduler can decide that a task is next without deciding that its agent should receive a production token. The task owner should explain any need for broader access, and the enforcement layer should apply the resulting permission decision.
Why Does Each Agent Need an Isolated Workspace?
Source isolation helps prevent one assignment from overwriting another's uncommitted edits. Separate branches make the proposed changes attributable and allow reviewers to examine one result at a time. Git worktrees provide multiple working directories associated with one repository, which can be useful for this pattern.
However, separate directories do not create separate security identities. Agents under one operating-system account can potentially access the same home directory, credential stores, and external services. A worktree can solve file interference while leaving the secret-access problem unchanged. Evaluate source separation and runtime isolation independently.
Tests also need their own resources. Assign distinct temporary directories, service ports, and disposable database namespaces. If a test rewrites shared fixtures or updates a common development service, running it concurrently can produce failures that are difficult to reproduce later.
Our safe worktree and permissions guide provides a concrete procedure. Begin with one clean base and a unique branch for each assignment. Preserve unfinished work before cleanup. The objective is to make each agent's result understandable, not to create directories that are separate in name but entangled through shared mutable state.
How Are Dependencies and Shared Files Coordinated?
Use a dependency map that distinguishes blocking decisions from independent implementation. A task should not claim completion if it tested against a temporary interface that another task will replace. Record the contract version or commit it depends on and require revalidation when that dependency changes.
For a small team, a simple task ledger may be enough: owner, prerequisite, contract, output, and integration status. The format matters less than whether it is current and authoritative. Copying slightly different versions of the plan into several chats can create the same divergence that the ledger was meant to prevent.
Limit concurrent edits to shared infrastructure. A designated owner can update a lockfile after dependencies have been agreed, while feature agents explain their requirements. The same principle applies to generated clients and schemas. Regeneration should be reproducible from an identified source rather than manually reconciled from several agent outputs.
Shared context should also have a trust boundary. An agent's report is evidence to assess, not permission for another agent to expand its task. The OWASP AI Agent Security guidance provides a broader reference for tool permissions and multi-agent risks. The team should retain a clear distinction between information exchange and authority to act.
How Are Changes Integrated and Conflicts Detected?
Textual merge conflicts are only one kind of conflict. Two patches can merge cleanly while disagreeing about a field's meaning, an error code, a timeout, or a permission rule. Integration must test the behavior across assignment boundaries, not merely confirm that Git accepted the files.
Choose an integration owner and sequence. Combine prerequisite changes first, update dependent work against the reviewed base, and rerun the checks that matter to their interaction. Git's merge documentation explains the mechanics, while the team remains responsible for deciding what constitutes a valid combined result.
A hypothetical API change might require a client update, a server change, and compatibility tests. Each branch can pass its own unit suite while the combined system still fails because the client sends a field the server interprets differently. A cross-boundary test should exercise the actual agreement rather than mock both sides independently.
Keep review evidence tied to the final revision. If a dependency or base branch changes after testing, identify which checks must be repeated. Do not cite an old success message as though it applies to a new combination of code. Our transaction-safe workflow analysis offers a related perspective on retries and state transitions when tool actions cross boundaries.
Where Should Human Review Remain?
People should retain decisions that involve ambiguous intent, consequential access, risk acceptance, and release responsibility. A model can propose alternatives and identify tradeoffs, but the team must decide which behavior it actually wants. Automating an ambiguous requirement only produces ambiguity more quickly.
Require a reviewable handoff: task outcome, diff, tested revision, executed checks, known limitations, and unresolved questions. GitHub's pull-request review documentation provides the repository mechanics for recording feedback and approval. Configure the workflow so a later agent revision does not bypass the intended review gate.
Avoid treating another agent's approval as independent assurance when both used the same missing context or assumptions. A second model can be a useful reviewer, but it should not replace ownership of the security or architectural decision. Ask what evidence the reviewer examined and how it challenged the proposed solution.
Review capacity also affects scheduling. If completed branches pile up, starting more assignments may increase the cost of rebasing and context switching. Limit work in progress when the bottleneck is integration or review. An orchestrator should make that bottleneck visible rather than optimizing only the number of active workers.
How Should Teams Measure Cost and Quality?
Measure delivered outcomes and the effort required to accept them. Useful metrics include task completion time, reviewer time, rework, failed integrations, regressions, and the cost of model and execution resources. Separate useful output from generated volume: more commits or longer responses are not evidence of better delivery.
Keep the workload comparable. A simple documentation task and a migration touching several services should not be pooled into one unexplained average. Record scope and dependencies so that a slower result can be understood. Parallel execution may reduce wall-clock time while increasing total compute and human review effort.
For an initial trial, follow a small sequence:
- Select a bounded task with explicit acceptance criteria.
- Record a single-agent or existing-team baseline where practical.
- Split only the independently testable parts.
- Track execution, integration, and review time separately.
- Compare the accepted result, regressions, and total cost.
Our minimum agent audit-record analysis describes the evidence needed to reconstruct what happened. Retaining that evidence makes comparisons useful when a model or orchestration tool changes. Without it, teams may attribute an improvement to agent count when it actually came from a clearer specification or better tests.
An effective orchestration design should also fail visibly. A blocked dependency, exhausted budget, or unresolved review question should be a recorded state with an owner. Silent retries and optimistic completion summaries make a dashboard look busy while obscuring whether the project is moving toward an acceptable result.
Before expanding a workerโs tools, use the agent files and accounts checklist to review the new access separately from the task assignment. Scheduling useful work does not itself justify additional authority.
Is opening several agent chats the same as orchestration?
Not necessarily. Orchestration adds explicit task state, ownership, dependency handling, and integration. Several independent chats can still leave all coordination work to the developer.
Which tasks are easiest to parallelize?
Tasks with stable interfaces, independent edit areas, and clear tests are good starting candidates. Tightly coupled architectural decisions usually need agreement before implementation can proceed independently.
Does a worktree provide a security sandbox?
No. It separates a working tree, not operating-system privileges, network access, or credentials. Add appropriate runtime and identity controls for those risks.
Can clean merges still introduce integration failures?
Yes. Semantic disagreements can survive a textual merge. Test the combined behavior at the boundaries between assignments.
What should count as success in a multi-agent trial?
An accepted, correct result with understandable cost and review effort. Agent count, token volume, and a large number of generated changes are not sufficient measures.
Conclusion
Multi-agent coding is a coordination problem as well as an inference problem. Clear assignments, stable contracts, isolated execution, and review of the combined result determine whether concurrency produces useful work or merely more integration effort.
Begin with a small, measurable workflow and preserve the evidence behind each handoff. Add parallelism where the dependency structure supports it, and let review capacity and accepted outcomes determine how far to expand.
Qwen3.8-27B With DSpine: How Draft Models Speed Up Inference
Understand Tencentโs DSpine draft model for Qwen3.8-27B, interpret draft acceptance, and design an end-to-end SGLang comparison.
Linumโs $21K Text-to-Image Experiment: What a 2B Model Can Generate
See what Linumโs 2B P-JiT research release demonstrates, how it compresses image tokens, and which output and training-cost claims need context.
Can 64 GB of RAM Really Run DeepSeek V4 Flash 284B Without a GPU?
Examine the reported 64 GB CPU-only DeepSeek V4 Flash run, including the custom quantization, memory budget, decode speed, and limits of the experiment.
