Filesystem snapshots can make vector compaction retain both old and rewritten blocks, delaying space reclamation and increasing copy-on-write pressure during merges.
A vector database may compact segments to remove tombstones, merge small files, and improve query locality, deleting obsolete files after a safe replacement. A filesystem snapshot taken before the merge still references their old blocks, so the pool keeps them while also allocating the compacted output. The snapshot preserves recoverability, but free-space and latency behavior differ from an unsnapshotted filesystem.
Compaction Rewrites Logical Records Into New Files
Many vector stores use immutable segments or log-structured components. Updates and deletions append new state, then background compaction reads live records, writes consolidated files, updates manifests, and removes superseded segments after a safe commit. This effect should remain measurable under the intended home-server workload.
The foundational LSM compaction describes log-structured merge trees as a hierarchy that batches writes and merges components over time. That rewrite pattern explains why compaction temporarily needs both input and output data. The distinction matters when several pipeline stages share the same storage and memory budget.
Vector-specific structures add graph links, posting lists, payload indexes, and quantization files, so compacted bytes need not equal deleted bytes. Database-level cleanup and filesystem-level block reclamation are separate events. That boundary must be tested with representative household data rather than assumed.
Snapshots Keep Pre-Compaction Blocks Reachable
A copy-on-write snapshot records a point-in-time block graph. When compaction writes new files, the active filesystem references new blocks while the snapshot continues referencing old segments; deleting filenames from the live view cannot free blocks still needed by the snapshot.
OpenZFS snapshot block retention defines snapshots as read-only versions of a filesystem or volume at a given time. Their space use grows as live data diverges, which is exactly what a large rewrite-heavy compaction creates.
A fast snapshot command can therefore precede substantial later space growth. The cost appears on subsequent writes, not necessarily at snapshot creation, and persists until every referencing snapshot is removed. This effect should remain measurable under the intended home-server workload.
Low Free Space Can Turn Retention Into Latency
Compaction needs temporary headroom, and copy-on-write allocation needs free blocks. When snapshots preserve old segments, the pool may fragment or approach capacity, slowing writes and extending compaction; longer compaction in turn leaves more segments and query work.
Milvus vector compaction describes compaction as merging small segments and cleaning deleted data to improve storage and query behavior. The mechanism shows why vector databases can rewrite substantial files even when the logical change is a set of deletions.
The failure boundary is assuming snapshot size reported at creation predicts its final cost. Compaction volume, update churn, compression, deleted vectors, pool free space, and snapshot lifetime determine retained bytes and tail latency. The distinction matters when several pipeline stages share the same storage and memory budget.
FAQ About Snapshots and Vector Compaction
Should snapshots be disabled during compaction?
Not automatically. Snapshots protect recovery points, but scheduling large compactions outside snapshot windows can reduce retained divergence. Any change should preserve a tested backup and database-consistency plan. That boundary must be tested with representative household data rather than assumed.
Why does database size stay high after deleted vectors are compacted?
Old blocks may remain referenced by snapshots, clones, or backups even after the live database removes obsolete segments. Check database files and filesystem referenced space separately. This effect should remain measurable under the intended home-server workload.
Can a snapshot capture an inconsistent vector index?
Yes if database files, write-ahead logs, manifests, and related metadata are not quiesced or captured atomically. Use the databaseโs checkpoint or flush mechanism before the filesystem snapshot when required. The distinction matters when several pipeline stages share the same storage and memory budget.
Measure Snapshot Divergence During a Controlled Merge
Clone a representative index, record logical and physical size, take a snapshot, then run a measured delete-and-compaction cycle. Track compaction bytes, temporary peak space, snapshot referenced bytes, pool free space, write latency, query tail latency, and time to reclaim after snapshot deletion.
Compare the result with the snapshot-stall mechanism in snapshot-stall mechanism. Repeat without a snapshot and with different retention durations while holding database version, index, data, compression, pool settings, and background load constant. That boundary must be tested with representative household data rather than assumed.
Schedule snapshots and compaction from measured headroom rather than convenience. Keep a database-consistent restore point, reserve space for old plus new segments, and expire snapshots only under the established retention policy rather than deleting protection to mask capacity planning errors.
