Persistent object IDs reduce duplicate NVR alerts by connecting frame-level detections into one continuing event rather than rediscovering the same visitor repeatedly.
A detector may find a person in thirty frames per second, but each detection is initially just a box and score. Without tracking, an alert rule can fire whenever confidence dips and returns, or whenever the person crosses a zone boundary. A tracker adds temporal continuity so the NVR can reason about arrival, dwell, departure, and re-entry.
Detection Boxes Have No Memory Between Frames
Object detection answers what appears in one image. Tracking adds state: recent position, motion, appearance features, age, and an identifier. Each new frame becomes a data-association problem that matches detections with predicted tracks and starts or ends tracks when no match is credible.
The Deep SORT tracker method combines motion and appearance information to maintain identities through a video sequence. Its design shows why a persistent ID is computed from temporal evidence, not supplied by the detector itself.
Once that state exists, an alert engine can trigger on the transition from absent to present instead of every positive frame. It can also require dwell time, count one zone crossing, and close the event only after the track has been missing long enough.
Association Keeps Weak Frames Inside One Event
Confidence naturally changes as a person turns, becomes smaller, or passes through shadow. A tracker predicts where the object should appear and can associate a weaker detection with the existing path, preventing a brief confidence drop from ending one event and starting another.
low-score association improves association by using low-score detections instead of discarding them all. That mechanism is relevant to NVRs because partially occluded objects often remain detectable below the threshold used for a fresh alert. This distinction remains important under realistic household operating conditions.
Alert suppression can then key on track state: notify once on confirmation, update the same event during motion, and apply a cooldown after disappearance. The identifier is local to the track lifetime; it is not proof that the same real-world person returned tomorrow.
Occlusion and Scene Changes Cause ID Switches
A long occlusion, crossing people, abrupt camera movement, lens correction, or a scene cut can break association. The tracker may assign a new ID to the same object or transfer an old ID to a different object, producing duplicate suppression or missed alerts in the wrong direction.
A broad tracking survey separates detection, association, motion, and appearance challenges and reviews common evaluation measures. That separation matters because a detector can score well while the track still fragments into several identities. The intermediate state should remain visible during later diagnosis and review.
The failure boundary is camera-local continuity under observable motion, not durable identity across days or cameras. Reset tracks after major scene changes, cap the time an unmatched track survives, and never use a track ID alone for access control or person recognition.
Measure Track Fragmentation Before Suppressing Alerts
Select ten clips with normal motion, occlusion, crossings, night transitions, rain, and wide-angle edges. Annotate each real visit as one event, then count track fragments, ID switches, missed tracks, and alerts produced under the proposed confirmation and cooldown settings.
Compare the result with the wide-angle instability mechanisms in wide-angle tracking, because geometric distortion can change both boxes and motion prediction. Inspect the timeline where each duplicate begins instead of tuning a global cooldown from total alert counts.
Enable ID-based suppression only when one real visit usually remains one track and separate visits are not merged. If long occlusions cause both failure types, combine track state with zones and time limits instead of lengthening one universal timeout.
Private Search Score Calibration: How Raw Similarity Becomes a Usable Confidence Signal
Learn why cosine similarity is not confidence, how labeled queries calibrate scores, and how to monitor thresholds when a private corpus changes.
Local AI NUMA Locality: Why Memory Placement Changes Accelerator Feed Rate
Learn how CPU, RAM, and PCIe topology affect accelerator feeding, why automatic placement can vary, and how to benchmark NUMA binding safely.
Model File Memory Mapping: How Shared Pages Reduce Duplicate RAM Use
Understand how mapped model pages are faulted and shared, why RSS can mislead, and which caches and buffers still consume RAM per process.
