An internet outage does not automatically make Home Assistant local automation fail. Local Zigbee, Z-Wave, Matter, ESPHome, MQTT, and LAN integrations can keep operating while the WAN is down. What changes is the workload surrounding them: cloud requests time out, integrations retry, DNS lookups fail, remote connections disappear, and recovery work may arrive in bursts when connectivity returns.
Resource scheduling therefore matters during an outage even when the local control path is intact. The question is not โdoes Home Assistant need the internet?โ It is whether failed remote work remains isolated or begins consuming event-loop time, executor threads, DNS capacity, logging I/O, or integration reloads that overlap with local control.
Failed Cloud Requests Turn Fast Success Paths Into Timeout Paths
When the WAN is healthy, a cloud request may finish quickly. During an outage, the same call may occupy its timeout window, retry, and log an error before returning. A few calls are harmless; many integrations doing this together create a different scheduling profile from normal operation.
Home Assistant's config-entry lifecycle has an explicit setup retry state for dependencies that are not ready, with the interval between automatic attempts increasing over time. The exact failure mode still belongs to each integration, but retry work is a defined part of degraded operation rather than an exceptional edge case.
Keep critical automations from awaiting a remote API before issuing the local action. Send the notification, cloud update, or external webhook after the physical action when that remote result is not required to decide what the house should do.
Network Timeouts Can Hold Resources Even Without High CPU
A stalled network operation may show little CPU while still occupying a task, connection, thread, or timeout budget. This is why โCPU is only 10%โ does not prove that an outage is cost-free.
A 2026 Home Assistant case traced repeated integration timeouts and cascading reloads to a broken IPv6 path that allowed connections to wait instead of failing quickly. The symptom was scheduling delay around network calls, not raw compute exhaustion.
Observe pending network tasks, integration warnings, DNS failures, and the time between trigger and local service call. If local actions stay fast while cloud entities go unavailable, the outage is correctly isolated. If local latency grows with failed remote calls, identify the integration or custom code that is holding the shared runtime.
Blocking Work Is More Dangerous Than Async Waiting
Home Assistant's core is asynchronous, so well-behaved integrations can suspend while waiting for I/O and let other tasks run. The dangerous case is blocking work that occupies the event loop itself or custom code that performs synchronous network operations in the wrong place.
Home Assistant's developer guidance explains that a blocking operation in the event loop prevents other work from running until it finishes. An internet outage can expose this weakness because a call that normally returns immediately may suddenly wait for a long timeout.
This is why a custom integration can make an outage feel like a whole-platform slowdown even though native local integrations remain well designed. Compare behavior with custom components disabled before blaming the hardware.
Recovery Can Create a Second Workload Spike
When internet connectivity returns, several integrations may reconnect, refresh state, reauthenticate, update entities, and write new history nearly at once. The recovery window can therefore be busier than the middle of the outage.
Do not treat a burst of CPU, network, or Recorder writes immediately after the WAN returns as proof that normal steady-state capacity is insufficient. Measure how long the burst lasts and whether local-control latency returns to baseline afterward.
ZimaSpace's article on retained, queued, discovery, and availability messages after reconnect shows the same recovery principle: reconnecting distributed components can replay state and create work that did not exist while the connection was stable.
Schedule for Degraded Mode, Not Just Normal Mode
During WAN loss, local motion-to-light paths should keep running without a remote prerequisite. Cloud polling can enter bounded retry, remote notifications may fail or queue, DNS-dependent services should fail predictably, and the return of connectivity can create a short refresh burst.
The design target is selective degradation: optional remote work gets slower or disappears while local control stays inside its normal timing range. The strongest outage test is to disconnect the WAN during a normal household workload, measure a few critical local automations, then reconnect and measure both the recovery burst and the time required to return to baseline.
Does an internet outage make Home Assistant local automations slower?
Not inherently. A fully local automation can continue at normal speed. It becomes slower when failed cloud, DNS, custom-integration, or shared-network work consumes resources on the same critical path.
Should I add aggressive retries so cloud integrations recover faster?
No. Aggressive retries can amplify an outage and create unnecessary work. Prefer bounded retry behavior and keep cloud recovery outside the timing path of critical local automations.
