Meta Muse gives a surprisingly concrete answer to a question the AI industry has mostly avoided: where does a personal AI agent actually live?
Meta's answer is not โinside the chat app.โ Every Muse gets a dedicated computer in the cloud with storage, memory, a browser, a filesystem, background jobs, and its own security boundaries. That matters because an agent that keeps working after you close your laptop needs more than a powerful model. It needs somewhere persistent to live.
What Is Meta Muse and How Does It Work?
Meta Muse is a personal AI agent designed to do work rather than simply answer questions. It can use connected services, send emails, make purchases with approval, remember information about the user, work toward longer goals, and continue tasks in the background.
The important part is its architecture. Muse Spark provides the reasoning model, but the agent itself operates from Muse Secure VM. That VM holds the user's files and connected-service data while giving Muse a browser, tools, compute, and a persistent workspace.
This separates two concepts that are often treated as one: the model that reasons and the computer where the agent lives.
What Is Muse Secure VM?
Meta describes Muse Secure VM as a dedicated cloud computer for each user. It is an isolated Linux virtual machine with its own browser plus enough CPU, memory, and storage to compile code, develop custom Skills, run concurrent sub-agents, and execute cron jobs.
The VM is also the system of record for what a user puts into Muse. Files, durable application state, memory-related data, and credentials for connected services are kept around this persistent environment rather than existing only inside one model conversation.
That is a major architectural shift. Muse is closer to giving an AI agent its own workstation than embedding another assistant inside the user's phone.
Why Does an AI Agent Need Its Own Computer?
A chatbot can disappear after it returns an answer. A useful personal agent cannot. It may be waiting for an event, running a scheduled task, holding unfinished work, preserving files, or coordinating several sub-agents while the user is somewhere else.
Those jobs require ordinary computing infrastructure: a filesystem, process execution, databases, network access, logs, credentials, and persistent state. None of that is solved simply by giving the underlying model a larger context window.
| Chat Assistant | Always-On Agent |
| Answers a prompt | Works toward a goal |
| Temporary session | Persistent state |
| Conversation history | Memory, files, and databases |
| Few immediate actions | Tools, Skills, and connectors |
| User waits for answer | Background jobs continue |
| Model-centric | Runtime-centric |
This is the larger lesson from Muse: an always-on AI agent is becoming a server workload. The frontier model may still run elsewhere, but the agent needs durable infrastructure around it.
Does Meta Muse Keep Working in the Background?
Yes. Meta designed Muse to advance work after the user gives it a goal rather than requiring the app to remain open for every step. Its dedicated VM can also handle concurrent sub-agents and scheduled cron jobs.
That changes what โpersonal AIโ means. A task might start with a conversation, continue as background work, wait for new information, trigger another action later, and return to the user only when approval or a decision is required.
For that pattern, uptime matters. The agent's computer has to stay available even when the user's computer does not.
Where Does Muse Store Files, Memory, and Agent State?
Meta says the user's dedicated VM acts as the system of record for everything placed into Muse. Durable application state is stored in PostgreSQL outside the main agent runtime cell, while files and workspace data remain inside the dedicated VM environment.
This is different from relying entirely on the model's context. A model can forget old tokens, compact a conversation, or be replaced by a newer model. Persistent files and databases survive those changes.
That separation is likely to become increasingly important for personal agents: reasoning can be replaceable; durable state should not have to be.
How Does Muse Protect Passwords and Credentials?
Muse is intentionally prevented from seeing the real credentials it uses. OAuth tokens and other secrets are stored by a separate authentication service outside the agent's runtime cell, and credential-capable operations run through more tightly controlled processes.
The browser follows the same principle. When a user enters a password, it can go directly into protected credential storage and later be injected into the browser without exposing the password to the main Muse agent.
This matters because an autonomous agent should not need unrestricted access to every secret required to perform its work. Ability to use a credential and ability to read a credential are different permissions.
What Is Meta Muse Sentinel?
Meta places a second agent, Sentinel, outside Muse's main runtime. Sentinel is the permission authority for connector actions and network egress: Muse can propose an action, but it cannot simply decide for itself that the action is allowed.
That creates a useful separation between reasoning about what to do and authority to actually do it. Sensitive actions can be denied or sent back to the user for approval, while deterministic system boundaries remain in force even if Muse makes a bad decision.
This is especially important because prompt injection remains an open problem. Webpages, files, and tool outputs may contain hostile instructions, so Meta treats external data as potentially untrusted instead of assuming the model will always recognize an attack.
Is Muse Secure VM Just a Sandbox?
It is more layered than a single container. Inside each VM, Muse's core harness, workspace, tools, and binaries run in a systemd-nspawn runtime cell. Root inside that cell maps to an unprivileged host user, while dangerous kernel capabilities and system calls are restricted.
Security-sensitive components sit outside the runtime cell. Credential storage, connector execution, safety classifiers, Sentinel, durable PostgreSQL state, and network proxies are separated so that compromising the main agent does not automatically give control over every protection.
Meta summarizes the design well: the right mental model is two isolated security domains on one machine, not an AI agent with unrestricted root access.
Can Meta Access Data Inside Muse Secure VM?
With the Secure VM available at launch, yes under some circumstances. Meta says operational policies restrict personnel access, but the current architecture does not technically prevent Meta from accessing VM data when needed to support, secure, or operate the service.
That distinction matters. Isolation from other users and isolation from the cloud provider are different privacy guarantees.
Meta also says conversations and VM data are not shared with its advertising systems, while inference trajectories may be sanitized and used for model training unless the user opts out. These are product policies rather than cryptographic guarantees.
What Is Muse Confidential VM?
Meta plans a stronger Muse Confidential VM later in 2026. The goal is to encrypt the VM so that even Meta cannot access the data inside it, with the design intended to be externally auditable.
This exposes an important hierarchy of privacy:
| Architecture | Who Controls Infrastructure? | Can Provider Technically Access Data? |
| Standard cloud agent | Cloud provider | Typically possible |
| Muse Secure VM | Meta | Possible under defined circumstances |
| Muse Confidential VM | Meta | Designed to cryptographically prevent access |
| Self-hosted agent server | User | Depends on services and model connections used |
โCloudโ and โprivateโ are therefore not opposites. The real questions are who controls the machine, who controls the encryption keys, what leaves the machine, and which components are trusted.
Is a Home Server an Alternative to Muse Secure VM?
Architecturally, a home server can perform many of the same persistent jobs: staying online, holding files, running databases, hosting RAG indexes, storing agent memory, executing containers, scheduling automation, and keeping backups. That does not mean a home server automatically recreates Muse.
Muse's security model includes runtime isolation, credential surrogation, restricted network egress, independent policy enforcement, classifiers, and approval gates. Simply giving a Docker container access to a home directory and several API keys is not equivalent.
The advantage of a home server is different: ownership and control of the persistent layer. Users can decide where files, databases, Skills, logs, and services live, while still calling cloud models when frontier-level inference is useful.
Cloud VM vs Home Server: Where Should an Always-On Agent Live?
The choice is less about raw AI performance than operational priorities. A managed VM removes maintenance and can tightly integrate security with the product. A home server offers more control over persistent data and self-hosted services but makes the user responsible for isolation, updates, backups, and access policy.
| Requirement | Managed Secure VM | Home Server |
| 24/7 availability | Strong fit | Strong fit |
| No infrastructure maintenance | Strong fit | Weak fit |
| Local file ownership | Provider-managed | Strong fit |
| Custom self-hosted services | Platform-dependent | Strong fit |
| Integrated security controls | Strong fit | User-dependent |
| Frontier cloud models | Native | Can be connected remotely |
A hybrid architecture may ultimately be more practical than treating cloud and local infrastructure as mutually exclusive. Private data and persistent services can stay on infrastructure the user controls, while selected context goes to a frontier model when its reasoning is worth the tradeoff.
Does an Always-On AI Agent Need a Powerful GPU?
Not necessarily. Muse itself helps expose why โagent serverโ and โinference serverโ should not be treated as synonyms.
| Agent Workload | Local GPU Requirement |
| File storage | None |
| PostgreSQL and memory | None |
| Cron jobs | None |
| API and MCP services | None |
| Skills and scripts | Usually none |
| RAG storage and retrieval | Usually none or low |
| Embeddings | Optional acceleration |
| Local frontier-scale inference | Potentially very high |
An agent computer needs persistence before it needs massive inference hardware. Storage, databases, networking, automation, and uptime are useful even when the main reasoning model lives in the cloud.
What Does Meta Muse Reveal About the Future of Personal AI?
The most interesting thing Meta built for Muse may not be Muse Spark. It may be the decision to give the agent a computer of its own.
That architecture acknowledges something important: once AI moves from answering questions to maintaining goals, operating tools, storing memory, and working unattended, the model becomes only one component. The agent also needs a durable place for its state and services.
The future personal AI stack may therefore split into two replaceable layers: a reasoning engine and an agent computer. The reasoning engine might be Meta, OpenAI, Anthropic, or a local model. The persistent computer can be a managed cloud VM, a privately owned home server, or a hybrid of both.
Muse's answer is a dedicated computer in Meta's cloud. The larger lesson is more durable: always-on AI needs somewhere to live.
Does Meta Muse run locally?
No. Muse runs in a dedicated virtual machine in Meta's cloud. The Muse app or web interface connects to that remote agent environment.
Is Meta Muse always running?
Muse is designed for background and long-running work, and its VM can run scheduled cron jobs and concurrent sub-agents. Individual tasks still depend on permissions, service availability, and Muse's execution policies.
Is Muse Secure VM a separate physical computer?
No. It is a dedicated virtual machine, meaning the user receives an isolated virtual computing environment rather than a dedicated physical server.
Where does Meta Muse store its memory?
Meta says the dedicated VM is the system of record for Muse data. Durable application state is stored in PostgreSQL, while other files and workspace data remain inside the user's VM environment.
Can Meta see data inside Muse Secure VM?
The launch version does not technically prevent Meta from accessing VM data when necessary to operate, support, or secure the service. Meta says operational policies restrict access. The planned Confidential VM is intended to cryptographically prevent Meta itself from reading the data.
Can Muse see my passwords?
Meta designed Muse so the main agent does not receive real passwords or connected-service credentials. Secrets are kept in separate credential storage and supplied to authorized operations without being exposed directly to the agent.
What does Muse Sentinel do?
Sentinel is a separate permission agent that evaluates connector actions and network access. Muse can propose an action, but Sentinel determines whether it is allowed, denied, or requires user approval.
Can a personal AI agent run on a home server?
Yes. A home server can host persistent agent components such as files, databases, memory, RAG systems, Skills, tools, automation, and backups. Recreating the isolation and credential protections of a managed system like Muse requires additional security engineering.
Does an AI agent server need a GPU?
Not for many agent workloads. Files, databases, memory, automation, API services, RAG storage, logs, and backups can all run without a powerful GPU. GPU requirements mainly depend on whether the server also performs local AI inference.
Is a home server more private than Muse Secure VM?
It can give the user greater infrastructure and data control, but local hosting is not automatically secure or private. Permissions, remote access, third-party APIs, cloud inference, credentials, backups, and network configuration still determine what data can leave the server.
