Jellyfin has no reliable fixed overhead percentage because metadata, artwork, cache, indexes, and temporary transcodes scale differently from source media.
Two libraries with the same media size can require very different application-data space when item count, artwork density, previews, scans, or user activity differ. Measure the data directory and temporary paths separately. The goal is a capacity budget based on growth and peak behavior, not a universal 5% rule.
Persistent App Data Is a Separate Capacity Pool
The database, metadata, artwork, logs, and generated indexes are touched during browsing, scans, and playback-state updates. They should be measured independently from the movies and episodes they describe.
The storage-overhead model model separates app-data capacity from bulk media capacity and explains why the two grow on different curves.
A large media archive can have modest metadata, while a smaller library with rich artwork or previews can consume more application space.
Feature Settings Change the Footprint
Artwork density, preview thumbnails, analysis data, item count, plugins, and cache behavior can expand persistent storage. Temporary transcoding is different: it creates a peak working requirement during active conversions.
Use storage latency and throughput to distinguish latency, throughput, and temporary working space when sizing the storage path.
Persistent growth belongs in the app-data budget; transient peaks belong in the scratch budget.
Why Percentage Rules Fail
A fixed ratio fails when the library contains many small items, when previews are enabled, or when concurrent conversions create unusually large temporary segments. It can also overestimate a simple library with minimal generated assets.
The storage-overhead model comparison shows why measured current size and growth rate are more useful than a single percentage.
The boundary flips when a feature or workload changes the data curve; recalculate after those changes.
Build the Budget From Measurements
Record current app-data size, monthly growth, largest temporary-transcode peak, and backup reserve. Keep the backup reserve outside the live data directory so recovery space cannot be consumed by normal operation.
Use the storage-overhead model storage budget pattern and update it after scans, analysis changes, or a major library expansion.
Stop adding capacity when measured persistent growth and temporary peaks both fit inside the chosen free-space margin.
