Model sharding helps across a home network only when memory relief outweighs activation transfers, synchronization delay, and the speed imbalance between participating computers.
A 40 GB model may not fit on either of two home computers yet fit when its layers are divided between them. Every token must then cross the network at one or more partition boundaries, so Ethernet latency and activation size join compute as part of inference. Partition shape, quantization, device balance, concurrency, and failure recovery decide whether sharding is usable or merely possible.
Partition Strategy Determines What Crosses the Wire
Pipeline parallelism assigns consecutive layers to devices and transfers activations at stage boundaries. Tensor parallelism splits operations inside a layer and usually requires frequent collective communication, while expert parallelism routes tokens to selected experts in mixture-of-experts models.
distributed transformer blocks distributes transformer blocks across machines connected through the internet and routes requests through available peers. Its design proves that heterogeneous distributed inference is possible, while its operating conditions expose communication and availability as first-class constraints.
For ordinary home Ethernet, coarse pipeline partitions are usually more tolerant than communication-heavy tensor splits. Quantization reduces weight memory but may not reduce intermediate activations proportionally, so model-file size alone cannot estimate network demand. This distinction remains visible during later household testing.
Bandwidth, Latency, and Device Balance Set Token Speed
A stage cannot advance until it receives the required activations. If one boundary transfers 8 MB per token, a 1 GbE link has a theoretical serialization floor near 64 milliseconds before protocol and compute overhead; faster links lower that floor.
automatic parallel plans jointly searches model-parallel execution plans across heterogeneous devices and network links. This illustrates why the best split depends on compute speed, memory, topology, and communication rather than equal layer counts. The intermediate result must remain inspectable before automation follows.
The slowest stage limits steady-state throughput, while round-trip boundaries dominate single-user token latency. Wi-Fi variability, power-saving states, and background NAS transfers widen the tail even when an average bandwidth test looks healthy. That boundary should be measured separately under realistic operating conditions.
State Coordination and Failure Handling Decide Reliability
All nodes need the same model revision, tokenizer, quantization layout, and partition manifest. Checksums verify shards before loading, while versioned handshakes prevent one computer from serving layers from an incompatible update. The practical consequence appears when several sources compete for limited context.
disaggregated inference stages separates prefill and decoding across devices because their compute and memory demands differ. The work shows that distributing stages can improve serving only when placement and communication match the workload. This dependency should remain explicit in the final interface.
The failure boundary is a transient participant. If a sleeping laptop, Wi-Fi roam, or reboot interrupts the only copy of a stage, the whole request stops. Replication, resumable checkpoints, or a local fallback can improve availability, but each consumes the memory that sharding was meant to save.
Measure the Split, Not Just the Network Link
Benchmark each device alone, then record every partition boundary’s tensor shape, bytes per token, copy time, compute time, memory peak, and synchronization wait. Test short prompts, long prefill, sustained decoding, and two concurrent users over wired and wireless paths.
Relate the measurements to the NAS-shard scenario in home-network model shards. Simulate a node restart, version mismatch, link saturation, and one slow participant while tracking tokens per second, first-token latency, p95 inter-token delay, and recovery behavior.
Use sharding only if it enables the required model and maintains an acceptable tail latency under realistic contention. If communication dominates, choose a smaller quantized model, a coarser partition, or one stronger node rather than adding more weak devices.
What Features Enable a Home AI Trust Boundary Around Sensitive Files?
See how classification, capability-scoped access, isolated parsing, retrieval filters, egress policy, approvals, and audits contain sensitive home files.
What Factors Determine Whether Merkle-Tree Backups Detect Silent Change Efficiently?
Learn how chunk size, fan-out, trusted roots, cached hashes, change locality, metadata scope, and scrubbing determine Merkle backup verification cost.
What Components Enable Verifiable Backups of AI Indexes and Model State?
See how coordinated snapshots, content manifests, checksums, version locks, restore drills, and query tests prove that AI state can actually recover.
