Plex reconciles device activity through server-side library state, client sessions, account identity, and refreshed metadata rather than direct device-to-device synchronization.
A client does not become the authoritative library just because it was the last device used. The server owns the catalog and access policy, while clients cache views and report activity through their own sessions. Problems appear when one of those layers is stale, disconnected, or using a different account or path.
The Server Remains the Library Authority
Library items, metadata relationships, and server identity live in the Plex data path rather than inside each client. That makes server state the anchor for changes observed across TVs, phones, and browsers.
Client devices can be replaced without rebuilding the authoritative catalog because Plex metadata storage remains on the server.
When two devices disagree, compare them against the same server and account before clearing data. Verify that both are reaching the intended server instance.
Clients Cache Views and Session State
A client can show stale artwork, playback state, or connection choices after the underlying server has changed. That is a cache and session problem until the server itself proves inconsistent.
Warm page-cache behavior is a general reminder that recently used state can outlive the event that first created it.
Sign out or reset only the affected client after confirming another client sees the expected server state. Avoid rebuilding the library to solve a single-endpoint cache issue.
Identity Determines Which Changes Are Visible
Different users can see different libraries, restrictions, and progress contexts even on the same device. A change that appears to โnot syncโ may actually be an account boundary.
Per-user Plex restrictions can alter visible content independently of the physical media and database path.
Repeat the same test with one account on two devices, then two accounts on one device. The variable that follows the mismatch identifies the next layer to inspect. Compare devices over the same remote Plex streaming path before attributing mismatched state to the server, because routing and client caches can create different observations.
Network Path Determines When Reconciliation Happens
Remote devices may reconnect through a different route or after a longer offline period than local clients. DNS, proxy, or VPN changes can therefore delay or redirect the session without changing server data.
Client route metrics influence which interface and gateway are used when several paths are available.
Use one local client as the control while testing a remote device after network changes. If the discrepancy disappears on the LAN, keep the diagnosis in reachability and session routing.
