How Does Context Length Affect Local LLM Throughput?
Longer context usually lowers local LLM throughput by increasing prefill computation, KV-cache memory, decode work, and contention for concurrent sequence capacity.
The effect is not one universal tokens-per-second curve. Prompt length mainly expands the prefill phase, while the growing active context makes later decode steps attend over more cached keys and values. If memory fills, the server may admit fewer requests, preempt sequences, offload cache, or reject work, so throughput depends on the model, attention kernel, hardware, scheduler, and workload mix.
Prompt Length Expands Prefill Work Before the First Token
During prefill, the model processes all prompt tokens to create hidden states and the initial key-value cache. Standard attention work grows steeply with sequence length, although optimized kernels reduce memory traffic and constant factors without making the input free.
The IO-aware attention paper introduces an IO-aware exact-attention algorithm that reduces transfers between GPU memory levels. Its speedups show why kernel choice changes the curve, while the underlying context still requires computation and memory movement.
A server reporting only decode tokens per second can hide this cost. For RAG and long conversations, time to first token and prompts processed per second are necessary alongside output throughput. This distinction remains visible during later household testing.
KV Cache Grows With Every Active Context Token
Autoregressive decoding stores keys and values from prior tokens so they are not recomputed. Cache memory scales with active sequence length, layer count, dimensions, precision, and concurrent sequences; longer contexts therefore reduce how many requests fit at once.
The vLLM PagedAttention presents PagedAttention to reduce KV-cache fragmentation and enable flexible sharing. Better allocation increases usable capacity, but it does not remove the bytes required for the retained context itself. The intermediate result must remain inspectable before automation follows.
When capacity is exhausted, systems may queue new requests, evict or recompute cache, swap to host memory, or lower the batch. These policies can turn a smooth single-user benchmark into unstable multi-user goodput. That boundary should be measured separately under realistic operating conditions.
Decode Steps Read More History as Context Grows
Each generated token queries the accumulated cache, so memory reads and attention work increase with sequence length. The model may remain memory-bandwidth limited, and context compression or cache quantization trades memory savings against accuracy and kernel support.
The KV-cache quantization work quantizes KV cache to enable much longer contexts and explicitly identifies cache capacity as a long-context bottleneck. This shows that advertised maximum context and efficient sustained throughput are different properties. The practical consequence appears when several sources compete for limited context.
The failure boundary is comparing two contexts while changing prompt composition, output length, concurrency, or cache precision. Retrieval quality may improve with added evidence even as system throughput falls, so performance and answer utility need separate axes.
Benchmark Throughput Across Prompt-Length Buckets
Create fixed prompt buckets such as 512, 2,048, 8,192, and 16,384 tokens with controlled output lengths. Run each at one user and increasing concurrency, recording prompt tokens per second, output tokens per second, time to first token, inter-token latency, cache use, queue time, preemption, and failures.
Compare the curve with the long-conversation slowdown described in context-window slowdown. Hold model, quantization, sampling, scheduler, and hardware constant, then repeat with prefix caching or cache quantization only as separate experiments. This dependency should remain explicit in the final interface.
Set an operational context budget from goodput under the required latency objective, not from the model’s maximum accepted length. Retrieve or summarize only when the resulting quality gain justifies the measured prefill and cache cost.
